How do I modify the metadata? - AVS Forum | Home Theater Discussions And Reviews
Old 02-22-2014, 11:56 AM - Thread Starter
boe
boe's Avatar
Quoted: 917 Post(s)
Liked: 417
Hello,
I'm not quite sure if it is metadata or what but I have a few movies that have additional movies. I think it was Iron Man 3 that came with Agent Carter about Cap's girlfriend after his plane went down. It is about a 15 minute short. When I turned it to an MKV the name of the MKV file is Agent carter but my Oppo sees it as Iron Man 3 (twice) and only plays the full movie, not the agent carter short. I have to put it in a different folder than Iron Man 3 and then Agent carter plays fine.
boe is offline
Old 03-09-2014, 07:26 PM - Thread Starter
boe
boe's Avatar
Quoted: 917 Post(s)
Liked: 417
I got the answer on makemkv forums - mkvmerge has a Header Editor that you can use.
boe is offline
