Asrock Z87E-ITX Build - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 06-21-2014, 12:34 PM - Thread Starter
SteveMA's Avatar
Building a second HTPC:
1-Antec 300-150 chassis
2-Title MB
3-Intel Haswell i3-4130 CPU
4-GSkill Ripjaws 8GB
5-WD 2.5" 2TB HDD
6-Samsung 840 EVO 120GB SDD
7-picoPSU 160
First HTPC was Silverstone, Gigabyte MB, Samsung HDD, Samsung ODD, Intel i3 Sandy Bridge, etc. No issues, working nicely
With new build I have no video. Powers up (chassis light on, fans running) but no video thru HDMI or DVI. Using same Samsung monitor/TV as with first build. What, other than competence, might I be missing?
SteveMA
SteveMA is offline
post #2 of 14 Old 06-21-2014, 12:51 PM
Orange14's Avatar
Do you get the BIOS flash screen when it turns on? That should come up in the absence of any video driver loading. Also if you are using a TV make sure that you have it set to the right input (I've made that mistake before). Usually I always use a regular monitor to do the Windows installation and component checks before hooking it up to a TV.
Orange14 is offline
post #3 of 14 Old 06-21-2014, 01:27 PM - Thread Starter
SteveMA's Avatar
Nothing on the screen. Absolutely nothing. Actually I misspoke, the Samsung monitor I'm using is just a monitor (with one DVI and one HDMI input) and not a TV. The only indication I have is that the blue LED lights on the chassis and the fans are running. Also tried on a Samsung TV with HDMI only and again no video (not BIOS screen or anything else).
Still puzzled.
SteveMA
SteveMA is offline
post #4 of 14 Old 06-21-2014, 01:32 PM
baniels's Avatar
Quoted: 209 Post(s)
Liked: 318
Look in the Asrock manual for info on Dr Debug codes. There is a little 2-digit LED screen on the mobo that will flash various codes as it boots up. The codes represent various errors. Find out which code(s) it is throwing, then google or look in the manual.
FYI - it is digital clock font, so it can be confusing as to whether you are seeing a "6" or a "b", or "8" vs "B". If you can't find the code it is throwing, consider that you may be misreading it due to this.
I encountered a similar no-video problem with a build once. The codes set me in the right direction... Can't remember now - I was either underpowering the gpu or the mobo. Good luck!
baniels is offline
post #5 of 14 Old 06-21-2014, 01:54 PM
Orange14's Avatar
take the MoBo out of the case and connect only the SSD, RAM and PSU and see if you can get it to at least show the BIOS screen. this would rule out some kind of short that the case might be causing with the MoBo. I once had a problem with a Gigabyte board where the DVI port died right after Windows installation but the two HDMI ports worked. The fact that neither of your video outputs work indicates a MoBo problem but as noted above see if you get a debug code.
Orange14 is offline
post #6 of 14 Old 06-21-2014, 04:54 PM - Thread Starter
SteveMA's Avatar
I've looked over the MB and the manual (Z87e-itx) and I can't find any LED screen. There is no mention of Dr Debug or his codes anywhere that I can see in the manual. I see no blinking lights anywhere on the MB or back panel. Still puzzled!!
SteveMA
SteveMA is offline
post #7 of 14 Old 06-21-2014, 06:08 PM
baniels's Avatar
Quoted: 209 Post(s)
Liked: 318
Hmm. I assumed they had that on all of their boards. Any beeps? Orange is probably on the right track. Eliminate every component except the minimums he listed.
baniels is offline
post #8 of 14 Old 06-21-2014, 06:32 PM
fullhorn's Avatar
you might try putting a video card in to test and see if bios shows up on that
fullhorn is offline
post #9 of 14 Old 06-21-2014, 06:36 PM - Thread Starter
SteveMA's Avatar
I'll have to get one but if that's what it takes. This is a replacement board as the first gave no video either. Interestingly, the board lacks the "sticker" on which the BIOS version is/was listed (as it was on the 1st board from Newegg). Perhaps I should've stuck with Gigabyte (built a couple PC's with their boards, with no issues).
I'll see what a video card does. Thanks,
SteveMA
PS, I did take MB out of chassis per Orange14's suggestion. No video here either and for what its worth no beeps.
SteveMA is offline
post #10 of 14 Old 06-21-2014, 07:41 PM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
Make sure the power/reset switches are connected to the motherboard headers with the right "polarity". The manual tells you which pins are +/- I know it sounds absurd that the power/reset pins should cause this as they are just a momentary contact logic, but for some reason certain Asrock boards are sensitive to that. To me, it has always happened with Asrock boards only, no other boards.
No explanation as to why it works or doesn't work either. It just is. Can't hurt to try.
kapone is offline
post #11 of 14 Old 06-21-2014, 08:36 PM - Thread Starter
SteveMA's Avatar
I'll give it a look again. Pretty sure I had polarity right but it surely doesn't hurt to check again.
Edit:
I gave another look and I have the polarity for the power/reset correct.
SteveMA is offline
post #12 of 14 Old 06-22-2014, 10:03 AM
Orange14's Avatar
You could try clearing the CMOS and then see if it works (page 25 in the manual). I just checked the manual and you don't have any LEDs or MoBo debugging features here. Maybe a call to Asrock help is warranted since this is the 2nd board with the same problem. Who knows, maybe there is just a simple solution.
Orange14 is offline
post #13 of 14 Old 06-22-2014, 03:41 PM - Thread Starter
SteveMA's Avatar
I've sent a note to their customer service department. They don't seem to have a phone contact option. Weird!!
SteveMA
SteveMA is offline
post #14 of 14 Old 06-22-2014, 11:48 PM
politby's Avatar
Quoted: 76 Post(s)
Liked: 77
If you have fans running and board is powered up I would suspect the RAM. Does the mobo have a DRAM LED? It will light up red if the memory test fails.
You may have a bad stick of memory or maybe the mobo doesn't like this particular model of RAM.
Try with just one stick in all memory slots one after another and see if it boots.
Also, the pins in the Intel CPU sockets are incredibly sensitive to getting bent. All it needs is a dropped screw or fumble when seating the CPU and you will have bent pins. This can cause all kinds of weird symptoms, like making one memory channel inop. Happened to me twice.
The AMD sockets are much better.
politby is offline
Reply Home Theater Computers
