Copy Once/ Copy Freely - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 07-16-2014, 12:00 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Hello I was told by one representative that all their channels were copy once while another representative told me that it is up to the individual station and that they don't control it at all.
So my question is has anyone had any experience with Metro cast and do the stations them self control what copy right protection is on the station.
alecwilcox is offline
post #2 of 14 Old 07-16-2014, 12:07 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
The cable providers set them. Comcast and Verizon are the most lenient. They have everything up to premium movie channels as Copy Freely. I don't know anyone else who does that (though there almost certainly some).
Beyond that individual programs can be denoted as Copy Once on a channel that is otherwise typically Copy Freely.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #3 of 14 Old 07-16-2014, 01:26 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
So if they are copy once does that mean I have to use WMC or does that mean I have to capture it over composite?
post #4 of 14 Old 07-16-2014, 01:35 PM
Quoted: 648 Post(s)
Liked: 426
If your channel/program is Copy Once, and you want to use a PC to record/watch, then you have to use Windows Media Center. A WMC extender logged into that PC would work too, but you need a PC configured to use WMC.
If I had a Copy Once program, and desperately needed to save it without the DRM, I could use the component/composite outputs on my Xbox 360 or DMA2100 to feed the video stream into a capture device.
post #5 of 14 Old 07-16-2014, 01:43 PM
mdavej's Avatar
Quoted: 2127 Post(s)
Liked: 940
Very clever. I never thought of that. Yet another reason to keep at least one Xbox around.
mdavej is online now
post #6 of 14 Old 07-16-2014, 02:57 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Could I get around all this and just use a composite capture device to start with in the first place
post #7 of 14 Old 07-16-2014, 03:02 PM
archiguy's Avatar
Quoted: 3420 Post(s)
Liked: 3289
You wouldn't be saving the HD version then - only SD through component/composite. So, who cares?
archiguy is online now
post #8 of 14 Old 07-16-2014, 03:06 PM
Quoted: 648 Post(s)
Liked: 426
What do you intend to capture? I mean, you *could* keep your current HD box and use a combination of PC, Hauppauge HD-PVR, and any DVR software you like to do recordings.
Having used WMC before there were cablecard tuners (forcing me to use capture) and now having the luxury of a cablecard theres no way I'd voluntarily go back.
For one thing you can only record/watch one channel at a time with capture. On a cablecard you can do up to six at once, depending on the device you get.
Secondly you are dealing with IR blasters, which aren't as bad as their reputation but are also no where near as convienent as an integrated tuner.
Third you are still paying for a set top box rental (unless you plan on buying an HTPC, buying an extender, and then buying a capture card to capture that extender's output).
You could capture in HD and 5.1 with component/toslink and something like the HD-PVR. Not that I'm planning on it, but it is theoretically possible.
post #9 of 14 Old 07-16-2014, 03:21 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
The only downside to use wmc with the cable card is that I will be unable to transfer it over to a tablet or something to watch it on. Also would I then not use Intel NUC as a front end and just use a centon Extender?
post #10 of 14 Old 07-16-2014, 03:22 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Also another reason I thinking capture was so I could transfer to direct TV which would give me better service and be cheaper,
post #11 of 14 Old 07-16-2014, 04:33 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
There are several HDMI capture cards (up to 1080i60/1080p24) that circumvent HDCP. A WMC PC with HDMI in GPU or a cable/satellite TV STB to another PC with a HDMI capture card, or even a WMC PC with HDMI in GPU to the same PC with a HDMI capture card.
renethx is offline
post #12 of 14 Old 07-16-2014, 04:53 PM
VideoJames's Avatar
Quoted: 12 Post(s)
If you want to use DirectTV, you would have to use a capture device since CableCard doesn't work with satellite. That is a hassle because the capture card would have to change the channel on the satellite box for each show it attempts to record and it uses an IR fob to do this.
If you are just trying to view TV on a tablet, most of the TV shows are already available on Apple or Google tablets. You are looking at a lot of extra trouble to record shows in WMC and then convert and transfer to a tablet.
VideoJames is offline
post #13 of 14 Old 07-16-2014, 05:18 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Ya i would just use WMC but to the best of my knowledge it does not run on windows server 2012.
post #14 of 14 Old 07-18-2014, 09:33 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
A single CableCARD gives you access to 6 streams. How much would direct TV charge you for service and 6 Direct TV boxes so that you can capture 6 streams at once. Also, you will need 6 capture devices.
I have never found satellite TV to be cheaper than land service. Most land service bundles your TV internet and phone, making bundle price much lower than individual services.
Verizon FiOS naked internet is like $60/month, bundle it with TV, and it is $50/month. All 3 services, TV, Internet and phone are $60/month. Even if Direct TV was $30/month for TV service, adding naked internet from your ISP will double the price, making it the same $60 for all 3 services from the land provider.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
Reply Home Theater Computers
