Who else has built a ridiculously overpowered HTPC? What's your story? - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 16Likes
post #301 of 346 Old 05-07-2014, 11:52 AM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
Originally Posted by Dark_Slayer View Post
Why is this so specifically important for you
Quick guess, to help combat bit rot. While it may not matter much for desktops, it's a concern for servers that are left running 24/7 for months on end. Longest uptime for my unRAID server was actually 2 years (had to shut down due to a failed UPS).
ilovejedd is offline
post #302 of 346 Old 05-07-2014, 12:42 PM
ajhieb's Avatar
Quoted: 1034 Post(s)
Liked: 693
Yeah, I'm a little curious about that myself...
I'm still a little fuzzy on the exact nature of bit rot, what causes it, and how ECC could help to prevent it.
MY understanding is that you can generally gruop the contents of RAM into 2 groups... code to be executed and data to be manipulated. If a memory error occurs ECC can correct a single bit error, and detect multiple bit errors and halt the system before anything is corrupted. Without ECC if a memory error occurs, the consequences could vary a great deal. If the memory error effects code to be executed then the effects could be pretty broad, ranging from system crash/bsod to "nothing happened when I clicked on the button" All of which I would lump into the broad category of "system instability" but generally shouldn't result in any permanent data corruption.
On the other hand, if the memory error effects data in memory (instead of code) and if that date is eventually destined to be written to disk, then that could/would result in long term data corruption / bit rot. The consequences of this would depend on what data was corrupted, and possibly where in the file it was corrupted. Let's say it effected your movie.xml metadata file. It could do anything from render it inaccessible to making it unreadable by your front end, (if for instance an xml tag was corrupted) or even just change the title of the movie from "Terminator" to "Tfrminator" If it effected an MKV, it could do anything form making the file inaccessible, to corrupting a single pixel, to corrupting a single frame or even a group of frames.
Any of the latter could happen to my MKV when it is read from disk and there is a memory error as well.
Now if you had a database on that drive, that was frequently being written to you might have something more to worry about. (which brings us full circle to traditional datacenter-type servers.)
Applying this to home media servers, I don't see much of a need for it on my 2k3x64 server that is mainly storing movies that I have original copies of. If something gets corrupt I can just rerip it. And in my experience NTFS is generally pretty resilient from getting borked.
If I'm storing more important data on there, I might be more inclined to worry about memory errors. If I'm storing data that is going to have a bigger impact on my life if it gets corrupted, (corrupt tax document could result in an audit, which would annoy me a great deal more than a bad frame while watching "Deadwood") I'd be more inclined to go with ECC.
I'm not really familiar with any of the unix variant file systems that you'd use in conjunction with something like FreeNAS but my understanding is file systems like ZFS are significantly more complicated than NTFS and might be happier if treated more like a database than a traditional file system. So with one f those I might be more inclined to go with ECC.
But I'm a little curious about the uptime comment. Not sure how that would be relevant unless the "data scrubbing" I've heard about would be prone to corrupting data. Otherwise I think that it would be more of a function of disk writes more so than uptime.
That's my understanding of things anyway.
Dark_Slayer and jhughy2010 like this.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is offline
post #303 of 346 Old 05-07-2014, 04:26 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Bit rot in the context of media might be a glitchy frame for a second on every 1 out of 1000 movies.
Not a big deal
Mfusick is offline
post #304 of 346 Old 05-07-2014, 06:24 PM
Dark_Slayer's Avatar
Quoted: 729 Post(s)
Liked: 452
I don't just mean in the context of a media server (though as explained it's not very important for media storage)
I mean more in the context of . . . . Will ECC ram eradicate bit rot on an NTFS file server?
Dark_Slayer is offline
post #305 of 346 Old 05-08-2014, 02:45 AM
ajhieb's Avatar
Liked: 693
Using ECC memory should decrease bit rot (or if we're being technical "silent data corruption") on any file system, but It can't eliminate it. Data can be corrupted in any number of places between the time it is transferred out of RAM and written to the disk, most of which will go unnoticed by even the most diligent of file systems. What the file system can do is detect and in some cases repair errors caused by drive firmware errors, media defects, and the occasional bit-flip on the disk caused by a stray cosmic ray.
From what I understand of the issue, silent data corruption happens at a rate higher than would be indicated by just looking at the unrecoverable read error rates for hard drives, but despite that, they are still a fairly uncommon occurrence when dealing with the typical amount of data that one would put together with consumer grade equipment.
