Fanless 750/750TI!
1K views 11 replies 3 participants last post by  morganf
#1 ·
Palit has announced fanless versions of the 750 card called "KalmX" and these should be perfect for HTPC use though the next-gen Maxwell right around the corner will include more HTPC improvements and new codec support along with HDMI 2.0.
#4 ·
In response, ASUS has dropped their own over-clocked 750TI with semi-passive cooling under their Strix product line. It is a superior card in every way due to it's clock-speeds and DisplayPort instead of VGA, except that it only goes completely silent when certain criteria are met though it's billed as being pretty quiet to begin with, so it may not matter. It's definitely the card you want to get if you think a 750 TI is ideal for your media playback AND you want more power for gaming.
