Flex Raid??? - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By ajhieb
  • 1 Post By rc05
post #1 of 7 Old 07-20-2014, 09:02 AM - Thread Starter
stamina1914's Avatar
Quoted: 106 Post(s)
Flex Raid???
Now that I have my system is up and running again. Can someome recommend which Flex raid option I should purchase. I have been using assassins guide to build my HTPC, but it seems as though his Flex Raid guide needs to be updated to match the flexraid website. Which one of the two new options would be best for a simple htpc user such as myself?
I am currently using Windows 7. I have one 2TB HDD with all my movies on it and 2 brand new HDD 2TB that are empty. Thanks for the help.
stamina1914 is offline
post #2 of 7 Old 07-20-2014, 09:21 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
Snapshot works best on stagnant data that doesn't change (like media)
Real time works best on dynamic data that changes (like databases or ms word and excel docs where you might edit the doc but the file remains with same name).
Real time has a small performance hit up front on writes because parity is calculated and recorded real time as you write files. Snap shot does it later at a designated time (like middle of night) so it's not performance effected. With snap shot you'll get what your drives can do.
Mfusick is offline
post #3 of 7 Old 07-20-2014, 11:23 AM - Thread Starter
Quoted: 106 Post(s)
I'm a little confused..the Website advertise Raid F and transparent Raid. Which one is ideal for HTPCs with Windows 7 and not WHS. Thanks
post #4 of 7 Old 07-20-2014, 11:38 AM
ajhieb's Avatar
Quoted: 936 Post(s)
Liked: 663
The version of Windows makes little to no difference. What @Mfusick said is great description. You should base your decision on what type of data you have, not what operating system.
RAID-F (snapshot) raid is best suited for static data such as media collections. Static data being anything that you move to the pool and then don't modify it.
Transparent RAID (real time) is best suited for dynamic data like databases or frequently modified documents.
Most people on here using flexraid for their media servers use RAID-F
Mfusick likes this.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is offline
post #5 of 7 Old 07-20-2014, 11:47 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2686
Snapshot = RAID F
Realtime = RAID T
Raid F is the traditional "flexraid"
Raid T is the newer "transparent" raid that works real time. The original flexraid had modes for both real time and snapshot but most did not use the real time because it did not work so great. The developer re-developed that as a new product. (raid t)
Mfusick is offline
post #6 of 7 Old 07-21-2014, 01:53 PM
Roussi's Avatar
Quoted: 46 Post(s)
Liked: 36
Now I am confused. I thought FlexT was the traditional version, with real-time and snapshot modes, and Flex F ("file") was the new one. Will have to go and read again, have been planning for a while to try it (in the meantime, two 2TB WD Greens failed...)
Roussi is offline
post #7 of 7 Old 07-21-2014, 01:59 PM
rc05's Avatar
Quoted: 152 Post(s)
Liked: 87
You have it reversed, FlexRAID tRAID is only real time, while FlexRAID RAID-F is the old one with snapshot (and real-time, but I think it's recommended to use tRAID until RAID-F real-time is redone)
Mfusick likes this.
rc05 is offline
Reply Home Theater Computers
