How many cards will effect at a same time at max? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-09-2014, 03:26 AM - Thread Starter
yandexrhino's Avatar
My friend complained about the lack of USB ports so he was straightforward to find a PCI Express card. I helped him to check out a video(https://www.youtube.com/watch?v=RJFVyMHAycM) about it.
The man in the video just used 3 memory cards for displaying the effects. And he described that 3 are maximum for using at the same time.
I'm confuse. Why wouldn't it effects if using more?
Guys can you help me with this?
Thank you.
yandexrhino is offline
post #2 of 6 Old 06-09-2014, 04:46 AM
StinDaWg's Avatar
Quoted: 451 Post(s)
Liked: 216
StinDaWg is offline
post #3 of 6 Old 06-10-2014, 02:24 PM
ikkuranus's Avatar
Quoted: 86 Post(s)
Liked: 53
He says using a 3.0 compatible device will give the best speed results as opposed to using a 2.0 or lower specification usb device.
You can't use more then 3 at a time on this device end of story.
As for your other question please rephrase is so we can actually comprehend you.
ikkuranus is offline
post #4 of 6 Old 06-18-2014, 07:21 PM - Thread Starter
Originally Posted by StinDaWg View Post
Uh, i'm sorry that don't understand why you just post a picture that way...
I just want solving the problem...
post #5 of 6 Old 06-18-2014, 07:34 PM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
i think he means works instead of effect.
I dont know what the limitation is that lets you use only 3 of the memory cards slots at a time. this products page does not tell you much.
i dont see it being a problem. does your friend have more that 3 different type of flash cards he must use at the same time?
aliaskary77 is offline
post #6 of 6 Old 06-18-2014, 08:35 PM - Thread Starter
All right. I don't mean he must use 3 different types of flash cards at the same time.
I just think that the more types of flash cards can be used at the same time, the better. Isn't it?
Reply Home Theater Computers
