htpc to plasma tv snowy picture - AVS Forum | Home Theater Discussions And Reviews
Old 03-30-2014, 07:05 PM - Thread Starter
MHK
MHK's Avatar
Hello.
My htpc is connected to a panasonic plasma with hdmi. When the desktop shows and I sit close to the tv the black background on the tv is a little snowy. When watching a movie the black bars on the top and bottom are also snowy. From the nornal sitting position I won't notice it but it still bothers me. I tried different hdmi cables but no luck. Is there anything else I can try to get rid of the snow/static?
thanks
MHK is offline
Old 03-30-2014, 08:51 PM
Thrillho's Avatar
Liked: 32
That's how Plasma is. Just sit at a normal viewing distance and you'll never notice it.
gonzo90017 likes this.
Thrillho is offline
Old 03-30-2014, 09:05 PM
lockdown571's Avatar
Liked: 62
Is it only happening with your HTPC or with other sources as well? Sounds like plasma dithering, in which case you are probably sitting too close to the TV. Make sure you've switched your plasma from it's default settings (usually "dynamic" or "vibrant" mode) to something like normal, movie, or cinema mode.
lockdown571 is offline
Old 03-30-2014, 10:52 PM
StinDaWg's Avatar
Quoted: 450 Post(s)
Liked: 214
If it's showing up in the black bars it means you need to turn the brightness down until they completely go away. Once you do this your brightness will be properly set and you should never see this issue again. On Panasonic plasmas this should be somewhere around the 50/100 mark in Cinema mode.
StinDaWg is offline
Old 03-31-2014, 07:39 AM - Thread Starter
MHK
MHK's Avatar
Thanks for your replies. I don't notice it that much with the satellite signal but it is still there. At least I know now that it is not any kind of interference or anything wrong with my htpc. I'll try some different picture settings. Thanks again
MHK is offline
Old 03-31-2014, 11:33 AM
ferlisboa's Avatar
I reduced my "snowy panel" by reducing the "panel luminance settings" to Med.
ferlisboa is offline
