Copying Prohibited message after upgrade to Win 7 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-07-2014, 07:21 PM - Thread Starter
rgc101's Avatar
Hi - I think I know the answer to this, but I hope I am wrong. I have an old dell xps420 with vista and an ati digital cable tuner. great library of movies recorded off of premium tv that my family and I have enjoyed for years. We recently had a power outage which fried vista on my machine (BSOD). Only option was to reinstall vista from the original disk which went fine until it tried to update. kept hanging at the reboot, and could not update at all. After trying several solutions and being frustrated with vista for years, i decided to upgrade to win 7. That went well at first. Got the tuner working with premiums. When I went to play the recorded shows I already had, I got the Copying prohibited message, event though no hardware changes. I tried to rename the DRM folder. That didnt work. Does anyone know of a solution or are all of those shows toast?
Thanks for your help.
rgc101 is offline
post #2 of 9 Old 07-07-2014, 09:21 PM
gtgray's Avatar
Quoted: 226 Post(s)
Liked: 146
My guess is that the DRM needs to be reset.. which will likely make your recordings unusable.
Samsung 78" JS8600, Mits WD-92840 43" Samsung 43ku7000 - Lumagen Radiance XS, Martin Logan Motion 40s, Ascend Sierra 2s
58" Panny Plasma -DVDO DUO, Usher S520, JBL HLS-610, Definitive SM45, MusicHall Marimba
gtgray is offline
post #3 of 9 Old 07-08-2014, 08:45 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
If they are flagged "Copy Once" they can only be played back on the original hardware and software configuration. Reinstalling same version of windows on the same machine breaks the DRM.
Your recordings are mostly toast. I think you have a legitimate case of going to the torrents to replace your legally obtained recordings that are now unuseable.
Resetting PlayReady won't do a thing.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #4 of 9 Old 07-08-2014, 09:03 AM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
I think you mean "Copy Once". If it was "Copy Never", it wouldn't be able to be recorded in the first place.
But they're right, your recordings are gone
rc05 is offline
post #5 of 9 Old 07-08-2014, 12:21 PM - Thread Starter
rgc101's Avatar
How about if I go back to original Vista install and try that again with OEM disk? Think that will work?
rgc101 is offline
post #6 of 9 Old 07-08-2014, 01:02 PM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 416
No. The DRM will be reset anytime you reinstall OS, OEM disc or not. Your recorded premium shows are as good as dead files occupying your HDD.
Foxbat121 is online now
post #7 of 9 Old 07-08-2014, 02:01 PM - Thread Starter
rgc101's Avatar
Ok. Thanks. So it was really dead from the start even if I had successfully reinstalled the OS from the OEM disk that I got with the computer. If that is the case I don't feel as bad since it was due to a power failure and completely out of my control. Time to start rebuilding the library...
rgc101 is offline
post #8 of 9 Old 07-08-2014, 03:14 PM
VideoJames's Avatar
Quoted: 12 Post(s)
Well, if you have a backup made using a system image type of daily backup, you could use that to reinstall.
But the DRM used on the recorded TV may have updated itself since your last backup, so there is a chance it could be too old to work.
VideoJames is offline
post #9 of 9 Old 07-09-2014, 08:40 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Yes, you are right, I meant "Copy Once"
Reply Home Theater Computers
