Hoping to setup WMC for Live TV. Questions about extenders/players.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-22-2014, 02:08 PM - Thread Starter
supahfly112's Avatar
Question Hoping to setup WMC for Live TV. Questions about extenders/players..
Hi guys and girls. There's a couple of spots on the forums that this may belong to so I'm hoping I'm posting this in the most relevant area.
I am looking to cut the cord. My plan is to get 1 or two HD Homerun duals and plug them into my Gbit router using OTA antenna. I already have a PC to be my WMC Host (Lenovo ThinkCentre M91p 5067A1U Desktop Computer Core i5 i5-2400S 2.5GHz). I am looking to either use the same PC or another device to be my media player. The part where I'm running into trouble is that I need this media player/PC to simultaneously broadcast the same audio to the TV via HDMI and to my Onkyo surround sound system via digital audio/SPDIF.
From everything I've read so far, windows 7 can not have two active audio devices so I can not just purchase an audio card with SPDIF to add to the PC without having to disable/enable devices every time I need to use an alternative device.
I've been looking into the xBox 360 but apparently those don't have digital audio out.
I currently have a Boxee box and WD Media player Live but neither of those are WMC extenders.
So this is where I am stuck. Any ideas or thoughts you can share would be greatly appreciated. Thank you.
supahfly112 is offline
post #2 of 12 Old 06-22-2014, 03:09 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
Xbox 360 does have optical out. You could also just run optical out from your TV to your AVR. Ceton Echo is another extender with optical out. Many ways to skin this cat.
mdavej is offline
post #3 of 12 Old 06-22-2014, 03:17 PM - Thread Starter
Thanks for the reply! I'm looking at XBox's on eBay. Enough though many don't have pictures of te back, the ones that do I don't see any optical ports. Also, as far as the optical out on the TV, Would that just work as a passthrough? If the tv itself doesn't have Dolby/DTS encoder, would it still pass the signal through? I should mention that I am not too familiar with the audio coding/decoding process. I'm also looking at the Ceton Echo. I've submitted a question on Amazon for it asking if it does simultaneous audio broadcast through HDMI and optical. I don't mind paying for it if that's what I gotta do. Thanks again!
post #4 of 12 Old 06-22-2014, 03:23 PM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
I don't believe the Echo will output over SPDIF and HDMI at the same time. I seem to recall it being either one or the other. Not sure about the 360.
Also, someone correct me if I'm wrong, but all you can pass over SPDIF is AC-3 and PCM, right? I don't think it will work with DTS.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is online now
post #5 of 12 Old 06-22-2014, 03:28 PM - Thread Starter
Thank you. At the same time, to add on that question, if I'm using HD Homerun dual with windows media center, is any of it really DTS? It may very not not be. Could be just Dolby digital audio which I think is the same as AC3...
post #6 of 12 Old 06-22-2014, 03:32 PM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
AFAIK all of the broadcast/cable/terrestrial/satellite standards use PCM or AC-3. So unless you're playing Bluray rips or something along that line, you shouldn't have to worry about DTS. If you're just sticking with Live/Recorded TV then you should be fine. With that said, I would try mdajej's suggestion of running HDMI to yout TV, then optical from your TV to your receiver.
That should be by far the easiest solution.
post #7 of 12 Old 06-22-2014, 03:33 PM
Toys7505's Avatar
Quoted: 69 Post(s)
Liked: 26
As to the Xbox question, if it is not a "Slim" version, the optical port is on the AV Cable you plug into the back of the 360.
Toys
Denon AVR-3311CI, Denon DVP-602CI, B&K Reference 200.7 S2, Belkin PF60
Sony BDP-S5000ES, Silverstone HTPC (6 Tuner DVR & 10 TB Media)
PSB Stratus Minis, PSB Stratus C6, PSB Alpha S surround, James Subwoofer EMB-1200
Sharp LC-70LE755U, Harmony 880 Remote
Toys7505 is offline
post #8 of 12 Old 06-22-2014, 07:57 PM
mdavej's Avatar
Liked: 940
My Sony TV passes DD5.1 bitstream from any input back out through its optical port. I ran that way for years before I got a new AVR with HDMI. Many, but not all recent TVs (within the past 5 years or so) will pass through at least DD5.1. Your AVR will decode it. Try it and see.
I have several Echoes, but I've never tried simultaneous HDMI and optical. I have no reason to think it wouldn't work. All my other devices output over optical and HDMI at the same time.
mdavej is offline
post #9 of 12 Old 06-22-2014, 11:19 PM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
I don't have an optical cable handy with which to test, but based on the Echo settings page it doesn't appear to offer a choice of both. That's not to say it doesn't work, but at the very least it doeasn't appear to.
post #10 of 12 Old 06-24-2014, 08:22 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I am using Linksys DMA2100 for dual output. Video/Audio to TV via HDMI, and additional Audio out of RCA in the back to a wireless headphone transmitter.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #11 of 12 Old 06-24-2014, 02:35 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 396
Xbox 360 does dual audio output via HDMI AND optical.
Foxbat121 is offline
post #12 of 12 Old 06-24-2014, 07:16 PM - Thread Starter
Thanks eeryone! I apprecaite your help. I'm going to try the xbox.
Reply Home Theater Computers
extender , spdif , windows media center , wmc , Xbox