But if one was hoping to eliminate bit rot by using ECC memory, I'd say it would be a fruitless endeavor, but if you're just trying to keep your data safer than it would otherwise be, and you can afford a couple hundred bucks for ECC memory, I say go for it. (and let's face it, most people here that are putting together multi-terabatye servers, can probably afford ECC RAM if they so desire)
ajhieb is offline
post #306 of 346 Old 05-08-2014, 03:07 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
I don't think ECC RAM would play a major role in fighting bitrot. If you really care about your media, you'll run it in an environment where its checked for consistency after being written, which would already detect (but not correct) such problems. I'm sure there are some cases where it may help, but I doubt those are the majority.
IMHO, its far more likely for the data on your HDD to randomly flip a bit, without the RAM being involved, causing rot this way, and that needs either a file system to periodically check itself, or a layer on top (like FlexRAID with Validate/Verify) that does the checking.
ajhieb likes this.
Nevcairiel is offline
post #307 of 346 Old 05-08-2014, 06:51 AM
ilovejedd's Avatar
Quoted: 76 Post(s)
Liked: 67
I think that's most likely the goal here. A resilient file system (e.g. ZFS) or a layer of parity protection with data validation (e.g. SnapRAID), paired with ECC RAM to minimize errors during parity calculation, data validation or rebuild.
post #308 of 346 Old 05-08-2014, 07:57 AM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
No, not in the HTPC context. Almost all HTPC data is write-once, read-many, and extremely tolerant of bit errors. It doesn't get churned enough for ECC to matter. (caveat: with ZFS, use ECC). For an NTFS fileserver, the money is better spend on more drives to protect the data.
Here's decent read on the merits of ECC.
http://www.cs.toronto.edu/%7Ebianca/papers/sigmetrics09.pdf
ajhieb likes this.
EricN is offline
post #309 of 346 Old 05-08-2014, 09:21 AM
ajhieb's Avatar
Liked: 693
Thanks for the link. Interesting (if not a little bit tedious) read.
ajhieb is offline
post #310 of 346 Old 05-08-2014, 09:25 AM
OrioniS's Avatar
Once.. Long time ago, I had a Asus PC-DL with 2x Xeon 2.8GHz and registered ECC memory. You may believe me or not, but it did few times ECC alert/reset, one of reason I found was my memory slot, other was my PSU not filtering anything (another reason for good UPS in between ;-). It was soo annoying that I did switch off ECC features and it went quiet... I was not doing anything particularly important like storing data, just my desktop PC, so I didn't bother: I wanted dual Xeons.. Then we had dual core, quad cores.. and I forgot about whole story. Once I immersed myself into NAS4Free and ZFS and other toys, it came back, but I cannot afford those new Xeons (and old ones are too power hungry for my liking) and motherboard with them. Once you married ;-)... I would have to pay 4x as much for ECC on Intel. For my NAS is not really worth it. I would spend that money on HDDs.
So what that Intel takes 35W at idle and AMD 50W? Intel will cost me much much more, AMD cost much much less and I can get decently featured motherboard for fraction of the price. If you use ZFS and checksumming and something goes wrong in your memory, then you wouldn't really know that there is problem until it's too late. It doesn't matter for normal desktop PC: worst case scenario you just lose a file or have a reset, but with ZFS where nearly everything is based on memory operations... Ask yourself: would you like to have a bulletproof car with plastic windows?? It can take a RPG shot into the side of car, but unfortunately you can break into by hand through plastic windows... Silly?? Maybe, but true.
My first NAS was born out of curiosity, but quickly it was re-developed as something more than anticipated and it outgrow its own description. Now, with experience of past, I can build myself what I really need and old MB with Celeron G1610 will be repurposed into my Multimedia Player where low idle will be welcomed more than loads of ECC memory.
ajhieb: As far as I can see, ECC Unbuffered are NOT more expensive than non-ECC. I got myself 2x2GB 1333 ECC Unbuffered for £3.99 each plus delivery of £2. No one want it on fleabay, because they think is a server memory. A side story: Guy is selling ECC for Apple computers for less because people don't want to buy them... and I emailed him asking what's the crack? He said to me that is easier to sell it to Apple people because they actually make use of ECC... So.. Money is NOT problem ;-)
OrioniS is offline
post #311 of 346 Old 05-08-2014, 09:31 AM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
On a side note, I did just order parts for a gaming server and went with unregistered ECC. It was only a $50 premium for 32GB, since I was already committed to Xeon/C226. My goal is building a Hyper-V/VDI/RemoteFX stack for thin-client gaming, and I want to minimize the number of parts that aren't certified for it.
