menu highlights were working, not anymore - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 07-03-2002, 08:04 PM - Thread Starter
rbrandt's Avatar
I'm running 1800 x 960i on my HTPC and am having trouble getting the menu highlights to display properly. They're stretched and you can only see the top 1/3 of them. I had the menus working properly before (well, I was running 1440 x 960i, that's the only difference). Since then I've re-installed Win98 and was running 1440 x 480p but I decided to use interlaced rez again. Only now I can't get the menu highlights to work.
Does anyone know what I can do to get them working again? Funny thing is it was working right after I set up my 1800 x 960i rez, but a few hours later it wasn't. As far as I know I didn't change anything, but I can't get it to work again.
Thanks for any advice.
rbrandt is offline
Closed Thread Home Theater Computers
