Ceton InfiniTV 6 ETH ..... personal experience please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 45 Old 07-13-2014, 03:48 AM - Thread Starter
Quoted: 123 Post(s)
Does anyone have any personal experience with Ceton InfiniTV 6 ETH? I am considering adding this to my Media Center System.
If you have other considerations that you think are better just let me know please and keep them within my desires please. No sense in pointing me to something I don't want.
I wanted six channels minimum.
My system is setup with my old Desktop as my MediaCenter Server and my HTPC accesses it via a Cat-5 Connection to my Router. Once I return to the United States from Korea(Military) we are going to build a second HTPC for the Bedroom (Or a 4k HTPC for the living room and the current one will go in the bedroom.) What I want is the Old Desktop, my Media Center, to have all the shows recorded onto that PC. I want to be able to watch all television and recordings from my HTPCS within the house.
Leon1972 is offline
post #2 of 45 Old 07-13-2014, 06:32 AM
Arative's Avatar
Quoted: 44 Post(s)
Liked: 41
I'm using the eth6. Works fairly good. Every once in a while I get some quirky issues. Like a channel will say subscription required. Then I have to press stop and go to that channel again.
As far as recording on one and watching on another. That will work as long as the channel is copy freely. If it is flagged copy once, like all pay channels, you won't be able to watch it on another htpc. You might look into using extenders if that is functionality you want.
Arative is offline
post #3 of 45 Old 07-13-2014, 07:24 AM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 53
Ceton InfiniTV 6 Thread here
Make sure you get the latest Ceton Software/Firmware
Make sure your PC network card and Router is Gigabit. In fact, it's best to use a Gigabit switch and plug ETH6, extenders, and PC into it. Then connect the switch to the router.
Keep an eye on the ETH6 temperature- set it up vertical and put a small fan on it.
Verify the Tuners signal levels. For best results needs to be within +6dBmV to -6dBmV
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #4 of 45 Old 07-13-2014, 07:29 AM - Thread Starter
Quoted: 123 Post(s)
WHy would i need an extender? From what I have read on their website so long as a channel is open it can be used on a different device. I can watch on six computers at once from what their website said. this is why i thought i would be good for setting up all recordings on on pc and then they could all access the same pc for the recordings
Leon1972 is offline
post #5 of 45 Old 07-13-2014, 07:35 AM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 53
I think that's called Tuner Pooling. I never tried it.
post #6 of 45 Old 07-13-2014, 07:37 AM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
If a show is flagged copy-once, it can only be watched on the PC that recorded it. It cannot be watched on another PC. This limitation doesn't exist if you use an extender, like an XBox360.
This doesn't matter for unrecorded live TV. You should be able to view live TV channels using any PC on the network.
dfkimbro is offline
post #7 of 45 Old 07-13-2014, 07:43 AM
Arative's Avatar
Quoted: 44 Post(s)
Liked: 41
I have a set up similar to what you want. I have a main HTPC that records everything and one in my bedroom that I can watch recorded shows on, as long it is copy freely. I only brought up extenders if you want to be able to have a central recording device with channels that are copy once. It really depends on the cable provider. I have charter and only the pay channels like HBO are copy once.
Arative is offline
post #8 of 45 Old 07-13-2014, 07:48 AM - Thread Starter
Quoted: 123 Post(s)
Does just mynetwork card and router need to be gigabit? wouldnt a gigabit internet plan be more expensive than just getting a dvr from the cable company? that is the main reason the wifey and i are looking at this route. we will most likely be going with comcast and they want 30 bucks a month for the dvrs and only 2bucks a month for the cablecard. but if i need to upgrade my internet plan that high that is expensive, isnt it?
Leon1972 is offline
post #9 of 45 Old 07-13-2014, 07:50 AM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 53
Internet (WAN) speed has nothing to do with your LAN speed.
Just your internal devices need to be gigabit- network cards, switches.
ISP modem/router is not relevant, as long as you connect everything to a gigabit switch.
post #10 of 45 Old 07-13-2014, 07:54 AM - Thread Starter
Quoted: 123 Post(s)
why would i need the switch then? I could see if im connecting tons of devices but what if its only three computers?
