ASUS Chromebox - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By busbeepbeep
Old 03-05-2014, 12:40 PM - Thread Starter
ssaeed's Avatar
So has anyone managed to get their hands on the ASUS chromebox yet? It looks to be shipping. Wondering if it is going to be possible to run Windows or Linux on it with XBMC....would make for a cheap low power HTPC. Not sure what the performance of the Celeron in it would be.
ssaeed is offline
Old 03-06-2014, 01:08 AM
spiderbite88's Avatar
I'm wondering this too, it definitely looks very promising as a decent HTPC. Seeing as the intel NUC with the Celeron 847 can run XBMC at 1080p with no issues, you'd expect the Celeron 2955U with about a 40% performance increase (even more graphically) to run it even smoother.
spiderbite88 is offline
Old 03-14-2014, 06:28 PM
kneedragger's Avatar
Quoted: 18 Post(s)
Found this the other day. http://liliputing.com/2014/03/asus-chromebox-review-chrome-desktop-celeron-cpu.html
I'm hoping more info comes out on having one OS and installing Linux.
kneedragger is offline
Old 03-15-2014, 02:56 AM
Dark_Slayer's Avatar
Quoted: 634 Post(s)
Liked: 416
Holy smokes -- this thing is ripe for openelec at what looks to be one of the best prices out there. I had hopes for bay-trail nucs, but a haswell celeron would be preferable to a haswell atom with ivy graphics. I'd love to see idle power consumption comparisons and the max bitrate they can handle
Dark_Slayer is offline
Old 03-15-2014, 03:07 AM
almostinsane's Avatar
Quoted: 45 Post(s)
Liked: 41
I think all of these Chrome PC's use secure boot and the OS cannot be changed.
almostinsane is offline
Old 03-16-2014, 02:13 AM
Puwaha's Avatar
Liked: 35
Did you read the article? It says you can install Linux side-by-side with Chrome OS. Plus, in the comments section, it's mentioned that other Chromebooks have a literal "write-protect screw" that you can remove to do whatever you want to it. At the pricepoint of this box, I'd say people will figure out how to get other OSes on it like Windows.
But even if that never happens, you should be able to use Linux/XMBC/OpenELEC or something.
Puwaha is offline
Old 03-16-2014, 06:04 AM
The only problem that needs overcoming now is the requirement of holding down the alternate-boot key combination every time it starts (Ctrl+D?). As little as it sounds, I don't want to have people restarting and getting stuck in the wrong OS all the time. I guess leaving it on is a possibility, as it uses so little power.
Old 03-17-2014, 06:22 AM
sneals2000's Avatar
Quoted: 209 Post(s)
Liked: 110
The Acer C720 Chromebook (which has near-identical specs -2955U + 2GB RAM + 16GB M2 SSD etc.) has a script that can alter some settings stored in Flash that switches the default BIOS mode and the time out settings, which removes the need for CTRL+L to get you to legacy BIOS (which is needed to boot OpenElec)
http://johnlewis.ie/how-to-make-seabios-the-default-on-your-acer-c720/
Hopefully the Chromebox will have similar functionality.
I have a C720 but haven't flashed it yet. I use Chrome OS (CTRL+D to boot), Ubuntu (as a separate partition on the SSD using CTRL+L to boot) and OpenElec (from a USB3.0 stick using CTRL+L to boot). The performance with recent OpenElec nightlies is very good indeed. Perfect HTPC to take when you're in a hotel. (I usually take a USB TV tuner and with TV Headend and an HDMI connection to the hotel TV have much better TV options than many - still analogue - hotel systems)
sneals2000 is offline
Old 04-18-2014, 10:19 PM
busbeepbeep's Avatar
To update this thread, I got an asus chromebox and am running openelec on it. Runs great. 1080p, dts-hd pass thru, no problems.
Got xbmc installed on the internal ssd. Press ctrl + D to boot chrome os or ctrl + L to boot openelec.
