Changing video card from HD7750 to HD7770 will I need to reload drivers? - AVS Forum | Home Theater Discussions And Reviews
Old 02-03-2014, 11:57 AM - Thread Starter
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
I have a HD7750 video card which seems to be failing and I want to know if I need to uninstall drivers first and re-install them or since they are the same family of cards will they just work?
Ordinarily I would uninstall and do a new install; looking for best info.
Rew
Rew
Vizio P75-C1 | OPPO UDP-203 | Samsung UBD-K8500
Denon AVR-x5200w | Nvidia Shield Android TV | C =Axiom VP150 |FL/FR =Axiom M60 |SL/SR =Axiom QS4 |TFL/TFR =Bose 161 | TRL/TRR =Bose 161 |Sub =Reaction Audio S-15 500W SEALED SUBWOOFER
Rew452 is online now
Old 02-04-2014, 03:34 AM - Thread Starter
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
WOW, 75 views and no replies!?
Rew
Rew
Old 02-04-2014, 03:51 AM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
i had issues going across generations, 3850 tp 6670, but within, should be ok. questions is. do you feel lucky?
worst case, reboot into safe mode to uninstall then reinstall if it doesnt work.
7790 though seems to have its own download options on amd website.
aliaskary77 is offline
Old 02-04-2014, 04:16 AM
bimmerfreak0's Avatar
Quoted: 12 Post(s)
I wouldn't think a reload is needed. Especially from within the 7700 series.
bimmerfreak0 is online now
Old 02-04-2014, 05:26 AM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
No need to reinstall the drivers. They are the same for both cards. However, you may want to see if the ones you have installed are the latest.
captain_video is offline
Old 02-04-2014, 05:34 AM - Thread Starter
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
Thanks, That was what I was thinking but wanted some confirmation.
It's my HTPC and want to be careful as to not cause other issues.
Thanks to you all
Rew
Rew
Old 02-04-2014, 06:08 AM
Quoted: 510 Post(s)
Liked: 336
You can always check the AMD website and see which drivers they have listed for each card. It used to be when you download graphics drivers from AMD, you download them for a specific family (i.e., HD7000 series), not a specific card. I just checked and they just have the AMD Catalyst Display Driver for a specific operating system or groups of operating systems (i.e., Windows 7, 8, and 8.1, 64-bit). They don't even break it down by graphics card family anymore.
Old 02-04-2014, 06:22 AM - Thread Starter
Rew452's Avatar
Quoted: 106 Post(s)
Liked: 64
They changed to a unified driver approach about 2 years ago covering all currently supported models; I think back to the 5000 series currently.That is why I asked if it was necessary to uninstall and re-install drivers for a same series card; HD7750 to HD7770.
My older 7750 card looks like it is failing and the price diff between the 2 is very minor <$15 so the 7770 seems like a better deal.
Rew
Rew
