Perfect Player is free IPTV/Media player, advanced channels manager and playlist generator for XBMC (IPTV-Simple).
NEW Android Perfect Player version is available for download
Features:
- Advanced full-featured IPTV/Media player with OSD and the ability to control playing in Fullscreen
- Video plug-ins supported (ex.ua plug-in bundled)
- Multilanguage support (English, Russian, Spanish, Ukrainian)
- Scalable OSD - video and OSD menus renders correctly with any window size and resolution
- The program monitors all your installed logos, EPG, channels groups, and other settings of channels that will not get lost after updating provider's playlists
- Playlists formats supported: M3U, XSPF (UDP, HTTP, HTTP-UDP-proxy, TORRENT-TV.RU)
- udpxy support (watching, scanning, playlist generating)
- EPG formats supported: XMTLV and JTV
- Setting logos (with preview), program guide (EPG) (manual and auto mapping)
- Working with multiple providers playlists and program guides (EPGs) at the same time
- Channels checking (scanning signal, presence or missing in the list of provider) - in the absence of signal channel are labeled as no signal and excluded from the final playlist until signal appears again; lost channels are marked as lost before they occur or, if desired, can be removed from the final playlist
- Setting radio channels, the time zone (for correct EPG showing)
- Managing channels groups (add, edit, remove groups)
- Rename, hide/show channels
- Channels sorting (by name, by group, within the selected group, move grouped channels to top, move hidden channels to bottom, set provider's ordering)
- Fully compatible automatic playlist generating for the IPTV-Simple addon (XBMC playlist)
Installation:
- Download and install PerfectPlayer-x.x.x.exe
Upgrade:
To guaranteed save all program and channels settings:
- Before installing save the settings in a separate file (Save settings)
- After the upgrade, restore settings (Restore settings)
Initial settings:
- Add Provider's playlist URLs
- Add EPG URLs
In the Properties specify:
- Logos directory
If necessary generate a playlist for XBMC specify:
- The resulting playlist file for XBMC (XBMC playlist)
- File in which final EPG will be written (XBMC EPG XMLTV file) - with the extension .gz (!)
In IPTV-Simple:
- Set to use a local playlist file (the same as XBMC playlist)
- Set to use a local EPG file (the same as XBMC EPG XMLTV file)
- Set the folder with logos (the same as the Logos directory)
Screenshots (v1.0.0 with russian GUI language selected):
Proposals and suggestions are welcome! Please, feedback...
Features:
Installation:
Upgrade:
Initial settings:
- Add EPG URLs
- Logos directory
In IPTV-Simple:
