Windows Media Center shutting down daily - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-17-2014, 05:40 PM - Thread Starter
wolfgang187's Avatar
So, everyday at 1am my WMC decides to shut itself down. I've taken to adding WMC to a program that keeps programs running at all times, but I'd like to figure out why it's shutting down on its own everyday @1am and to stop it.
wolfgang187 is offline
post #2 of 7 Old 05-17-2014, 10:09 PM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Odd did you check the bios?
trans_lux is offline
post #3 of 7 Old 05-18-2014, 07:00 AM
drtdiver's Avatar
Do you have optimization turned on in the media center settings?
drtdiver is offline
post #4 of 7 Old 05-18-2014, 08:35 AM - Thread Starter
No, optimization is off, but it doesn't matter. I've had it on before and it still turned off at the same time every day.
post #5 of 7 Old 05-18-2014, 12:45 PM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Two quick ideas
Is it possible you enabled this a scheduled task when you opted in on getting the latest Electronic Programming Guide for your TV-Tuner?
Check the "Task Scheduler".
wolfgang187 likes this.
post #6 of 7 Old 05-18-2014, 01:03 PM - Thread Starter
Originally Posted by trans_lux View Post
Two quick ideas
Thank you! Not sure how this task was scheduled, but ACS Digital Media themes for windows media center was running FIXMC.Menu's.exe which was crashing it daily at 1am. That was the last lingering issue with my HTPC and it now works flawlessly! TY again.
post #7 of 7 Old 05-18-2014, 01:52 PM
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Awesome!
Glad it's resolved.
Reply Home Theater Computers
