Looking to build or buy nearly silent NAS with at least 12 slots supporting RAID 5+1 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 71 Old 02-15-2014, 11:12 PM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
Hello,
I'm looking at a lot of solutions - thunderbolt 2, LSI, NAS. What it comes down to is my need for a large amount of storage (4TB drives in each bay), excellent redundancy as I won't be backing it up, very good speed, and a nearly silent raid solution. I'm used to just buying dell arrays for work servers as there is no need to worry about noise in a server room. I've built all of my PCs to be nearly silent from a few feet away despite the high end processor and video cards and 8 drives in each.
I would definitely appreciate any experience you care to share as it may greatly reduce my research time on an ideal solution for my needs.
boe is offline
post #2 of 71 Old 02-16-2014, 04:23 PM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
What's your budget? $3K, $6K, and $10K will get you very different results
EricN is offline
post #3 of 71 Old 02-16-2014, 05:00 PM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
I'd like to keep it down to 3K at most but for very fast and quiet. I just priced it, for 4K I could build a whole new PC with an i7, fast array (LSI controller) etc. I might take the video card from my current PC if I do that and make it my new main PC.
boe is offline
post #4 of 71 Old 02-18-2014, 11:04 PM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
I think if I go a little crazy, I could build a great PC for about $5K (provided I take the video card from my current PC). I keep updating/tweaking my parts list. I'm going to wait to see how much the Toshiba 5TB drives are a few months after they are released. If by some miracle they are $300 or less I'll definitely use them in the rig I'm building. I'm also hoping LSI updates their 9280 card as they did the 9260 to the 9271.
boe is offline
post #5 of 71 Old 02-19-2014, 06:25 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I would look at a silent style case that holds 12 HDDs and start there. Nearly silent limits your selections and it all starts with the case first.
Sourcing or spec out the hardware is easy after you figure that out.
Some questions:
Why RAID 5 versus flexraid ?
Does size matter ?
Why does it have to be silent ?
Can you locate it somewhere a little noise is ok ?
My experience is if you want good performance and good capacity a server is going to make some noise. Not a lot but some.
You'll limit yourself in capacity and add extra cost at a rate of exponents as you become more and more excessive with the noise requirements. When you say nearly silent I think that means under 40db which would not be noticed as a noise source in a consumer home.
You might have to redefine nearly silent.
When I built my flexraid server I used a Norco 4220 chassis. Nice budget chassis IMO but noisy like a jet engine. I replaced the 4 80mm fan wall blade with a 120mm fan wall and I installed silent fans on it that I ran off the motherboard fan controller. I also replaced the two back fans with silent fans and also ran them on the fan controller. I set the target speed at 4 (out of 1-9) and raised the ideal target temp up 4 degrees (still plenty cool) and this has resulted in what I would call "nearly silent" but it's still louder than my SSD only HTPC on my bedroom with fans on setting 1. I used a full chassis on my HTPC so I could control the heat and noise better even though it's SSD only. Size matters and bigger with more airflow usually means cooler and quieter.
I can't tell if you are trying to build a NAS box (which will get hot if small and has 12 drives) or if you are trying to build a real server ?
I think if you choose the case wisely the rest will follow easily. Big full cases designed to be quiet are likely your best option, or you can save some cash by not getting somthing like a silent super micro chassis ($$$!) and doing like I did by retro fitting a cheaper case to be nearly silent.
Mfusick is offline
post #6 of 71 Old 02-19-2014, 06:59 AM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
I was trying to build either a NAS or a server but got no responses so I'm going to build a server as I know those well.
The server will be in my office which is off of my living room with no doors in between (I live in an apartment). My current PC is barely perceptible from the living room (8 drives, 780 video card and a 6 core processor). I have very good hearing so I can just notice it but my guests can't hear it. I replaced the stock fans in the case, put in an extremely quiet processor cooler and got the quietest version of the 780 on the market. I also dampened the sound of the interior of the case.
I've completed my needs for my current collection and it is about 34 TB.
I'll probably go with the Cosmos II case.
I'll be using my RAID for more than just movie storage so I want it as fast as possible and I need as much space as possible so I won't be mixing disk sizes. Flexraid is interesting but not really an alternative to an LSI raid if you've ever set up servers for the workplace. I'll be needing a 12-13 hard drives which the motherboard won't support natively and the case won't support much more space for 3.5" drives. I'll probably be going with raid 5 or 5.1 depending on space.
boe is offline
post #7 of 71 Old 02-19-2014, 07:44 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
I'm using a 3ware 9650 card in a 5.1 setup with capacity for 24 ports. It resides in my living room and is dead silent from a foot away. It's not cheap 😊 PM me if this is of interest to you.