Can anyone make any switch recomendations? Dont know if the wifey is gonna go for this anymore. kinda hard pressed as it is considering the cost of a second htpc and the CableCard device already. lol
So does anyone have a link to a good place to start looking into how all this works together? The networking side I mean. I have a VERY basic understanding of it all and it seems that I may need to learn more.
Were talking I have 2 computer and an atv 2 networked into my router for plex currently. lol
Leon1972 is offline
post #11 of 45 Old 07-13-2014, 08:03 AM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 53
Are the LAN ports on your router gigabit?
It works better using a switch because the router is spending lots of time doing "internet duty". Using a switch ensures the massive amounts of tuner streaming doesn't have to be done by a "busy" router.
I have used this switch for over a year: TrendNet Gigabit Switch $30
post #12 of 45 Old 07-13-2014, 08:05 AM - Thread Starter
Quoted: 123 Post(s)
ok so that i get but if my internet is only 25 mbps (Im figuring i would have to increase that to a 100mbps connection) then how can such a large capacity switch increase it? wouldnt that create a bottleneck because i have such a small data connection? wouldnt the 100mbps router ports create the same bottleneck?
Leon1972 is offline
post #13 of 45 Old 07-13-2014, 08:12 AM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
The 6 ETH also requires a hard wire Ethernet connection http://cetoncorp.com/products/infinitv-6-ethernet/.
If you buy your own router instead of renting a modem/router combo one from the cable co., it will probably have 4 ports (one for each computer, and one for the Ceton InfiniTV 6 ETH). You can use those ports instead of a switch if they are the only devices you want to hard wire. Make sure you get one with gigabit ports. If you want to hard wire anything else via Ethernet (printer, smart TV OR blu ray, AVR, Wii, PS3, XBox, etc.) you'll need a switch since you'll quickly run out of ports on the router. A hard wired connection will always be faster and more stable than WiFi, especially for streaming video.
I found www.smallnetbuilder.com to be helpful. Or google home network. Lots of how to guides out there.
I found that I could get business class unmanaged Netgear switched for about the same price as their consumer switches...small 5-port gigabit switch for $32.18 http://www.amazon.com/NETGEAR-ProSaf...Netgear+switch.
dfkimbro is offline
post #14 of 45 Old 07-13-2014, 08:16 AM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
No. Internet sped has nothing to do with the network speed. Internet is WAN (wide area network). Internal is LAN (local area network). WAN speed is your download speed. LAN speed is how fast you can transfer data from one device (6ETH) to another (PC) within the walls of your house. Internet speed doesn't affect sending video over your LAN. You aren't getting the tv signal over the internet. You're using the cable company's digital tv signal via coax and then transferring it from the 6ETH to a PC over Ethernet (LAN).
dfkimbro is offline
post #15 of 45 Old 07-13-2014, 08:18 AM - Thread Starter
Quoted: 123 Post(s)
I do have a router already. I have 5 open ports. I think its gigabit but I would have to check.
WHat I am picturing is if i only have a 25 (or 100mbps connection ill have to upgrade to probably) MB connection then I will only have 25mbps total going to each of my channels, regarles of if it is a 100mbps or gigabit switch, correct?
Leon1972 is offline
post #16 of 45 Old 07-13-2014, 08:20 AM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
Not correct. That's just your download speed, and doesn't affect the transfer speed from one PC (or Ethernet tuner) to another.
If your downloading a file from the internet, then yes, the download speed will be limited to 25 Mbps. If your moving files around from one PC to another then the limit is the router or switch (100 Mbps for "fast Ethernet" or 1000 gbps for gigabit Ethernet).
dfkimbro is offline
post #17 of 45 Old 07-13-2014, 08:21 AM - Thread Starter
Quoted: 123 Post(s)
ok. NOW i get it. lol. the name decieved me. i thought the ETH stood for ethernet. it was a confusion in the name of the product. FYI, my limited skills do afford me the knowledge of what a lan, wan, man is. just not the big configuration. lol
Leon1972 is offline
post #18 of 45 Old 07-13-2014, 08:22 AM - Thread Starter
Quoted: 123 Post(s)
So the GIGABIT recomendation is not for the Internet. Its for my networks LAN. I get it now. Thanks!!!!