Thanks to Matt Devo and others on the xbmc.org forums and John Lewis as above for the bios work.
http://wiki.xbmc.org/index.php?title=ASUS_Chromebox
fgsouza likes this.
busbeepbeep is offline
Old 06-01-2014, 03:35 PM
jenglish13's Avatar
Do you know if the 2GB celeron version can pass through dts-hd & dolby hd or do you need the 4GB i3 version? Thanks
jenglish13 is offline
Old 06-01-2014, 08:18 PM
Defcon's Avatar
Quoted: 1098 Post(s)
Liked: 558
The 2GB Celeron one can do passthru of all digital audio. There is no hw processing needed so the i3 is not needed.
busbeepbeep (love your user name btw), a few questions for you since I alos just bought a Chromebox -
- did you install Coreboot firmware or still on the default one?
- what do you use for a remote solution?
- do you keep box always on (I think idle power should be <10W), if not how do you power on remotely?
Defcon is offline
Old 06-04-2014, 02:27 PM
I'm still on the default firmware. I didn't remove the write protect screw. I just installed the script for openelec, and press CTRL+L to boot. I should go back and redo it, but I leave it on all the time so the boot time or having to press CTRL+L doesn't bother me much.
I use a PS3 BluRay bluetooth remote. I also have used a Logitech K400 with it, which works fine during Openelec , but cannot pass the CTRL+L during startup. Luckily, it's pretty stable and I don't have to reboot often.
Old 06-10-2014, 04:47 PM
elsmandino's Avatar
Hi,
I am thinking of buying for these as it will be perfect - I need a device that can be used with both Openelec and Netflix.
Just a couple of questions with regards to playing Netflix via Chrome OS (which I have never used):
1. Can you get 5.1 sound output from Netflix this way?
2. Can you use Hola with Netflix, in Chrome OS, to unblock other Netflix regions? I am based in the UK so would need to preserve my access to Netlix US.
Thanks very much
elsmandino is offline
Old 06-12-2014, 02:57 PM
efball's Avatar
Quoted: 60 Post(s)
Liked: 41
Smile
Originally Posted by elsmandino View Post
Hi,
Thanks very much
I don't know about 5.1 (probably) but mine is connected to a stereo only setup. Netfix / Amazon/ Vudu do not stream in HD. 480 only
See this Amazon review for more details: http://www.amazon.com/review/R2DQLBY...res_rtr_alt_13
I don't know what Hola is, but I can use the ssh client to setup a tunnel to use as a proxy and stream the BBC.
When I tried doing that with netflix it did not like that my account was not in the country I was connecting from.
Vizio M60-C3 UHD TV
Insignia 40" FHD TV
MythTV / Ubuntu / Home Run Prime
Onkyo TX-DS777 receiver
Paradigm Studio v2 speakers
Clark Tactile Transducer
efball is offline
Old 07-13-2014, 02:44 PM
mastermaybe's Avatar
Quoted: 335 Post(s)
Liked: 283
So then if you really have grown to love xbmc like I have this box is pretty much plug n play (on the hardware side anyway) for $160?
Anything I lose to the nuc besides IR (which sucks by the way)?
James
Actual phone call (see pic to left):
Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
Old 07-16-2014, 03:05 PM
Quoted: 634 Post(s)
Liked: 416
Yes, and a perfect size internal ssd. Great amount of info here http://wiki.xbmc.org/index.php?title=ASUS_Chromebox
I'd do like loki05 seems to have done and remove the write protect screw and make it openelec/standalone. I have zero reason to dual boot chromeOS, personal choice though
The only reason I'm considering a Q-1900 for my next box instead is that I have extra RAM and an extra case just sitting around
Asus really hit it out of the park for xbmc usage I think, though I think that it's gpu doesn't have enough EU for lanczos3 upscaling in XBMC if that's of importance
Originally Posted by loki05 View Post
I thought that when clicking streams the lag came from the server end, but it didn't. The hardware and software really makes a difference...streams are pretty instant
Thanks for the video, but for reference I've tried a lot of that stuff in the past (1channel, navi-x, icefilms, mashup, etc, etc) and the experience you have is not just better hardware. I've tested a lot of them on my i5-3570k gaming htpc, and there used to be way more lag and buffering. They definitely improved their backends
Right now I'm pretty happy with individual add-ons instead like southpark, colbert, daily show, etc, but I also have the USTV VOD add-on which works ok in a pinch.