DotJun is offline
post #8 of 71 Old 02-19-2014, 07:49 AM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
Thanks the 3ware and lsi are very similar (same company). I'm fine with either and you are right - not cheap at all by the time you add the cables and the battery but very fast compared to most controllers on the market. I currently have a 9260 and a 9271 between my two computers which will probably become backup storage systems for my new main computer with the 40-50TB of storage. I really wish they'd let you adjust the spin up time wait on those dang cards. Waiting for the PC to boot is unpleasant if you are as impatient as I am smile.gif
boe is offline
post #9 of 71 Old 02-19-2014, 08:00 AM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
I haven't decided which fans I'll keep or replace in the case but here is my current design with existing hardware on the market. I'm holding on to the hope that the 5TB (air) drives about to be released will be in the $300 range and the 9280-16i will be upgraded to an 9291 in the near future.
This will be my main PC and storage server.
1 GIGABYTE GA-G1.SNIPER Z5S LGA1150/ Intel Z87/ DDR3/ 2-Way CrossFireX & 2-Way SLI/ SATA3&USB3.0
1 Intel Core i7-4770 Haswell 3.4GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics BX80646I74770
1 Noctua NH-D14 120mm & 140mm SSO CPU Cooler
1 Kingston 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 Desktop Memory Model KVR16N11K2/16
1 Enermax Platimax 750W, 12V Multiple Rail, 80 Plus Platinum, Modular ATX Power Supply EPM750AWT
2 ENERMAX Power Supply SATA Cable 4x SATA
LSI MegaRAID SAS 9280-8i
4 3WARE Cable Multi-lane Internal Cable
1 LSI battery
1 Intel EXPI9301CT Desktop Adapter Gigabit CT 10/ 100/ 1000Mbps PCI-Express 1 x RJ45
1 Cooler Master Cosmos II - Ultra Tower Computer Case with Metal Body and Hinged Side Panels
AcoustiPack™ ULTIMATE PC Soundproofing Kit (APU)
13 Seagate or Toshiba 5TB drives
2 Samsung Electronics 840 Pro Series 2.5-Inch 256 GB SATA 6GB/s Solid State Drive MZ-7PD256BW (raid for 500GB - backed up with acronis frequently)
780 GTX video card (taken from my current PC)
3 Noctua 120mm, Anti-Stall Knobs Design,SSO2 Bearing PWM Case Cooling Fan NF-S12A PWM
2 Noctua 140mm Premium Quiet Quality Case Cooling Fan NF-A15 PWM
$7000 plus tax - estimating 13*325 for the 5TB drives
boe is offline
post #10 of 71 Old 02-19-2014, 10:35 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I don't think 12 hard drives and silent or near silent go together.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #11 of 71 Old 02-19-2014, 10:44 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I have a cosmos II case myself it's right under my Norco 4220. My desktop i7 4770k is inside that. Nice case. Very quiet. Very cool. Very very big !
You can do it in a cosmos II I'd guess and keep the noise down
Mfusick is offline
post #12 of 71 Old 02-19-2014, 10:51 AM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
Please let me know how to get 45-50TB of storage for under $5000 that can be nearly silent. You can't hear the hard drives in my current computers from more than a couple of feet away- I have 6-8 spindle drives in each.
boe is offline
post #13 of 71 Old 02-19-2014, 11:24 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Put the server/storage in the basement, or wherever noise is not an issue.
Even if it is quiet when you just built it, it will get noisier with time.
I am in the process of building a 16 drive pool in a Rosewill case. Just the hard drives alone, when powered up create noise. They make more noise when they are being accessed. Add some fans for cooling, a fan for the PSU, a fan for the CPU, and unless you can set them up so that one fan cancels the other fan's noise, and same for the hard drives. Even with rubber mounts, you can still hear them spin up and spin down.
Perhaps people have different definition of quiet. Mine is that if I can tell a difference between something being on and being off completely, it is not quiet.
Perhaps I have sensitive ears. I can hear some APC UPSes cycling charge on and charge off, and I can hear some LED light bulbs (mostly Insignia from Best Buy) in the ceiling fan fixture.
post #14 of 71 Old 02-19-2014, 11:53 AM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
My apartment has a very small basement, my downstairs neighbor gets offended for some reason when I try to store things there smile.gif
For me nearly silent means whisper quiet. If I can't tell the difference between something being on or off I'd say it is silent.
16 drives - that is awesome!
boe is offline
post #15 of 71 Old 02-19-2014, 04:58 PM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
If it was my space, I'd tell the neighbour in no uncertain terms where they can go. I also don't see the need to go to heroic efforts to get it quiet if there will be a wall or floor and some distance to another person's living space. Most PCs, even when noisy (like you would not have sitting next to you in a dedicated theatre) are mainly white noise with the occasional HF 'squeaky' noise of drives seeking, none of which is going to disturb anyone else's quality of life in an adjacent space unless they are contantly examining the dividing wall/floor with a stethoscope.
