Adding more hard drives when out of SATA ports. - AVS Forum | Home Theater Discussions And Reviews
Old 07-19-2014, 09:47 PM - Thread Starter
Alan Winslow's Avatar
I have a mini ITX motherboard and out of ports to plug in hard drives. The case is large enough to hold more.
Are there any solutions out there to add more drive easily?
Alan Winslow is offline
Old 07-19-2014, 10:16 PM
ajhieb's Avatar
Quoted: 935 Post(s)
Liked: 663
If your ITX board has a PCIe (or even PCI) expansion slot you should be able to add an additional SATA controller.
If your onboard SATA controller supports Port Multipliers then you could use one of those (with reduced performance)
You could also use external USB drives, or possibly rig up some internal USB solutions but those will also have reduced performance as well.
But if you want your drives connected at full speed, you'll need a PCIe (or PCI) expansion slot.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is offline
Old 07-19-2014, 10:48 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
A couple of SATA 6Gbps controller PCI Express cards:
- SYBA SY-PEX40039 2-port internal SATA 6.0Gb/s Controller PCI Express 2.0 x1 Card (ASM1061 chip)
- SYBA IO Crest SI-PEX40064 4-port internal SATA 6.0Gb/s Controller PCI Express 2.0 x1 Card (88SE9215 chip)
- Supermicro AOC-SAS2LP-MV8 8-port SAS/SATA 6.0Gb/s Controller PCI Express 2.0 x8 Card (88SE9480 chip); you will need two SFF-8087 to 4 x SATA forward breakout cables (e.g. 3ware CBL-SFF8087OCF-05M)
renethx is offline
Old 07-20-2014, 05:28 AM
captain_video's Avatar
Quoted: 511 Post(s)
Liked: 336
Here's a list of SATA controller cards that work with unRAID. They'll work with any OS as long as you have the right drivers:
http://lime-technology.com/forum/ind...?topic=12404.0
captain_video is offline
Old 07-20-2014, 06:47 AM - Thread Starter
Thanks for all the quick replies! The PCI card looks like the prefect solution for me.
