Intel HD4000-latest drivers only capable of interlaced output - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-25-2014, 03:01 PM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Question Intel HD4000-latest drivers only capable of interlaced output
I'm really at a loss on this one.
Windows 7 Enterprise 64bit SP-1 Intel i5-3570k/HD4000-ASUS P8Z77-V LK- HDMI
XBMC Gotham 13.0
Recently upgraded to the Intel drivers-15.33.22.3621- and am now unable to set the resolution to 1080p/60.
Change settings/system/video output/resolution to 1080p system resolution changes to 1080i/59.
If I change the resolution using Intel or Windows interface all I get no output signal and black screen.
Prior to the firmware update this was not an issue. I uninstalled and re-installed the drivers but am having the same issue. Nothing else has changed but the Intel drivers.
Any direction on this would be greatly appreciated.
trans_lux is offline
post #2 of 5 Old 06-26-2014, 12:39 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Uninstall the driver, clean the registry, e.g. with Driver Cleaner, $10, then re-install the driver.
renethx is offline
post #3 of 5 Old 06-28-2014, 02:35 AM
uncola's Avatar
Quoted: 43 Post(s)
Liked: 37
You could also try using this display driver uninstaller.. hopefully not stepping on your toes renethx you helped me build my htpc in the past you rock :P
https://forums.geforce.com/default/t...sed-06-18-14-/
Gear list: Main setup - Kef Q900, Svs sb12-nsd subwoofer, onkyo 609 receiver, epson 8350 projector, elitescreens sable 92" screen, mac mini htpc
Bedroom setup: Philharmonic Audio New Philharmonitors, Odyssey Kismet Monoblocks, Soekris Dac, Hattor active preamp
uncola is offline
post #4 of 5 Old 06-30-2014, 10:18 AM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
Thanks for the suggestions.
Not sure what actually solved the issue.
I think it may have been that I installed the drivers over VNC.
Uninstalled drivers, rebooted, re-installed drivers. Desktop res was fine but XBMC was still 1080p/50.
Closed XBMC, desktop res was still at 1080p/60, opened XBMC and it was @ 1080p/60??
post #5 of 5 Old 07-13-2014, 09:01 AM - Thread Starter
trans_lux's Avatar
Quoted: 119 Post(s)
Liked: 164
What the heck-the issue is back.
Desktop set at 1080p/60, XBMC set to 1080p/60 but 1080p plays back at 1080p/50.
1080p/24 plays fine as do other components playing the same content.
This is driving me nuts!
Reply Home Theater Computers