A9X-308 is offline
post #16 of 71 Old 02-19-2014, 05:51 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
It's actually easier to build a hush box out of sound treatments and store a server chassis inside, and it's cheaper. A sheet of MDF is $35. Watch what the guys in the theater building forum do. I saw a guy make a hush box for the blender so his wife didn't wake him up making her smoothies in the morning;)
Mfusick is offline
post #17 of 71 Old 02-19-2014, 05:55 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I have 20 in my Norco 4220 Flexraid server and it's pretty quiet. I also have 10 drives in my Cosmos II including a 9TB raid0 stripe and it's even quieter. A high quality case like the Cosmos II can be pretty quiet with proper set up; the built in fan controller is pretty nice too in that case. $350 PC tower is serious business. biggrin.gif
Mfusick is offline
post #18 of 71 Old 02-19-2014, 06:08 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
20 of the 3TB Seagate 7200.14 > 4TB @ 5900rpm IMO. $99 each and faster. Use two drives for parity and you get 18 data drives in Flexraid. You could sub the 7200.14 for the Hitachi 7k4000 or HGST NAS or Toshiba 3TB which are all cheaper too and still 7200rpm. That's 50 TB. Also only $2000.
Flexraid over hardware raid. I flashed the IBM M1015 to a pure HBA sata card using the LSI firmware in IT mode. I also bought some Dell cards Andy Steb flashed for me. I used 2 of them (2 SAS8087 ports each) to populate 4 rows of my Norco case. The top row I reserved for the 4 mobo ports. That got me 20 hard drive bays populated and still had mobo sata ports left for SSD and optical. The cards cost me $69 each. No raid pain either.
I can add or remove full or empty drives anytime without data loss. Drives readable in any system.
I upgraded my server 3 times easily without data loss. I replaced every part twice or more in the last two years.
I first built and all in one machine with a 2600k i7 in the CosmosII before doing it right. Learn from my mistakes biggrin.gif. It will save you from building a server 24 bay hot swap case after doing the cosmos 2 thing.
Mfusick is offline
post #19 of 71 Old 02-19-2014, 06:26 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
1 LSI battery
13 Seagate STBD4000400 4TB 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive – (Raid 5.1) Backed up along with docs on the SSD with freefilesync to older 2 computers.
$4700 plus tax.
If it was me I'd go for an Asrock Extreme 6 because I like it and it has dual intel LAN and 10 sata ports, plus plenty of PCI lanes for sata cards.
I'd go with a Norco4224. 24 bay hot swap chassis, and fill it with 24 hdds @ 7200rpm and 3 TB.
And I'd upgrade to faster ram. 1600mhz is so 2011 these days tongue.gif. 2400mhz is like $5 more.
I'd get a smaller better PSU (550 or 650 watts is enough)
Mfusick is offline
post #20 of 71 Old 02-19-2014, 07:13 PM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
Thanks when I did the PSU calculation between the drives, the 780GTX graphics card and the processor, 750 was recommended. I realize it probably own needs that at peak times such as boot up but I'm going to play it safe. I'm concerned I couldn't make the Norco quiet enough but I'll look at it again. I'll be honest I'm not nuts about the asrock motherboards although I might put one in a htpc.
I think him screaming over the 4224 is what is scaring me a bit as I'm not sure how much I could do to silence it. http://www.youtube.com/watch?v=8ixfto_1Nl8
http://www.youtube.com/watch?v=_RfQfDH11_I
Did you go with the 3 120mm fan blade or the original 4 80mm?
To be clear, I do not have a closet, I do not have a basement, or an attic, I do not have a guest bedroom, I do not have a panic room, I do not have a solarium where I can store it. I have a relatively small apartment and most rooms are connected with open walls (no doors) other than my bedroom and bathroom.
boe is offline
post #21 of 71 Old 02-20-2014, 12:34 AM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
With your goals (quiet workstation with lots of storage), I'd recommend an Antec P183 or P193 case. I've had a P180 for years that has seen many different drives, including some 10k rpm ones, and these cases really do help. The drive mounts have silicone standoffs, the drive cages are dampened, and the chassis is a thick steel-plastic laminate.
They have enough bays to meet your needs if you add some 3.5" cages in the 5.25" bays. You may have to make some compromises (USB dvd drive) to get there, but if you don't want to live with a jet engine, these are the best large workstation cases I know of.
EricN is offline
post #22 of 71 Old 02-20-2014, 01:07 AM
DotJun's Avatar
Quoted: 574 Post(s)
Liked: 154
Noctua 800 rpm 120mm fans are the quietest fans for the given cfm I have tried, and I've tested over two dozen fan makes. Dynamat helped quite a bit with stopping vibration along with general sound deadening. Don't use a typical server rack mount case as most of these use smaller fans and also less mounting points for fans.
