AMD R7 250 vs nVidia GTX 750 - madVR - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By renethx
  • 1 Post By renethx
post #1 of 9 Old 07-12-2014, 04:19 PM - Thread Starter
pubare's Avatar
Title says it pretty well... I am looking for a replacement card for madVR performance ONLY (no gaming) and am not willing to use anything that uses greater than 65W of power (thermal / noise / space considerations). Which pretty much means the R7 250 or GTX 750 series. Which one typically does better with madVR performance? Primary use is 720P DVD / 1080P BluRay rips (handbrake CQ = 18) to mkv. CPU is Intel i5-4570 with HM-87 motherboard, 8GB low-latency RAM.
pubare is offline
post #2 of 9 Old 07-12-2014, 04:32 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
Pretty sure @renethx and @MlNDBOMB could answer that off the top of their head.
techmattr is offline
post #3 of 9 Old 07-12-2014, 09:20 PM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
I tested only R7 250X vs. GTX 750 Ti. They are almost equivalent in madVR performance.
R7 250: 384sp
R7 250X: 640sp
GTX 750: 512sp
GTX 750 Ti: 640sp
So obviously GTX 750 is better than R7 250.
pubare likes this.
renethx is offline
post #4 of 9 Old 07-13-2014, 01:17 AM
Dark_Slayer's Avatar
Quoted: 729 Post(s)
Liked: 452
R7 250: 384sp
R7 250X: 640sp
GTX 750: 512sp
GTX 750 Ti: 640sp
What about all this then?
AMD does MadVR a little better because of how they handle OPEN CL
Not "a little better" but "twice better".
In a brief search I did just now, I see both the 750 Ti (MSI) and 260X (MSI) for about $100 AR (though the techbargains link for the 750Ti has an additional savings code)
Both 2GB
How much difference is there between the 250X 2GB and 260X 2GB (they seem to be priced about the same)
Dark_Slayer is offline
post #5 of 9 Old 07-13-2014, 02:06 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
GTX 750 Ti is equivalent to R7 260X (1971 GFLOPS) in pure shader unit performance (as seen in various gaming benchmarks). But because of poor OpenCL support, it's only equivalent to R7 250X (1280 GFLOPS) in madVR NNEDI3.
260X vs. 250X = 1971 vs. 1280.
Dark_Slayer likes this.
renethx is offline
post #6 of 9 Old 07-14-2014, 06:48 AM
pylor's Avatar
Quoted: 27 Post(s)
I don't think you'll be able to do NNEDI3 image doubling from the 720p material with either of those (I could be wrong), which is the new "standard" for madvr, atleast from what I've read/seen. I have a 270x and can only do 32 neurons image doubling for 720p material.
pylor is offline
post #7 of 9 Old 07-14-2014, 07:31 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Rendering time per frame to upscale 1280x720 to 2560x1440 (x2) by NNEDI3 neurons 32, then downscale to 1920x1080 (x0.75) by CRARLL (BC75AR for chroma upscaling) is (according to my own test)
- R7 250X: ~29ms
- R7 260X: ~19ms
- R7 270X: ~15ms (all with 13.12 driver)
- GTX 750 Ti: ~28ms
All of them are enough shorter than 41.8ms = 1/(23.976Hz), but not enough shorter than 16.7ms = 1/(59.94Hz). In other words, every card above can upscale 720p24 to 1080p by N32 without dropped frames, but every card will have to drop frames to upscale 720p60 to 1080p.
Comparing GTX 750: 512sp vs. GTX 750 Ti: 640sp, I can assure GTX 750 is fast enough to upscale 720p24 to 1080p by N32.
On the other hand, R7 250: 384sp vs. R7 250X: 640sp, so R7 250 can't upscale 720p24 by N32. If you reduce neurons to 16, then
- R7 250X: 23.3ms (again my own test)
- R7 250: 38.8ms = 23.3ms x (640)/(384)
so that R7 250 can barely upscale 720p24 to 1080p by N16. Using 13.12 driver is critical in this case.
renethx is offline
post #8 of 9 Old 07-14-2014, 07:52 AM
danbez's Avatar
Quoted: 39 Post(s)
- R7 250X: ~29ms
- R7 260X: ~19ms
- GTX 750 Ti: ~28ms
Renethx comments are my main source of education those days :-)
One follow up question - do you see any difference between 16 and 32 neurons when watching movies? I have it set for 16 today (that's all my card can afford - GTX650), and I wonder if I should upgrade the GPU just to get more neurons (film only, 720p and DVD -> 1080).
danbez is offline
post #9 of 9 Old 07-14-2014, 08:09 AM
renethx's Avatar
Quoted: 246 Post(s)
Liked: 402
Generally I see less artifacts with 32 neurons than 16 for DVD upscaling. This depends on the scenes, of course. As for 720p, the difference between 16 and 32 tends to be even smaller.
renethx is offline
Reply Home Theater Computers
