New Fan Needed, have no clue! pls help! - AVS Forum | Home Theater Discussions And Reviews
Old 07-14-2014, 11:34 PM - Thread Starter
Liked: 0
Hi Guys,
I have a Windows 8 HTPC, im not 100% sure what type of pc it is but it keeps overheating. I've tried the local PC guy (wasnt very helpful).
Any help would be appreciated. If more info is needed please tell me....
Name:	photo 2 (1).JPG
ID:	161713   Click image for larger version
Name:	photo 1 (1).JPG
Menadool is offline
Old 07-15-2014, 12:17 AM
Dark_Slayer's Avatar
Quoted: 656 Post(s)
Liked: 434
Looks like the fan was running in the picture you took, or no?
If the fan still works at all, then you are probably experiencing an unseated cooler. You'll need to take it apart, pull the cooler off, clean the bottom with alcohol, carefully remove the cpu, clean it's metal lid housing with alcohol, let both parts dry, apply new thermal paste, then put everything back together
If the fan does not work at all, then we'll probably need to see a shot of the board were the name is printed on it. Removing the cooler (which you'll need to do anyway if it isn't working) will help since you should be able to get a shot of the processor if you don't already know which one it is
If it works for a short period before overheating, go to Control Panel -> System and then post up the CPU type and RAM specs. That along with the brand will typically identify everything
Dark_Slayer is online now
Old 07-15-2014, 10:26 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
How do you know you need a new fan?
Where is the PC located? Is it in a closed cabinet with no influx of fresh cool air? Are there other heat generating equipment?
There is a lot more to PC cooling than just a fan. You can put a big ass fan on it, but if the ambient air is hot, it won't help you much.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