Old 07-16-2014, 03:50 PM
Quoted: 335 Post(s)
Liked: 283
Thanks guys...
I ended up getting the celeron nuc and 4 gigs of ram for $170.
I figure if I ever need to load windows on it I can and it seems (now, anyway) people are very happy running openelec and xbmc on it.
Hopefully Ill get the latest 2830 version but I'm not holding my breath.
Either way, I know Ill be happy with xbmc and I wish I would have figured this out long ago.
James
Old 07-16-2014, 05:53 PM
Quoted: 634 Post(s)
Liked: 416
Another thing that I like is *experimental* to say the least. On my vizio m701d-a3r HDMI-CEC is poorly supported. Back button exists and the remote uses wifi-direct, so it seems open-shut. However, cec with my sony tv is quite a bit better. The home button goes to the home screen and the arrow keys are much less tactile (which is nice for menu navigation).
Either way, if you want to try it out then libcec is built into openelec. The usb adapter from pulse eight isn't too cheap http://www.pulse-eight.com/store/pro...c-adapter.aspx. When you compare it to the cost of a remote it's not too much more and it gives you a nice all-in-one power button if your tv supports it
The sony tv supports "keep power states in sync" which means that when I press the power button on the tv remote it turns the TV off, and by consequence that activates the shutdown function in openelec. You can change the shutdown function to "suspend" in OpenELEC settings. Then when you turn the tv on, it will send a wake command to your htpc. (Though they disabled suspend on removable boot drives in OpenELEC, so you have to do a short ssh work around to re-enable it -- I can show you if you are interested)
Another nice byproduct you get if your tv supports synchronizing power states is that yatse will be able to power off (suspend) your htpc+tv and wake it with a wol packet (which will turn the tv back on)
Old 07-23-2014, 06:53 AM
Liked: 0
I bought the ASUS Chromebox over the weekend, installed standalone OPENELEC/XBMC and OMG...it is awesome!! This past year I had the Gbox MX2 and this is like 300% better. I thought that when clicking streams the lag came from the server end, but it didn't. The hardware and software really makes a difference...streams are pretty instant, and no more crappy ANDROID OS to use. If you're looking for an HTPC box, I'd definitely recommend the Chromebox running OPENELEC. I made a quick youtube on it, no cuts or edits, just me navigating around to show you speed and responsiveness...hope this helps:
http://youtu.be/7gKnTf_Akaw?list=UU-...lkBCOuRJi9n8Rw
Was wondering if you could either make vid or send step by step directions on how to do this the right way. Read to many things and need to know th correct way to install Openelec standalone. is there anyway you can send directions in a private message.
Brandon Baker is offline
Old 07-24-2014, 12:47 AM
Quoted: 634 Post(s)
Liked: 416
Start with this link (read all)
Originally Posted by Dark_Slayer View Post
Then follow along to this and read through the entire first post http://forum.xbmc.org/showthread.php?tid=194362
Everything should be covered before you even get your hands dirty
Old 09-14-2014, 10:55 AM
DaveFi's Avatar
Quoted: 49 Post(s)
Liked: 27
Just curious if you could watch Xfinity TV Go on this using their Chrome extension, or quite possibly watching the on demand stuff through a browser off the website?
Anyone with one of these and Xfinity want to test it for me?
XBOX Live: Wagmman
PSN: Wagg
BFBC2: Wagman
Steam: Wag
My Second Life character looks and acts exactly like me except he can fly.
DaveFi is offline
Old 09-16-2014, 07:10 PM
efball's Avatar
Quoted: 60 Post(s)
Liked: 41
I have a standard ASUS Chrombox (standard Chrome OS). The xfinity web page works for viewing shows. I was surprised because it doesn't work on my Linux box. The xfinity chrome extension is for viewing live TV, not shows on demand (but it works too).
Vizio M60-C3 UHD TV
Insignia 40" FHD TV
efball is offline