EricN is offline
post #312 of 346 Old 05-16-2014, 11:47 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
I would be curious to hear more about that project ^
You doing a build thread ?
Mfusick is offline
post #313 of 346 Old 05-18-2014, 01:54 AM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
mobo: Supermicro X10SAT
cpu: Xeon E3-1245V3
ram: Kingston KVR16LE11K4/32I
gpu: 2x Radeon R9 290
nic: Intel I340-T4
boot: 2x Crucial M500 120GB
data: 4x Sandisk Extreme II 240GB
psu: SeaSonic SS-860XP2
ups: CyberPower PR1000LCDRT1U
jhughy2010 likes this.
EricN is offline
post #314 of 346 Old 05-18-2014, 08:44 AM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
jhughy2010 is offline
post #315 of 346 Old 05-18-2014, 08:56 AM
Nevcairiel's Avatar
Quoted: 43 Post(s)
Liked: 135
Personally, I would actually be surprised if your idea of a virtualized gaming system actually works out to any decent degree. I would expect games to not like what is happening, and the entire experience to be sub-par.
But good luck to you anyway!
post #316 of 346 Old 05-18-2014, 04:23 PM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
Initial verdict: very pleased.
I put it to the test this weekend, and it supports 4 thin clients with desktop-quality graphics. From the logs, I expect it to support 6-8 if needed. Friends came over (some with year-old, well-spec'd gaming laptops), and got more fps remoting into the server versus playing natively off their own GPU! We took an old Core2 laptop out of mothballs and ran it alongside modern rigs, and you couldn't see a difference. WAF(albeit a gamer-W) is extremely high, and so far, it has been an big win.
Granted, I've only tested multi-client with ESO (and one game of Civ5), but remote vGPU gaming has impressed the hell out of me. Your assumption that most games won't play nicely has been a concern of mine from the start of this project, but it has been smooth so far...without having to drop $3K on an Nvidia Grid.
The downside is that it's wired only. For a decent experience, it needs a 250Mbps+ link that my wifi simply can't sustain. Making this happen wirelessly is the next WAF hurdle.
EricN is offline
post #317 of 346 Old 05-18-2014, 04:48 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
What games do you play ?
Mfusick is offline
post #318 of 346 Old 05-18-2014, 08:42 PM
jhughy2010's Avatar
Quoted: 852 Post(s)
Liked: 278
I've always been under the assumption that games require local hardware?  I never thought it to be possible to remote into a server with beefy GPUs and play games utilizing the servers hardware.
post #319 of 346 Old 05-18-2014, 09:50 PM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
With Citrix XenDesktop, Microsoft RemoteFX, or VMware Horizon View, the client can use the server's GPUs. It doesn't have to be 1:1 sharing either. I can have three clients evenly sharing the two cards in the server, with each client receiving the equivalent of 2/3s of a Radeon R9
EricN is offline
post #320 of 346 Old 05-18-2014, 10:24 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
I have the same motherboard and CPU in my VM computer. Are you running ESXi or Xen or what to get the Radeon to work as a vGPU to the thin clients?
rc05 is offline
post #321 of 346 Old 05-19-2014, 07:43 AM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
Hyper-V. I prototyped this idea with all three (Xen, ESXi, and Hyper-V) using a 3770S on a DQ77KB.
EricN is offline
post #322 of 346 Old 05-19-2014, 11:08 AM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
Right, I almost forgot about Hyper-V! Thanks for the info, I might play around with Hyper-V this summer.
rc05 is offline
post #323 of 346 Old 05-19-2014, 11:19 AM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
The biggest gotcha I encountered: VDI+RemoteFX needs a domain environment, but it can't run on a DC. (Hyper-V can, but the VDI role can't) The VDI host also needs to run on bare metal. The DC can be a VM on the VDI host, but you can't join the bare-metal VDI host to the domain using the VM DC: chicken-and-egg problem.
In a nutshell, the whole stack can run on a single machine, but you will need a second Windows Server to bootstrap it.
