HDD records duplicates of each program thumbnail? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-12-2014, 06:05 AM - Thread Starter
stevethebrain's Avatar
Quoted: 108 Post(s)
Liked: 25
I’m using Windows 7 media center and a Western Digital MY Book Elite external HDD.
Each new program’s thumbnail is being duplicated and is also counted as two programs, also each old show’s thumbnail that was previously recorded to this drive has also been duplicated, I believe the HDD space used isn’t doubled, I haven’t confirmed that yet., if one of the duplicates is deleted then both are deleted.
I have since switched this Western Digital MY Book Elite external HDD as my storage drive (which is a USB 2 type) and the duplication and sleep issues has gone away however I would prefer to use the WD as my primary everyday record watch and delete, HDD it still actually works maybe it can be reset?
I have some Western Digital HDD diagnoses software I can try however I believe it’s W7MC settings that are somehow not configured correctly for a external drive?
Edit: The Western Digital MY Book Elite external HDD comes w/ a automatic backup SW however I have never used it I would prefer to choose what I backup plus it really doesn’t make any sense to backup on the same drive I’m thinking when the drive fails both copies are lost correct? or is backup just in case only a few sectors are damaged and the backups are automatically moved to a good sector while the original files are lost in the bad sectors?
Edit 2: To clairify these programs that are being duplicated are on the same date and time and channel. W7MC is set to only record new programs not new and reruns.
Edit 3: I'm not using the W7MC guide listings to set my recordings I use date,time and channel.
Any tips is appreciated STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 6 Old 06-13-2014, 01:33 AM - Thread Starter
Quoted: 108 Post(s)
Liked: 25
anyone w/ advice
post #3 of 6 Old 06-13-2014, 03:11 AM
Ken.F's Avatar
Quoted: 1497 Post(s)
Liked: 1279
If you have more than one Media Center computer on your network it might be showing you the recordings that are available to each computer as a separate recording. Try turning the other computer off and see if the duplicates go away. If that isn't the cause then it may be the external HDD making backup copies. I have no experience with that model HDD so I can't tell you how to check for that.
Ken.F is offline
post #4 of 6 Old 06-13-2014, 03:50 AM - Thread Starter
Quoted: 108 Post(s)
Liked: 25
I only have one PC turned on at a time. actualley I only use the HTPC w/ W7MC I use my lap top for internet stuff.
I have searched this issuse and only found issues w/ using the W7MC guide listing this does'nt apply to my dupicate issue because I'm manualley entering in my time date and channel.
edit: I have scanned the HDD w/ check disk HDD has no errors and is ready for use.
I have been using this drive for six months w/out any issuse's
here's a link for the elite
http://www.newegg.com/Product/Produc...82E16822136398
Thanks STB
post #5 of 6 Old 06-13-2014, 04:33 AM
Ken.F's Avatar
Liked: 1279
Ken.F is offline
post #6 of 6 Old 06-15-2014, 06:20 AM - Thread Starter
Quoted: 108 Post(s)
Liked: 25
anyone w/ the solution?
Reply Home Theater Computers
