Playclaw - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 04-11-2014, 10:01 AM - Thread Starter
TxBobS's Avatar
Has anyone used Playclaw? If so, what kind of performance did you get?
I am trying to use Playclaw to drive my AmbiBox but it causes some video stuttering.
Bob
HTPC - Built with Assassin Guides
Intel G620 - GIGABYTE GA-Z68MA-D2H-B3  - Samsung 830 SSD
Win 7 SP1 32b - G.Skill 4GB - SilverStone Grandia GD04B - Seasonic SS-460FL2 Fanless PSU
TxBobS is offline
post #2 of 13 Old 04-11-2014, 10:18 AM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
Can you describe a little more on what you're actually doing? Googling Playclaw and AmbiBox I can't really put the two together.
techmattr is offline
post #3 of 13 Old 04-11-2014, 10:25 AM - Thread Starter
TxBobS's Avatar
Playclaw is a screen capture program that works like FRAPS if you will. Ambibox takes that information and drives LEDs mounted behind the TV. All of this acts like the Samsung Ambient Light Engine. This is an Adafruit project called Adalight. Works pretty well and is pretty immersive. Just curious if anyone else has run it and if so on what hardware.
https://www.youtube.com/watch?v=LOxKkf8LrbU
Bob
TxBobS is offline
post #4 of 13 Old 04-11-2014, 11:57 PM
ryu4000's Avatar
I'm using it with my setup
amd apu 3500
win 8.1 wmc
4gb ram
gt 610
i get stutter on the video also not sure how to fix it wish i could cause it hurts watching movies/tv with it on.
ryu4000 is offline
post #5 of 13 Old 04-12-2014, 08:05 AM - Thread Starter
TxBobS's Avatar
Thanks. I noticed last night that while watching Netflix I did not get any stuttering. So far I've only noticed it while playing back a WMC recorded TV file. Setting compression to None in Playclaw seemed to help. I'll try watching live TV and also a movie through Media Browser to see if it happens there.
I also noticed that the Adalight sketch runs pretty fast but it just doesn't work for full-screen WMC.
Bob
TxBobS is offline
post #6 of 13 Old 04-12-2014, 10:58 AM - Thread Starter
TxBobS's Avatar
I did some CPU monitoring while running Playclaw using different sources. It seems that for some reason, during certain playback, the MS Security package sucks up an entire core. Turning off the real-time monitoring provided perfect playback.
Bob
TxBobS is offline
post #7 of 13 Old 04-12-2014, 03:07 PM
ryu4000's Avatar
What you mean turning real time monitoring off???
ryu4000 is offline
post #8 of 13 Old 04-12-2014, 03:38 PM
Aleron Ives's Avatar
Quoted: 1581 Post(s)
Liked: 1289
Disable your antivirus program so it stops scanning and reducing your performance.
Aleron Ives is offline
post #9 of 13 Old 04-12-2014, 04:13 PM - Thread Starter
TxBobS's Avatar
Right. Not sure if other anti-virus software works that hard during playback, but the MS Security Essentials one does. in there it is called "Real-time Monitoring".
I should see if I can exclude all of the video files from its processing.
Bob
TxBobS is offline
post #10 of 13 Old 04-12-2014, 07:45 PM
ryu4000's Avatar
I disable windows search indexer using this method http://answers.microsoft.com/en-us/windows/forum/windows_7-files/disable-windows-search-indexer/914286d5-9485-49a9-a3df-f9516c9970cd
It seem to help here a video it's only 30 seconds long but i didn't notice any stutter or anything.also this is from live tv within wmc.
https://www.youtube.com/watch?v=h9WflGBUpQ0&feature=youtu.be
I couldn't find that compression settings in play claw you was talking about
ryu4000 is offline
post #11 of 13 Old 04-13-2014, 08:17 AM - Thread Starter
TxBobS's Avatar
In Playclaw I changed the "Video Compression" to None in the "Encoder" tab.
If you use Microsoft Security Essentials as your anti-virus software, it is under Settings and is called "Turn on real-time protection (recommended)". I unchecked this.
Bob
TxBobS is offline
post #12 of 13 Old 04-13-2014, 09:09 PM
ryu4000's Avatar
I guess we have different playclaw cause in mine i can only turn it to fast no off switch in the encoder tab for me but thanks anyways seems like i'm starting to get a stutter free exp now.
ryu4000 is offline
post #13 of 13 Old 04-21-2014, 02:25 PM
ryu4000's Avatar
Well found out the issue for me playclaw not playing nice on win 8.1 it cause stutter on both wmc and xbmc well changed to windows 8 under ambibox settings now xbmc is smooth as silk but no wmc support its the price to pay.
ryu4000 is offline
Reply Home Theater Computers
