Radeon HD 6450, Haswell GT1, Haswell GT2 or A6-6400K for nicely-deinterlaced 1080i? Argh! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-15-2014, 06:18 PM - Thread Starter
allio's Avatar
Hello
I’m doing an overhaul of my father’s HTPC and am struggling a bit with the right way to go. Here’s what he’s currently using to run WMC on Windows 7:
Athlon II X2 245
2GB DDR3-1333
Geforce GT 440 1GB DDR5
On the other hand, here’s what I’m using to run XBMC/TVHeadend on Ubuntu:
Phenom II X4 955
8GB DDR3-1600
Sapphire Radeon HD 6450 1GB DDR3
We both largely use our HTPCs to watch live TV (1080i/50).
Dad's machine has been running like crap recently, and I’m planning to replace the CPU, bump the memory up to 4GB and add a small SSD. Also central to my plan is nabbing the GT 440 for my own purposes, as AMD cards can’t do vector adaptive deinterlacing in Linux and I understand that the Geforce will manage a lot better. However I’m not sure what to replace it with in Dad’s box while ensuring that he doesn’t take a hit in image quality.
My first thought is to swap it with the 6450, as I understand that it’ll do vector adaptive deinterlacing in Windows. He certainly wouldn’t care about or even notice high quality upscaling so madVR etc isn’t necessary. Anandtech’s review of the 6450 says that it can do VA deinterlacing of 1080i/60 while enforcing smooth playback, so that should theoretically do the trick. However there are also lots of (admittedly pretty old) reports on AVS about problems with the 6450 with 1080i, like a lagging interface and dropped frames. I don’t want to take a few hundred bucks from my Dad and hand him back something that performs worse than the old one.
If I repurposed the 6450, I’d put a Pentium G3220 in there as a cheap, zippy upgrade to the old Athlon. However I’m not convinced that the GT1 HD Graphics in the G3220 is up to high-quality (VA equivalent) deinterlacing of 1080i. Another option is to just get an i3 with GT2 HD Graphics, which I understand can definitely manage VA of 1080i no problem. I don’t really mind spending the extra cash if it's worth it, but I’d rather avoid it unless I have to as I don't think I'd get any tangible CPU performance improvements for the near-doubling in price.
Finally, I could get an AMD APU. This would definitely have the graphics grunt, but would leave some CPU performance on the table compared to the G3220 and results in me having to chuck the 6450 in the bin, which seems wasteful. I'm also reluctant to get a Richland now when A6/A8 Kaveris are just around the corner (theoretically...) and really don't want to put an A10 in there.
So, what would you do?
  • G3220 + onboard GT1 (cheap)
  • G3220 + 6450 (cheap)
  • G3220 + a new GPU (expensive)
  • A6-6400 + onboard (cheap)
  • i3 4130 + onboard GT2 (expensive)
  • Wait for A6/A8 Kaveri
Feh!
allio is offline
post #2 of 8 Old 04-15-2014, 09:47 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Celeron G1820 is enough, or A6-6400K if he wants 3D. Add a discrete graphic card only when PQ is unsatisfactory. As far as deinterlacing is concerned, Celeon = Pentium = Core i3/i5/i7.
allio likes this.
renethx is offline
post #3 of 8 Old 04-15-2014, 10:13 PM - Thread Starter
allio's Avatar
Definitely no 3D.
So a G1820/G3220 can produce deinterlacing quality of a 1080i/50 signal on par with a A6-6400K/Radeon 6450? No jagged diagonals, and 50fps rather than 25fps? If so this is actually a really easy decision...
Thanks for your reply!
allio is offline
post #4 of 8 Old 04-16-2014, 04:13 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Intel HD Graphics is perhaps better than HD 6450 because deinterlacing is done in ASIC (unless you encounter the 29/59 Bug).
renethx is offline
post #5 of 8 Old 04-16-2014, 10:05 AM
Ruiner's Avatar
Add the ram and SSD and check back.
Also define 'running like crap', as in perhaps loaded with browser bars and spyware/crapware?
Ruiner is offline
post #6 of 8 Old 04-16-2014, 12:11 PM
Elpee's Avatar
Quoted: 61 Post(s)
Sorry, OP. Off topic for a while.
renethx, when you're talking about PQ, BTW, I have a quick question.
An HTPC with Core i3 vs discrete HD 7770 vs a HD Player Oppo 105, which one should I buy for PQ? Why? I'm mainly playing 3D iso movies.
Thanks for your reply.
Elpee is offline
post #7 of 8 Old 04-16-2014, 01:38 PM - Thread Starter
allio's Avatar
Huge long pauses navigating the WMC interface, changing channels, responding to remote commands, generally doing anything. There's no crapware - it's literally just used for running WMC and never even sees the Windows desktop. Most of the time it's not even connected to the internet. It's not all down to hardware, I know, as it certainly wasn't anything this bad when I first built it, but it was never a speed demon even in its day and it is time for an upgrade I think. And my upgrade fingers are itchy smile.gif
Besides - I want to snag that GT 440! There's no onboard video so I have to replace it with something, and a straight swap for the 6450 would be a downgrade if anything.
Perfect. Thanks.
allio is offline
post #8 of 8 Old 04-16-2014, 09:49 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
If you mean Blu-ray 3D, then PQ is almost identical whatever graphics processor you use.
renethx is offline
Reply Home Theater Computers
