Helo me setup my new stereo system - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-19-2014, 11:01 AM - Thread Starter
SeaNile's Avatar
Quoted: 380 Post(s)
Liked: 136
Just bought Revel Studio2 speakers and a Hegel h300 integrated amp (has DAC).
I have a pretty big iTunes library and have no CD's at all. Not sure of the format of the music files when I put my CD's into iTunes. I'd really like to get great sound out of my system and would like NOT to re-buy hundreds of CD's.
I'm OK with buying a Mac Mini but not sure how to hook up everything. I'll transfer over my library to the Mac Mini but then I'm a bit lost. Best to hook the Mini up to the Hegel via USB? And then use something like jRiver to manage the music? What about wanting to buy new music that may not be available on a high resolution site, do I buy the CD and just import it to the iTunes library?
Thanks for the help..
SeaNile is offline
post #2 of 3 Old 07-19-2014, 12:58 PM - Thread Starter
SeaNile's Avatar
Quoted: 380 Post(s)
Liked: 136
Oh man, just what I was afraid of, at least 85% of my library is AAC and purchased AAC. Then a combination of AIFF, Apple Lossless, MPEG audio.
Looks like I will be re-buying a lot of music??
SeaNile is offline
post #3 of 3 Old 07-19-2014, 02:40 PM
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
AAC is not lossless. Whether you can tell or not is up to you, but if you really want the best theoretical quality you want CDs ripped to FLAC, WMA lossless or ALAC. Those are probably the most commonly supported.
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
Reply Home Theater Computers