If you a really plan on raid level 6 then I suggest your hardware as the software variety was slower on writes and random reads. At least the software I tried.
DotJun is offline
post #23 of 71 Old 02-21-2014, 09:38 AM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
Looks like both Toshiba AND Seagate are starting shipment of 5TB drives! So by late summer when I need to build this beast, prices may drop a teensy bit so I can justify the 5TB drives smile.gifsmile.gifsmile.gif
Unfortunately that will probably drive the price of this system up by about $2,000. On the plus side that gets me to the 50TB of usable space I really want while keeping my noise to where I want it.
I've looked at a lot of nice cases you guys have recommended and they all have their advantages and disadvantages but I think I'll stick with the Cosmos II for now although those other cases were great too.
boe is offline
post #24 of 71 Old 02-21-2014, 09:55 AM
GCS
GCS's Avatar
Quoted: 49 Post(s)
Liked: 32
Norco 4224 (24 bay case) here and while it is great for price, capacity it is a noise hound even with things swapped out it is a little nosier than I would like.
I did as Mfusick and replaced the 80mms in back out to some nice Noctua 80s and put Noctua 120s in the middle section as well but with 6 fans going and 16 7200RPM drives running it still makes enough noise in the theater room that on a super quiet movie scene you will notice it. Of course I notice my Benq 1080 projector more than I notice the server (love the pic quality, cheap price etc on the 1080 but hate the fan noise and its crappy HDMI handshaking).
Good luck with your build. It is hard to build a true server with lots of HDDs and be super silent.
FYI if you are interested in some older 3ware raid cards (9650se) with batteries PM as I have 2 to sell off fairly inexpensively.
EDIT - you may also want to look at some fractal design cases as they are supposed to be pretty nice, well built, lots of space and good cable routing etc. Your main key (which you already know) will be to get good quality controllable fans and really good PS. I highly recommend a modular PS. I wish I had gone this route on mine as I hate all the extra cables in there that I don't need.
Mfusick likes this.
XBL Gamertag - blowfish7494
"Pull up your big boy pants and deal with it" - The Wife!
"Put on your man suit and fake it" - The Wife
GCS is offline
post #25 of 71 Old 02-21-2014, 10:17 AM
ElJimador's Avatar
Quoted: 116 Post(s)
Liked: 109
Originally Posted by GCS View Post
EDIT - you may also want to look at some fractal design cases as they are supposed to be pretty nice, well built, lots of space and good cable routing etc.....
I can confirm this. I have a node 304 which I have sitting under my entertainment console directly below the TV, etc and even there with the case fans set to medium I don't hear the server at all, and that's running 6 hard drives (3TB WD Reds). Problem is, the node 304 can only hold 6 3.5" hard drives and I don't know that Fractal makes a case that holds more. If they do though then I definitely recommend that boe look at it. They make very nice cases.
ElJimador is offline
post #26 of 71 Old 02-21-2014, 10:24 AM
ElJimador's Avatar
Quoted: 116 Post(s)
Liked: 109
Just did a quick search and Fractal's Design XL and Arc XL cases both have 8x 3.5" internal hard drive bays + 4x 5.25" trays that can be converted = room for 12 total plus + 2x 2.5" dedicated SSD positions if he wanted those for the OS or cache drives. Those appear to be the biggest cases Fractal makes at the moment.
post #27 of 71 Old 02-21-2014, 10:30 AM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
Thanks. With the Cosmos II, I can put in 13 x 3.5" drives (to make 50TB usable with Raid 5.1) and still have room left for the 2 SSDs I'll use for RAID 0 and an optical drive and 1 hot swap bay.
boe is offline
post #28 of 71 Old 02-21-2014, 10:58 AM
ElJimador's Avatar
Quoted: 116 Post(s)
Liked: 109
Yeah that Cosmos II is a beast. For pure capacity I don't think you're going to find anything to top that.
Mfusick likes this.
post #29 of 71 Old 02-21-2014, 11:01 AM
ElJimador's Avatar
Quoted: 116 Post(s)
Liked: 109
I mean for something you can rig up to be anywhere close to the nearly silent running you're looking for. Obviously if you just wanted capacity you could go w/something like the Norco that GCS has. But it seems like you're on the right track for what you want.
Mfusick likes this.
post #30 of 71 Old 02-21-2014, 12:51 PM - Thread Starter
boe
boe's Avatar
Quoted: 884 Post(s)
Liked: 410
Who knows by the time I build this system in September - maybe they'll have a Cosmos III case for me to ogle smile.gif
Mfusick likes this.
boe is offline
Reply Home Theater Computers
