After new case swap created sleep issue Windows7. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 07-17-2014, 04:46 AM - Thread Starter
stevethebrain's Avatar
Quoted: 106 Post(s)
Liked: 25
I recently upgraded my PC case now my PC won’t sleep as it should.
This PC is used mainly to record TV shows like in the middle of the night when show has been recorded the PC should sleep (the on/off button should blink) however it stays on.
When I force a sleep
Start
Cursor right, cursor right, enter it will sleep one minute later it wakes this is w/ the mouse and keybroad turned off.
I rarely connect this PC to the net. So I have automatic updates turned off.
Here are the power settings in the BIOS.
ACPI Suspend mode S3 STR
Deep power off mode enabled
Power on by RTC alarm disabled
Power on by PCI devices disabled
Power on by PCIe devices disabled
Wake up by PS/2 KB/mouse enabled
Restore On AC Power loss Last state
Any tips on this sleep issues is appreciated
STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 18 Old 07-17-2014, 06:29 AM
DanPackMan's Avatar
Quoted: 233 Post(s)
Liked: 381
New power supply? If so, I'd suspect that's the difference maker. But I have no advice on solving.
DanPackMan is offline
post #3 of 18 Old 07-17-2014, 06:35 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
BIOS settings has no effect on it after Windows booted up. You need check the settings in Device Manager for each devices, especially for mouse and keyboard. If you have a wireless mouse and keyboard, you will have to disable both from waking up the PC. Also check the NIC settings to make sure only magic packets can wake up the PC.
You have to look at the event log to locate power troubleshoot events. This will tell you what wakes up your PC after you manually put it into sleep.
Foxbat121 is offline
post #4 of 18 Old 07-17-2014, 06:39 AM
Charles R's Avatar
Liked: 541
powercfg -requests
Try the above command in DOS and it will tell me what's keeping the PC awake or waking it up... once you know what's up you can address the processes themselves.
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
post #5 of 18 Old 07-17-2014, 10:04 AM - Thread Starter
Quoted: 106 Post(s)
Liked: 25
I manuelly disable the optical mouse w/ the on/off power switch on bottom of mouse, I would prefer to not disable in control panel because I use it to turn on PC.
What is a NIC and how do I chech it's settings?
How do I check the event log?
I tried you’r advice powercfg powerrequest result none
I tried last wake result the SSD Samsung Magician SW
Thanks STB
ID:	166417   Click image for larger version
post #6 of 18 Old 07-17-2014, 11:42 AM
DanPackMan's Avatar
Quoted: 233 Post(s)
Liked: 381
You can also try this command after it wakes up;
powercfg -lastwake
post #7 of 18 Old 07-17-2014, 01:19 PM
DanPackMan's Avatar
Quoted: 233 Post(s)
Liked: 381
Just a passing thought. I once had a wireless mouse receiver connected to a usb hub. It kept waking my PC immediately. After moving it to a port directly on the PC, the problem went away. Some cases, I believe, have a usb hub type arrangement for front panel connectors.
post #8 of 18 Old 07-17-2014, 02:12 PM
mdavej's Avatar
Quoted: 2129 Post(s)
Liked: 940
Haven't you been down this road before, Steve, with the Samsung Magician waking your PC? Just uninstall it. Problem solved.
mdavej is online now
post #9 of 18 Old 07-17-2014, 02:21 PM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
Don't need to (or, shouldn't) uninstall it - it's useful for updating firmware on the SSD, running TRIM on command if you are on anything below Win 8.1, checking SSD health, etc.
Just remove the shortcut it places in the startup folder. Then it won't start up with Windows anymore and keep the PC awake. From there on, you just have to kill it via the tray after you use it anytime in the future. Or restart after using it. Whatever floats your boat.
staknhalo is offline
post #10 of 18 Old 07-17-2014, 02:48 PM - Thread Starter
Quoted: 106 Post(s)
Liked: 25
are you saying to just drag the Magician desktop Icon to the recyclebin?
if not how do I remove the shorthcut and prevent Magician from starting at bootup?
Thanks STB
post #11 of 18 Old 07-17-2014, 03:17 PM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
C:\Users\<user name>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
There is a shortcut to the Magician software there, that shortcut is all you need to delete.
post #12 of 18 Old 07-17-2014, 04:14 PM
mdavej's Avatar
Liked: 940
That works too. But I've never seen a firmware update for my Samsung SSD and haven't used the software since I first cloned it. I still vote to uninstall and only re-install if necessary (probably never). The first time the OP runs it again, it will probably put itself back in Startup, then the head scratching about sleep will ensue again.
post #13 of 18 Old 07-17-2014, 04:23 PM
staknhalo's Avatar
Quoted: 383 Post(s)
Liked: 241
There have been 2 firmware updates for my Samsung 840 EVOs since I purchased them last February. Maybe there just weren't any for your make/model. That doesn't mean there aren't ever any for anyone. Or, no need for the software in general; even without firmware updates. RAPID mode is another beneficial feature of the drives you can only enable from within the Magician Software. For this particular piece of software, what it does and what piece of HW it relates to, telling him to remove it is just silly.
And no, I can tell you from experience, it does not re-add itself to the startup folder when you run it if you have previously removed it from the startup folder.
post #14 of 18 Old 07-19-2014, 04:58 AM - Thread Starter
Quoted: 106 Post(s)
Liked: 25
I would like to have the Magician SW just to experiment around w/.
I was able to get to C:/ Users/ user Steve
did not see AppData.
note I have the SSD setup for Max realibility
It's really unbelievably that Samsung doe'snt have a warning about there Magician ruining my PCs sleep.
STB
post #15 of 18 Old 07-19-2014, 05:49 AM
aliaskary77's Avatar
Quoted: 46 Post(s)
Liked: 56
can you see magician in the start menu in the startup folder? try right clicking on it on the start menu and delete.
aliaskary77 is offline
post #16 of 18 Old 07-19-2014, 06:00 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 399
The AppData folder is hidden. You will have to enable the option to view hidden folders and files in order to see it.
You can also type MSConfig command to launch a utility that may allow you to edit the startup alternatively.
post #17 of 18 Old 07-22-2014, 03:19 AM - Thread Starter
Quoted: 106 Post(s)
Liked: 25
even w/ the Magician SW removed the PC will not sleep after a schduled TV recording.
The only way it will sleep if I manuelley
start
crusor right
crusor right
enter.
Any tips on resolving the sleep issue
Thanks STB
post #18 of 18 Old 07-22-2014, 08:02 AM
bryansj's Avatar
Quoted: 1137 Post(s)
Liked: 561
Leave it running 24/7. That will solve your sleep issue.
bryansj is offline
Reply Home Theater Computers
