Am I the only one that uses Splashtop instead of team viewer ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 35 Old 03-14-2014, 08:35 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
http://www.splashtop.com/
Someone once recommended it to me (Damelon ?) and then Asrock started offering it as a standard with their mobos so I got hooked. It works very well. The ipad and iphone apps are also neat. I can sign onto my PC and control it anytime, and it streams audio and video very well.
Mfusick is offline
post #2 of 35 Old 03-14-2014, 09:18 AM
bakerja's Avatar
I used it for a couple of years but when they went to the annual subscription model, I bailed. Microsoft's remote desktop has come a long way and the ipad & android apps work quite well.
bakerja is offline
post #3 of 35 Old 03-14-2014, 09:40 AM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
I just use RDP or Remote Desktop Manager...
techmattr is offline
post #4 of 35 Old 03-14-2014, 09:54 AM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
+1 for RDP
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is offline
post #5 of 35 Old 03-14-2014, 10:09 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I use this for my server. I do it nearly daily and it works very well. I love that I can click "use all monitors" and it brings up my 2600k based Flexraid server on all three of my triple monitors, or I can just use one monitor and keep my normal work station on the other two. Very nice!
I am a huge RDP user but I never figured out how to get audio and video to stream well, or use it to control my parents or brothers HTPC at their place or my own desktop from work.
I also never figured out how to use ipad or iphone to control my PC or server either (or other machines)
Can you clarify that for me?
Locally SLASHTOP is FREE. But over internet it requires a small but reasonable fee.
And my last question for you you guys is that I found it hard to set up RDP on a machine that did not have a password. I don't want a password on my machines, especially my HTPC which I don't want to enter from a remote only controlled device. Is there a way to get the normal microsoft RDP to work on say my HTPC without a password ?
It works great on my server because WHS2011 requires a password and I have one. But that threw me for a loop last I tried so I ended up just using splashtop which works well. I am sure there might exists a solution. know it ?
Mfusick is offline
post #6 of 35 Old 03-14-2014, 10:21 AM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
To access an RDP system over the internet you'll need to forward port 3389, and either take note of the cable modem's IP address or use some sort of dynamic DNS client to connect. That should be about it.
As far as using it with no password I believe the concurrent RDP session patch has an option to enable connecting with a blank password, but I certainly wouldn't recommend doing that with your ports forwarded. Anyone could connect to you machine. All of my computers have a password. On my HTPC I simply enabled autologin and it's never been an issue, as I have no other inbound connections to that computer anyway.
ajhieb is offline
post #7 of 35 Old 03-14-2014, 10:27 AM
bakerja's Avatar
+1 That's how I do it also.
bakerja is offline
post #8 of 35 Old 03-14-2014, 10:38 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Ok so let me clarify.
I don't want to ever be able to access my HTPC from outside my local LAN inside my home. Never from away from home ever. I only want to be able to use RDP on it from my desktop located in another room on the same local network. I don't want to port forward anything or expose myself or my HTPC to any harm even though it's a pure 100% HTPC that never contains any personal information so I don't really think it could hurt me. What's the worst someone could do? Watch my media ? I'm generally PC knowledgeable enough to avoid problems in these areas anyways. My HTPC does not even need internet access actually.
But I don't want to use a password on it. I want it to restart automatically and jump right to my front end. I only have a remote on it. No keyboard. No mouse.
I want to do my maintenance and stuff from my desktop in RDP session. Can I remove the password and do that ? How ?
Mfusick is offline
post #9 of 35 Old 03-14-2014, 10:51 AM
Roussi's Avatar
Quoted: 45 Post(s)
Liked: 36
I cannot believe you don't know how to do an autologin ("netplwiz"); or, I cannot see the reason why you wouldn't want to.
Roussi is offline
post #10 of 35 Old 03-14-2014, 11:03 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I guess I don't. Aware me.
Mfusick is offline
post #11 of 35 Old 03-14-2014, 11:06 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
By entering the netplwiz command above, your can assign a designated User to automatically log in when the/a computer gets turned on or rebooted. You can also have the RDP remember your credentials so you don't have to enter a password all the time.
I use RDP from work with DDNS and a designated port which I forward to 3389.
Also use teamviewer when I want Restart/sleep options which I don't get with RDP. Also got Jump when it was offered by Amazon as free app of the day. Actually jump is my favorite RDP app for Android as it mostly behaves like windows RDP.
oman321 is offline
post #12 of 35 Old 03-14-2014, 11:09 AM
bakerja's Avatar
Type netplwiz in the run line (start, search/run box at the bottom). That gets you into the user manager which will give you the option of "not requiring a password for login" or something to that effect. Computer will boot right in to the desktop without any user intervention.
bakerja is offline
post #13 of 35 Old 03-14-2014, 11:09 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I don't want to port forward or use over the internet. I just want to use RDP locally without needing a password. From one machine in my house to another.
So if I do that I can RDP in without needing a password ?
Mfusick is offline
post #14 of 35 Old 03-14-2014, 11:11 AM
bakerja's Avatar
Not sure if RDP requires the password but in RDP you have the ability to "remember" the login and auto connect.
bakerja is offline
post #15 of 35 Old 03-14-2014, 11:14 AM
bakerja's Avatar
Actually, now that I think about it, I'm pretty sure that RDP does need the password but like I said, you type it in once and "save username and password".
