Running 1080, but if WMC in full screen only resumes in 720 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-21-2014, 05:12 AM - Thread Starter
Schroinx's Avatar
Quoted: 27 Post(s)
I run 1080 and it works fine. If I have WMC open and the monitor is turned off/stdb (or the computer) and then awoken again, the computer and screen continues in 1080 as it should, but WMC interface only resumes in 720 resolution. Taking WMC off full screen and then full screen again sorts it out, but it is a bit annoying, as it cannot be done with the remote. Any suggestions to sort this out?
Schroinx is offline
post #2 of 6 Old 02-21-2014, 07:43 AM
hammerdwn's Avatar
Quoted: 169 Post(s)
Liked: 52
HDMI?
What model GPU?
What model monitor?
Is there multiple monitors?
Is there an AVR?
Sounds like hdmi handshake/EDID. Many topic here on that. Many suggested solutions. Start here: http://www.avsforum.com/t/1387832/htpc-tweaks-and-fixes
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #3 of 6 Old 02-21-2014, 08:19 AM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Open Media center full screen just like have been.
Turn off/un-plug your monitor
Remote into your HTPC (Teamviewer works great for this)
Run the monitor set up wizard and change your resolution back to 1080p
After this it should stick.
Schroinx likes this.
Andy_Steb is offline
post #4 of 6 Old 02-21-2014, 11:05 AM - Thread Starter
Schroinx's Avatar
Quoted: 27 Post(s)
I'll try and explain a little better. The monitor, a LG plasma and source, a Mac mini, is connected by hdmi. The resolution in windows does not change on resume but stays at 1080. It is only the resolution of the WMC window in full screen, that changes down to 720 upon resume.
Schroinx is offline
post #5 of 6 Old 02-21-2014, 05:25 PM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Did you get around to test the procedure I listed above?
post #6 of 6 Old 02-22-2014, 06:28 AM - Thread Starter
Schroinx's Avatar
Quoted: 27 Post(s)
Almost spot on. I did not need to connecte remotely, just get WMC to the wrong resolution and then run the wizard. Couriously the listed modes was a 1080p and a 1920x1080 interlaced 50 hz. Should I chose the 1080p above the interlaced?
EDIT, you already wrote that. Thank you for your help!
Schroinx is offline
Reply Home Theater Computers
