XBMC/FlexRAID - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-07-2014, 05:27 PM - Thread Starter
bkinder83's Avatar
Quoted: 13 Post(s)
XBMC/FlexRAID
I've been noticing that I get an error during a Validate task on my FlexRAID array on the last movie I've watched in XBMC. The error is "HANDLE_VALUE error=32". Does XBMC keep the file open on my HTPC after completion?
Thanks for any help.
bkinder83 is offline
post #2 of 9 Old 07-07-2014, 05:33 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2681
probably edits the file while the update or process is running. If you modify an existing file it will throw an error. I wouldn't worry about it. The file probably changed slightly (like watched status changed or edited)
Mfusick is offline
post #3 of 9 Old 07-07-2014, 05:46 PM - Thread Starter
bkinder83's Avatar
Quoted: 13 Post(s)
Thanks for the response. Does the Validate task kick out if it receives an error? I wouldn't want it to miss an unknown amount of files. Also, would you think it could be something different if I mentioned that I do an Update nightly including one prior to the Validate?
post #4 of 9 Old 07-07-2014, 06:30 PM
rc05's Avatar
Quoted: 151 Post(s)
Liked: 87
I get tons of these errors, but it doesn't seem to affect Validate/Verify/Update. I should probably check to make sure it Restores correctly though...
rc05 is online now
post #5 of 9 Old 07-07-2014, 09:15 PM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2681
No the process completes but if you did a restore probably the watched status on that one would be unmatched instead of watched.
Mfusick is offline
post #6 of 9 Old 07-08-2014, 01:29 AM
Dark_Slayer's Avatar
Quoted: 650 Post(s)
Liked: 429
What scraper are you using? Local metadata only puts a lot of stress on flexraid's update/validate/verify, but the imdb/tmdb scrapers build a library cache on your C: drive which should be excluded from your array
Dark_Slayer is offline
post #7 of 9 Old 07-08-2014, 10:21 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2681
Yeah you can set PLEX or MediaBrowser to also store stuff outside the movie folder or on another drive (like SSD)
But honestly I would not worry about it. I chased those problems before and as long as the server is idle next time (like middle of the night) it will complete successfully. The error doesn't mean your entire flexraid array is bad either- it just means that one file. If you restored you'd be ok anyways. This is just the problem with snapshot raid, it's a snapshot. Anything that adds or deletes won't mess anything up, but files that change and still exist will throw an error. Only way around it is to not use the server during the process (or run the process again when you are done using it) or convert to a real time raid solution.
Mfusick is offline
post #8 of 9 Old 07-09-2014, 08:26 AM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
You should have an Update scheduled to run right before the Validate.... in case you don't already.
techmattr is offline
post #9 of 9 Old 07-09-2014, 09:30 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2681
I do update and then validate- otherwise it's pointless.
Mfusick is offline
Reply Home Theater Computers
