Multi tuners playing on the same screen- Is this possible? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 03-23-2014, 03:39 PM - Thread Starter
wackychimp's Avatar
So... sitting here watching NCAA tournament on my projected 136 inch screen and loving it.
Then I started to think how awesome it would be to project all of the games at once. I've got 3 tuners on a WMC PC but don't think I've ever seen a way to project 3 feeds at once.
Surely it's possible. If I can record 3 channels at once, wouldn't it be possible that I could have 3 images projected at once with sound from one of them? The projector shouldn't care, right? It'd just be projecting one image of three separate channels.
Doesn't have to be a WMC solution. I'd gladly build another HTPC just for this functionality.
Is there any way to do this "sports bar" kind of thing?
wackychimp is offline
post #2 of 8 Old 03-23-2014, 03:50 PM
captain_video's Avatar
Quoted: 529 Post(s)
Liked: 341
Sure is. Check this out:
http://www.hdhomesportsbar.com/
One caveat. You can only watch two shows on one screen if your TV has PIP and can accept two separate inputs for display. Any more than two feeds will require multiple monitors.
captain_video is offline
post #3 of 8 Old 03-23-2014, 07:39 PM - Thread Starter
wackychimp's Avatar
This is cool but requires 4 boxes and 4 monitors.
Does anyone know of a single-screen application that does the same thing?
post #4 of 8 Old 03-24-2014, 04:11 AM
Quoted: 529 Post(s)
Liked: 341
You'd need four inputs on the monitor that could display four PIP frames simultaneously. I don't know of any monitors that have this capability, except perhaps some sort of video surveillance monitor. There are some TVs that have a split frame capability that allows you to display two images side by side rather than one large frame with a small PIP frame in the corner. In any case, you'll need four devices that can provide individual outputs. A HTPC can only provide a single output from the graphics card or motherboard, buy can provide multiple outputs if you use extenders .
post #5 of 8 Old 03-24-2014, 04:43 AM
el_kano's Avatar
Mediaportal 2 (only in Alpha currently) supports PiP, although I am not sure it can manage 3 as have yet to test it myself:
http://www.team-mediaportal.com/news/mediaportal-20-alpha-released
But, any copy protected content (cable) won't be supported.
el_kano is offline
post #6 of 8 Old 03-24-2014, 02:57 PM
dicko2's Avatar
Quoted: 17 Post(s)
What tuners are they? If they're HDhomeruns, you can open multiple copies of their Quicktv program to get multiple screens at once.
dicko2 is offline
post #7 of 8 Old 03-27-2014, 09:33 AM - Thread Starter
wackychimp's Avatar
Yeah it's an HDHR Prime - 3 tuners.
I was hoping there would be a software way to "combine" all 3 feeds onto the the same single output to the Epson projector. IF the hard drive can record 3 tuners at once, wouldn't it be possible to play them back within a single output at the same time too? The PC can deal with the feeds ok.
I'll look into Quick TV - I hadn't heard about that.
post #8 of 8 Old 03-27-2014, 10:49 AM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
What you are looking for is 'video tiling'.
almostinsane is offline
Reply Home Theater Computers