EricN is offline
post #324 of 346 Old 05-22-2014, 07:29 PM
Dropkick Murphy's Avatar
Quoted: 72 Post(s)
Liked: 89
I think this one counts as ridiculously overpowered (or at the very least, over-engineered).
CASE: Fractal Node 605
CPU: i5-4570
MOBO: Asrock Z87m Pro4
RAM: G.Skill 8GB (2 X 4)
GPU: Asus R9 270
SSD: Samsung 840 Pro
HDD: WD 500GB Black 2.5"
PSU: Seasonic 460 watt Fanless
FANS: Corsair AF120 Quiet Edition (X-2), Corsair SP120 PWM Quiet Edition, Enermax T.B. Silence 80mm
Watercooling:
RAD: XSPC 120mm
PUMP: Laing DDC-1T
RES: Bitspower 150mm X 60mm
CPU WATERBLOCK: XSPC Raystorm
GPU WATERBLOCK: XSPC Rasa
HARD TUBING: Monsoon: 3/8" X 1/2"
SOFT TUBING: XSPC 3/8" X 5/8"
MISC FITTINGS: Monsoon, Bitspower, EK
Mfusick, kesawi and jhughy2010 like this.
Dropkick Murphy is offline
post #325 of 346 Old 05-23-2014, 05:56 AM
wiley165's Avatar
Location: State of Rhode Island and Providence Plantations
Quoted: 62 Post(s)
Liked: 98
Originally Posted by Dropkick Murphy View Post
I think this one counts as ridiculously overpowered (or at the very least, over-engineered)...
You'd be better off simply stating "HERE !", then drop the microphone, and walk off stage.tongue.gif
wiley165 is offline
post #326 of 346 Old 05-23-2014, 07:30 AM
royalpython's Avatar
Hey, it looks awesome though, I'm hoping it's efficiency matches it looks!! I'm sure it does :)
royalpython is offline
post #327 of 346 Old 05-23-2014, 06:43 PM
Quoted: 72 Post(s)
Liked: 89
Lol, Awesome!
Originally Posted by royalpython View Post
Hey, it looks awesome though, I'm hoping it's efficiency matches it looks!! I'm sure it does smile.gif
I still have to test the water loop for leaks and get a copy of windows 7 before I can go any further. I did put the finishing touch on the physical build today with a window (you gotta show off that jewelry right?).
post #328 of 346 Old 05-24-2014, 08:28 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Mfusick is offline
post #329 of 346 Old 05-24-2014, 02:56 PM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
http://www.maximumpc.com/lian_lis_hybrid_desk_chassis_shipping_july_starting_989
Might make for an interesting project ^
That's interesting, but a little expensive. I wonder if the glass is strong enough that you could put a 50" TV on top.
Well, Duncan, he's just this guy, you know?
dfkimbro is offline
post #330 of 346 Old 07-16-2014, 07:44 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Originally Posted by dfkimbro View Post
Quote:Originally Posted by Mfusick
http://www.maximumpc.com/lian_lis_hy...y_starting_989
I'd guess yes. Glass is surprisingly strong.
Mfusick is offline
Reply Home Theater Computers
Intel Core I5 3570 3 4 Ghz Processor , Intel Pentium G2020 2 9ghz Lga 1155 Dual Core Desktop Processor , Intel Pentium G3220 3 0ghz Lga 1150 Dual Core Desktop Processor , Intel Core I7 4770k 3 5ghz Lga 1150 Quad Core Desktop Processor , Intel Core I3 4130 3 4 3 Fclga 1150 Processor Bx80646i34130 , Intel Core I5 4670k 3 4ghz Lga 1150 Quad Core Desktop Processor , Asrock Z87m Extreme4 Lga1150 Intel Z87 Chipset Ddr3 Quad Crossfirex Quad Sli Sata3 Usb3 0 Microatx M , Asrock , Amd A10 6700 Richland 4 2ghz Socket Fm2 65w Quad Core Desktop Processor Amd Radeon Hd Ad6700okhlbox , Amd A6 5400k 3 6ghz Socket Fm2 Dual Core Desktop Processor , Amd A8 5600k 3 6ghz Socket Fm2 Quad Core Desktop Processor , Amd A6 3650 2 6ghz Socket Fm1 Quad Core Desktop Apu Cpu Gpu With Directx 11 Graphic
