Laptop as Home Theater - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-03-2014, 05:53 PM - Thread Starter
sdelafuente's Avatar
Hi all,
I would like to sollicit some advice on my theoretical Home Theater setup. I have an old InFocus beamer (DVI input) and a Denon AVR3805 receiver which I would like to use. These used to be hooked up to a desktop (Video Card DVI to beamer DVI and Toslink motherboard to Toslink receiver). I have now moved and the desktop is unpractical locationwise so am thinking on buying a laptop and using this as HTC. I have my eye on a Dell XPS 15 (http://www.dell.com/us/p/xps-15-9530/pd?oc=dncwx1249h&model_id=xps-15-9530#overrides=dncwx1249h:454~PATNB) which has HDMI and a mini DisplayPort output.
My question: what would be the best way to split video and sound to the beamer and receiver?
For video I was thinking mini DisplayPort to DVI of the beamer via an adapter.
For audio I was thinking USB to external sound card (soundblaster X-Fi) which then sends Toslink to Toslink AVR.
Looking forward to your advice!
Thanks & regards,
Sam
sdelafuente is offline
post #2 of 4 Old 08-16-2014, 04:40 PM
SteelWill's Avatar
Quoted: 79 Post(s)
Liked: 38
Poor Sam, his only post, so hopeful, and no one responded. I'm currently looking at a similar situation with using a laptop for HTPC duty and a search brought up this thread. Does anyone have any advice on how to split and handle audio over USB? I see these are floating around on ebay:
Can anyone here confirm they do what they're supposed to, particularly the optical out?
SteelWill is offline
post #3 of 4 Old 08-16-2014, 05:18 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
When I was using my laptop as a HTPC I used the Turtle Beach Advantage Micro II for audio to my receiver via optical. HDMI would go from the laptop to the tv.
Worked well for bitstreaming AC3 and DTS.
http://www.amazon.com/Turtle-Beach-A.../dp/B0036VO4X4
Mrkazador is offline
post #4 of 4 Old 08-17-2014, 03:19 PM
Tyborg's Avatar
Quoted: 13 Post(s)
I have also used the Turtle Beach Advantage Micro II with good results.
Tyborg is offline
Reply Home Theater Computers
