Sound "pop" when HTPC goes to sleep or restarts - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-23-2014, 05:26 AM - Thread Starter
scottdw's Avatar
I have a music "jukebox" setup with an amp connected to my sound card and every time I restart or put the computer to sleep all of the speakers make a pop sound, same thing happens when it boots back up or resumes from sleep....makes if fun when every speaker in the house pops at night
As a temporary fix for this I added an OLD X10 appliance module so I could basically switch off the outlet the amp is connected to when the computer sleeps and switch it back on once the computer is back up. I have been running this way for a few years on my HTPC that was running XP. I recently upgraded to win7 with a different jukebox program and program that came with the X10 module no longer works. I found a program someone else wrote to control the X10 but I have issues with it every once in a while and want a more stable approach.
First, I am hoping there is a way I can just leave the amp on all the time without the "pop" happening.
Second, is there a cheapish computer controlled outlet I can get to replicate what I have now....the X10 is just old and I am not sure how long it would last anyway. I would need to be able to turn it on and off thru command line.
Scott
Scott
scottdw is offline
post #2 of 3 Old 07-23-2014, 08:33 AM
Barrettmr's Avatar
Quoted: 104 Post(s)
Liked: 29
I have one of those 'green' multi socket filter things where you turn off a master piece of equipment and it shuts off the other 'green' sockets, and back on again when you switch on the master. I used it with my AVR so when it goes to standby the power to my projector and DVD player turns off. I wonder if the PC going to sleep would trigger that function? Not sure I would like the idea of having the amp powered on 24/7, is that normal?
Epson 5020UB - Falcon Screens AT 131"
Onkyo TX NR818 - Emotiva XPA-5 - Panamax M5300
Polk 265LS/255cLS L/C/R - 80F/X-LS & LSiM703 surrounds - Dual SVS PB2000 subs
OPPO BDP-103 - HTPC with MediaBrowser3
http://www.avsforum.com/forum/19-ded...-re-model.html
Barrettmr is offline
post #3 of 3 Old 07-23-2014, 09:51 AM - Thread Starter
scottdw's Avatar
Thanks but I don't know if that will work because the popping happens as soon as the computer is put to sleep so it may not have enough time to switch the power off. I did notice that the popping happens on this particular sound card...not another I tested. I am using a Sound Blaster 0060 with the KX drivers so I can adjust each port individually. It could be my particular card or the KX drivers themselves.
Scott
scottdw is offline
Reply Home Theater Computers
