Reviving old XP LT w/ new techonogoly
this XP LT has a IDE internal interface.
I look at the BIOS boot order
1.USB rest is blank
2.SSD
3.DVD
Ect.
So is it possible to boot from a USB connected HDD or SSDusing this interface?
http://www.newegg.com/Product/Product.aspx?Item=N82E16812232002
I would also like to use this device to recover data from another IDE HDD.
Note this LT will not be used as a portable but like astationary desktop.
Or maybe this
Reviving old XP LT w/ new SSD inserted into the DVD driveslot?
http://www.microsatacables.com/9-5mm-ide-optical-bay-hard-drive-adapter-caddy/
?1.can I adjust the BIOS boot order and use the DVD port asa boot drive?
?2.can I use a modern SSD in a XP LT?
What do you Guy’s think about squezzing a little more out ofthe XP LT?
Thanks STB
1.USB rest is blank
2.SSD
3.DVD
Ect.
Or maybe this
Thanks STB
