Newbie proposed first build - AVS Forum
post #1 of 18 Old 05-15-2014, 03:18 PM - Thread Starter
gotgrowth's Avatar
Hows it going guys my brain is on overload but I've managed to come up with this build
http://pcpartpicker.com/p/3KFwG
It will be used for streaming downloading 1080p movies TV shows and to web browse ..... No gaming at all ....
I would also like to get ota channels and live TV if I can but there will be no cable connection. Please feel free to give any advise as this is my first time doing anything like this
Sent from my SGH-M919 using Tapatalk
gotgrowth is offline
post #2 of 18 Old 05-15-2014, 07:24 PM - Thread Starter
gotgrowth's Avatar
Anyone
post #3 of 18 Old 05-15-2014, 07:40 PM
Toys7505's Avatar
Quoted: 42 Post(s)
Thumbs up to the Sammy SSD - will provide you some fast performance! Also, I like the Silverstone case, have the GD08 myself though. You will like the construction of it. Only thing I see missing is a HDD of at least 2tb to get you started with storing media. Other than that, looks good!
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K EX4420, B&K TX4430, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
post #4 of 18 Old 05-15-2014, 08:12 PM - Thread Starter
gotgrowth's Avatar
Build is getting way up there in price for me
post #5 of 18 Old 05-15-2014, 09:40 PM
Toys7505's Avatar
Quoted: 42 Post(s)
You could save some additional $$ by going intel.....say a Celeron processor and ASRock motherboard from the Egg. Could save you another $40 that you can apply towards a WD or Seagate HDD.
Toys
Toys7505 is offline
post #6 of 18 Old 05-16-2014, 04:09 AM - Thread Starter
gotgrowth's Avatar
I always thought and was cheaper then Intel and the HDD would just be under additional memory or storage? .
Can you reccomend what specific CPU and mobo? Is the mobo have wofo built in
post #7 of 18 Old 05-16-2014, 04:32 AM
Toys7505's Avatar
Quoted: 42 Post(s)
You can run an Intel Celeron with HD graphics included - http://www.newegg.com/Product/Product.aspx?Item=N82E16819117301
and this motherboard since I see you want a mini ITX - http://www.newegg.com/Product/Product.aspx?Item=N82E16813157451
it doesn't have wifi built in but you can always add a card to handle that...........
Toys
Toys7505 is offline
post #8 of 18 Old 05-16-2014, 05:24 AM - Thread Starter
gotgrowth's Avatar
Mini isn't necc at all I have no preference ..
post #9 of 18 Old 05-16-2014, 06:54 AM - Thread Starter
gotgrowth's Avatar
Cheaper the better but I want it to be fast and powerful I will sacrfoce size
post #10 of 18 Old 05-16-2014, 06:54 AM
Orange14's Avatar
I've been using the Gigabyte H87N-WiFi motherboard in HTPC builds and it works well.  You could couple this with a Pentium G3220 CPU for a first rate unit.  Unfortunately, it will cost a little more than you have in the original build.
Orange14 is offline
post #11 of 18 Old 05-16-2014, 07:39 AM - Thread Starter
gotgrowth's Avatar
What would be the benefit over running the original setup?
post #12 of 18 Old 05-16-2014, 07:55 AM
Orange14's Avatar
I don't know since I only use Intel CPUs.  Can't give you any advice about AMD chips.  I think the Gigabyte motherboard that you identified in that build is pretty similar to the H87N.   I stream Netflix and Amazon Prime over the WiFi and it works fine.
Orange14 is offline
post #13 of 18 Old 05-16-2014, 08:41 AM - Thread Starter
gotgrowth's Avatar
How far is your router from your htpc. ?
post #14 of 18 Old 05-16-2014, 08:52 AM
Orange14's Avatar
15 feet but I did an identical build for my wife's workstation which is upstairs and she streams video all the time.  I'll be putting in a 2nd HTPC up in our bedroom as soon as the new furniture arrives and plan to use the same MoBo for this build as our house is not wired for Ethernet.
Orange14 is offline
post #15 of 18 Old 05-16-2014, 09:04 AM - Thread Starter
gotgrowth's Avatar
Oh really? Because I am moving into a basement apt. And the landlord is providing me with free WiFi. I wanted avoid having to get my own line if I didn't have to .... I just didn't know of the signal would be strong enough or if the antenna on the mobo was good enough
post #16 of 18 Old 05-16-2014, 09:10 AM
Orange14's Avatar
My wife's office build is 60 feet or so from the router and upstairs and it seems to work fine.  You will need to try it and if it's not satisfactory see if the landlord will install one of the Ethernet over Power Line transmitters.   That should do the job if the WiFi does not.
Orange14 is offline
post #17 of 18 Old 05-16-2014, 09:48 AM - Thread Starter
gotgrowth's Avatar
Does that require any hardwires? Because that would be impossible with thebsetupnof the house
post #18 of 18 Old 05-16-2014, 08:11 PM
dfkimbro's Avatar
Quoted: 37 Post(s)
Liked: 41
With ethernet over power line, plug two or more adapters into power outlets in different parts of the house and they use the power lines for ethernet. It's slower than Cat5 or Cat6 but is usually sufficient for video and more stable than a typical wifi connection. Depending on the home wiring they may work well for you.
dfkimbro is offline
Reply Home Theater Computers