I got caught up with the eth in the name connecting to the internet.
Leon1972 is offline
post #19 of 45 Old 07-13-2014, 08:26 AM - Thread Starter
Quoted: 123 Post(s)
So they would be connected with eachother and internet and the router would only have one port used. the router would ONLY be used when accesing internet through that one connection.
Router -------------S
HTPC---------------W
HTPC---------------I
ATV----------------T
C
H
Leon1972 is offline
post #20 of 45 Old 07-13-2014, 08:28 AM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
Well, you almost got it right!
ETH does mean indeed ethernet. That's how it connects to your network. Where you went wrong is that Ethernet doesn't mean internet. It means the communications protocol and hardware.
The alternative to the ETH products from Ceton are internal cards that plug into the motherboard and are for a single PC (they can be shared, but that's beside the point). Think of the ETH as a stand alone TV tuner that's a network "resource" like a shared printer that's plugged into your router, and isn't dedicated to a single PC.
dfkimbro is offline
post #21 of 45 Old 07-13-2014, 08:34 AM - Thread Starter
Quoted: 123 Post(s)
I dont want the heat internal and I like the idea of it being network dependent. not computer dependent.
Leon1972 is offline
post #22 of 45 Old 07-13-2014, 08:37 AM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
C
H
Something like that, yes. Think of the switch as a port-multiplier for the router. It adds ethernet ports and takes some of the switching load off the router so it can better route internet traffic, as mentioned before. Get an unmanaged switch with more ports than you think you'll need, because you'll find a use for them.
dfkimbro is offline
post #23 of 45 Old 07-13-2014, 08:38 AM - Thread Starter
Quoted: 123 Post(s)
is the purpose of a dual ethernet mobo one for the lan and one for the internet?
Leon1972 is offline
post #24 of 45 Old 07-13-2014, 08:45 AM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
That's one use, yes. They can also be "teamed" which increases throughput. Multiple NICs (network interface controllers aka Ethernet cards or ports) can also be used for specific purposes that are beyond what you're wanting to do.
For basic internet browsing, HTPC use, and file sharing between PCs, dual NICs aren't needed. This would add multiple layers of complexity and really takes networking to another level.
dfkimbro is offline
post #25 of 45 Old 07-13-2014, 08:46 AM - Thread Starter
Quoted: 123 Post(s)
My wife and I are also considering just getting one of the media extenders and using my old paperweight ps3 instead of a second HTPC build. Would I still get same 1080p quality out of it as i would a second htpc? I would like to hold off on pulling the trigger on a second HTPC till we get our 4k TV and then build one around that instead of using first gen 4k hardware if it would still be good quality with the ps3.
Leon1972 is offline
post #26 of 45 Old 07-13-2014, 08:47 AM - Thread Starter
Quoted: 123 Post(s)
Thanks. GOod to know. If I end up upgrading my Server PC then I will have to keep that in mind and make sure it gets two. of course the non-workhorse htpc has two. lol.
Leon1972 is offline
post #27 of 45 Old 07-13-2014, 08:55 AM - Thread Starter
Quoted: 123 Post(s)
and hey, what do you know!!!! My router is rated in the top routers off your website link. Guess it is a gigabit.
HOw do i know if my equip is DHCP?
Leon1972 is offline
post #28 of 45 Old 07-13-2014, 09:07 AM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
Which router (make/model)? How old is it?
It's DHCP. That how it assigns the addresses to your PCs. I doubt you can buy a consumer router that doesn't have DHCP function.
dfkimbro is offline
post #29 of 45 Old 07-13-2014, 09:14 AM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
By the way...THANK YOU for your service to our country!
dfkimbro is offline
post #30 of 45 Old 07-13-2014, 09:34 AM - Thread Starter
Quoted: 123 Post(s)
It's a net gear 6250
And thank you. No it's hdcp. It said hdcp compliant graphics card or inboard graphics.
Leon1972 is offline
Reply Home Theater Computers
