Question - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Dark_Slayer
post #1 of 7 Old 06-25-2014, 06:58 PM - Thread Starter
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
Question
Which motherboards have the best onboard audio chip and which CPU is the best for video transcoding?? Time to putter with another build....
vcrpro3 is offline
post #2 of 7 Old 06-25-2014, 07:16 PM
Aleron Ives's Avatar
Quoted: 1678 Post(s)
Liked: 1437
If you want to use x264 to make high quality rips, the number of cores you have is important, so either a 6-core i7 or a Xeon-series server CPU with 8+ cores will give you the best performance. If you only want to transcode on-the-fly for viewing videos on a tablet or other device, any Intel Core CPU with a QuickSync hardware encoder will let you do that without using any CPU resources.
Aleron Ives is offline
post #3 of 7 Old 06-25-2014, 07:21 PM
ajhieb's Avatar
Quoted: 1032 Post(s)
Liked: 691
Actually, you brought up a point I've been meaning to ask about on here...
If you're maintaining a digital signal path (bitstreaming, sending PCM or even AC-3) does the audio chip even matter? I guess you'd need a chip capable of bitstreaming whatever it is your files are encoded in (DTS-MA or whatever) but beyond that, does it matter? Also, if you're using a graphics card (instead of integrated video) and your sound is output via HDMI is the anything on the motherboard even being utilized for sound? It's all on the graphics card, isn't it?
(Sorry, don't mean to hijack your thread, but I think the answers to my questions are also relevant to yours)
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is offline
post #4 of 7 Old 06-25-2014, 09:34 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Ivy Bridge-EP (such as Xeon E5-2697 v2, 12C/24T 2.7--3.5GHz 130W LGA 2011, $2,614) is the best right now. Haswell-E/EP will be available later this year. If you want a normal, desktop-like processor, Core i7-4790K (4C/8T, 4.0GHz-4.4GHz LGA 1150, $339) is a good choice.
Realtek ALC1150 is the current best onboard audio chip. I assume you want good 'analog' output. Then you'd better add a discrete sound card.
renethx is offline
post #5 of 7 Old 06-26-2014, 01:44 PM
Dark_Slayer's Avatar
Quoted: 722 Post(s)
Liked: 451
Audio decoding is done in the PCH for HDMI audio, and no the on-board audio chip (usually realtek) does not matter in that case
Onboard is applicable when you change your default sound device in windows to something other than intel hd audio
ajhieb likes this.
Dark_Slayer is offline
post #6 of 7 Old 06-26-2014, 01:55 PM
ajhieb's Avatar
Liked: 691
Thanks for the info!
ajhieb is offline
post #7 of 7 Old 06-26-2014, 05:08 PM - Thread Starter
vcrpro3's Avatar
Quoted: 107 Post(s)
Liked: 25
In my case, i am wanting to make a box that will be a kinda/sorta substitute for an AV receiver I am planning on sending analog audio directly to a Marantz 5ch power amp.This brings up another question as that i can control output levels with a media center remote and programs that support it, but would also like to have a manual volume control on the case.
vcrpro3 is offline
Reply Home Theater Computers
