can I splice two cooling fans wires together - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By stevethebrain
  • 1 Post By captain_video
Old 07-16-2014, 08:16 AM - Thread Starter
stevethebrain's Avatar
Quoted: 105 Post(s)
Liked: 25
can I splice two cooling fans wires together then plug into one three pin connecter?
I'm trying to install two intake cooling fans in my new case however I only have one three pin connecter on the front of case.
I actualley order a Y-adaptor was planning on having two exhaust fans however this is a four pin connecter it would probablley be easier to splice the two fans together if this is OK to do.
Thanks STB
bryansj likes this.
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
Old 07-16-2014, 10:28 AM
pkscout's Avatar
If you're comfortable working with the relatively thin wires, then you're probably fine. I'd make very sure that you properly cover the bare wire, or you could short out your motherboard if something touches where it isn't suppose to.
Why not just get (or wait for) the Y connector though?
pkscout is offline
Old 07-16-2014, 10:54 AM
EricN's Avatar
Quoted: 154 Post(s)
Liked: 240
Don't splice the 4th pin. (and pkscout makes a good point...your pc will survive without a second intake fan for a few days)
http://www.formfactors.org/developer...e_PWM_Spec.pdf
Look at § 4.1.6 Fan Connector Pinout and Wiring Colors
EricN is offline
Old 07-16-2014, 11:00 AM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
I think this falls into the category of "if you have to ask, you shouldn't do it"
Spend a couple of bucks and buy the right Y-adapter for your fans.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is online now
Old 07-16-2014, 11:19 AM
captain_video's Avatar
Quoted: 510 Post(s)
Liked: 336
You probably have some 4-pin Molex to 3 or 4-pin fan adapters that came with a fan at some point. Instead of connecting the extra fan to your motherboard you should be able to insert it into one of the PSU cables.
ajhieb likes this.
captain_video is offline
Old 07-16-2014, 11:50 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2682
buy a proper Y adapter from ebay for $3 and wait for it. I'd run the PC without the fan in the meantime.
Mfusick is offline
Old 07-16-2014, 01:46 PM
bryansj's Avatar
Quoted: 1133 Post(s)
Liked: 560
I would be looking to reduce the number of fans, not increase them. I go with the minimum to keep the noise down. I'd rather it run a little hot than loud. As long as it is within an acceptable range then leave it alone. You seem to want to plug something into every spot that accepts a plug or device.
bryansj is offline
Old 07-16-2014, 02:10 PM
mdavej's Avatar
Quoted: 2128 Post(s)
Liked: 940
+1
I've got the fan in the power supply, a CPU fan and one sitting on top of my Ceton card. That's it. That keeps everything around 50C, which is a little hot but still fine and very quiet. Of course your components may dictate otherwise.
I've ruined a motherboard before by having a cold solder joint of mine drop off and short something. So I try to avoid that at all costs. If you really need more fans, buy the right part before you start splicing and soldering. It's not worth the risk, especially if you don't have much experience with that kind of thing.
mdavej is offline
