Intel new x99 chipset ? When? Details ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-11-2014, 07:18 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
Have they officially set a launch date yet ? Or announced specifics?
When does devils canyon hit ? I'm debating between these to upgrade my 4770k/z87 desktop. Thoughts?
Mfusick is offline
post #2 of 8 Old 07-11-2014, 08:25 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
September 14 (rumor).
Core i7 5960X: 8C/16T, 3.0GHz/3.5GHz, PCIe Gen.3.0 40 lanes (2x16 + 1x8), 4ch DDR4-2133, 140W
Core i7 5930K: 6C/12T, 3.5GHz/3.7GHz, PCIe Gen.3.0 40 lanes (2x16 + 1x8), 4ch DDR4-2133, 140W
Core i7 5820K: 6C/12T, 3.3GHz/3.6GHz, PCIe Gen.3.0 28 lanes (1x16 + 1x8 + 1x4), 4ch DDR4-2133, 140W
X99 supports 6 x USB 3.0, 10 x SATA 6bps (and M.2, SATA Express).
renethx is offline
post #3 of 8 Old 07-11-2014, 10:32 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
Devil's Canyon has been out for over a month.
For Haswell-E/X99 September is about as official as a rumor gets since documents were leaked last month with the release schedules. They'll probably find a way to delay it again though even though samples have been all over for months now.
Are you seriously considering a Haswell E setup? You're talking well over $1500 for a CPU/Motherboard/RAM that isn't going to do anything for you that your 4770K doesn't already do...
techmattr is offline
post #4 of 8 Old 07-12-2014, 09:12 AM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I am not sure. I don't have enough data to seriously consider the upgrade yet. That is why I asked.
Mfusick is offline
post #5 of 8 Old 07-12-2014, 11:01 AM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
Unless you plan on doing some serious encoding a 3570K would last you until it dies. If all you're looking for is expanding storage then any system upgrade (especially the x99 route) is just overkill. The easiest solution is obviously just find a board that supports another 9211-8i if your current board won't. If you're going to go overkill though.... you might as well skill Devil's Canyon and go straight for the big guns with Haswell E.
post #6 of 8 Old 07-13-2014, 02:33 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
I have a 3570k in my htpc, a 2600k in my server, and a 4770k in my desktop so perhaps you are right.
Mfusick is offline
post #7 of 8 Old 07-13-2014, 04:23 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
Yeah I mean you can certainly go overkill if you want. And it WILL make things easier. But there are obviously much more cost effective ways to get to your end goal that won't hinder your experience. You certainly don't need the extra horsepower.
Dropping $1500 on a X99 platform you're just going to build it and then ask yourself... what the hell does this do that I couldn't do before? Aside from plugging more drives directly into the board.
post #8 of 8 Old 07-13-2014, 05:40 PM - Thread Starter
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
*want
I need to control that.
Mfusick is offline
Reply Home Theater Computers