In reality it's "remember my credentials"
bakerja is offline
post #16 of 35 Old 03-14-2014, 11:22 AM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
http://lmgtfy.com/?q=windows+7+auto+login
Aware.
ajhieb is offline
post #17 of 35 Old 03-14-2014, 11:25 AM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
The Concurrent RDP patch will allow you to login via RDP with a blank password.
The netplwiz change will allow you to put a password on your computer and still automatically login and launch your front end.
ajhieb is offline
post #18 of 35 Old 03-14-2014, 11:27 AM
bakerja's Avatar
RDP does have restart and sleep. While in an RDP session, click start, windows security on the remote PC. Then the power options are available in the lower right part of the screen.
oman321 likes this.
bakerja is offline
post #19 of 35 Old 03-14-2014, 11:31 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Ok so I guess I am getting confused. You are saying that I put a password on my HTPC but then enable auto login ? Then I just use the password in RDP from my workstation and have it remember the password so I don't need to enter it each time ?
Mfusick is offline
post #20 of 35 Old 03-14-2014, 12:00 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Since you stream video with Splashtop, you may not want to go down the RDP road since it sucks a video streaming. Does everything else great though. Nice for messing with the HTPC without disturbing anyone else.
mdavej is online now
post #21 of 35 Old 03-14-2014, 12:14 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
oman321 is offline
post #22 of 35 Old 03-14-2014, 12:18 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Yes. Once you do this you just click the connection you want, ba da boom, ba da bing.
oman321 is offline
post #23 of 35 Old 03-14-2014, 12:22 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I do that now with my server and WHS2011 from my desktop but I always just used splashtop when I wanted to use the HTPC because I hated having a password on it.
Mfusick is offline
post #24 of 35 Old 03-14-2014, 12:26 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
Yes you are the only one using splashtop instead of teamviewer
From the thread however, it appears many people still have love for RDP
I prefer VNC to RDP, so that's why I stick with TeamViewer
I don't stream audio and video that way. If there is something I wanted to watch or listen to I'd just open Plex Web in a browser (or if using tablet/smartphone the plex app)
I like teamviewer a lot, you can install the host-only package as well. That is what I have on my server, parents pc, and sisters pc. That way they can't use it to control my stuff by accident biggrin.gif. It uses default outgoing ports so there isn't anything to forward through your router smile.gif
Dark_Slayer is offline
post #25 of 35 Old 03-14-2014, 01:02 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
What exactly is so great about team viewer ? I find slashtop better in most ways.
Mfusick is offline
post #26 of 35 Old 03-14-2014, 01:21 PM
Quoted: 655 Post(s)
Liked: 434
Actually I didn't realize splashtop wasn't a VNC client
For my parents / sister / etc, a VNC is more preferable to me since I login and take over their controls without logging them out. I can converse with them over the phone, and move their mouse around "showing" them what is going on
TeamViewer happens to be my preferred VNC client since it's Win/Nix supported with mobile apps as well. Icing is that it works with OSX as well
If there is something going on that endangers WAF while I'm away, I can "see" exactly what's going on and fix it without logging in / out / etc. I like the "shared" desktop experience for troubleshooting
Also, since I only use remotes on my HTPC (and server htpc tongue.gif ) it is also helpful if I do need to type or control anything with a keyboard / mouse
post #27 of 35 Old 03-14-2014, 01:30 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
You can also WOL from the webclient. Not yet available on the android app, not sure about ios. Not a big deal if you only use it locally, but nice if you want remote access to a powered down machine. Obviously you don't need teamviewer for WOL but it saves a step or 2.
oman321 is offline
post #28 of 35 Old 03-14-2014, 01:34 PM
mdavej's Avatar
Liked: 940
Hmm... $5/month for Splashtop. I think I'll stick with the free ones. VNC and RDP work fine. I have no need for streaming video inside a remote session.
ajhieb likes this.
post #29 of 35 Old 03-14-2014, 02:14 PM
Aluminum's Avatar
Quoted: 22 Post(s)
Liked: 25
Ah, so you guys are the reason why the drive-by botnets that hit the ranges at work test for port 3389 to be open. They clear and enumerate a /16 in a few seconds, its nuts.
I figured it was just a leftover port like 445 from the days when people actually plugged in directly, but guess they still find enough open that its worth cycling through the laundry list of windows exploits for anyone behind on their patches. (patch tuesday = exploit wednesday) Probably overdue for another 0day anyways.
PS you're crazy if you have services meant for trusted LANs forwarded to your WAN on the same ports no less.
When I stopped caring about super quiet: E5 1680v2 @ 4.5Ghz, 980ti, i750 SSD - JS9500 & Dell P2715Q for dual 4k@60 because reasons
SAN shares over 56Gb infiniband, microcenter + fleabay = severe risks to my wallet
Aluminum is offline
post #30 of 35 Old 03-14-2014, 02:28 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I'm only talking about local access via RDP inside my network, not from outside. I don't forward any ports.
Mfusick is offline
Reply Home Theater Computers
