W7 PC that refuses to sleep - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #31 of 33 Old 07-28-2014, 12:36 PM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Originally Posted by stevethebrain View Post
A Magnavox DVR, Sony BD and a PC connected to the AVR w/HDMI cables then out of AVR w/ HDMI to the TV also have a optical Tosh linkconnected to TV’s audio out to AVR AV1.
I'm confused, if you have all the equipment into to the receiver with HDMI and then from receiver to TV with HDMI both audio and video should get to the TV.
The toslink connection to the receivers AV1 in should not be necessary from tv toslink out unless your using a built in ATSC tuner for OTA HD.
Look in the tv settings to be sure you have HDMI setup to do video and audio. Likewise look for a similar setting in the receiver for the HDMI out.
oman321 is offline
post #32 of 33 Old 07-28-2014, 12:52 PM - Thread Starter
stevethebrain's Avatar
Quoted: 108 Post(s)
Liked: 25
resolved
the tosh link somehow got disconected.
plugged it back in and I have the audio. thanks STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #33 of 33 Old 07-28-2014, 01:06 PM - Thread Starter
Quoted: 108 Post(s)
Liked: 25
I'm curious what you Guy's have you'r settings for
when the PC sleeps in minutes.
The three times I tested my sleep was for one minute recordings PC was put asleep 15 minutes pryor to recording PC woke up and PC right after recording immediately went to sleep. (this is the way it has always sleep)
I maynot have completely resolved this sleep issue
because Monday morning the last scheduled recording was to end at 2:00am at around 2:20am the PC was still on.
I have the when the PC is set to sleep set at 30minutes (which is defualt) so if the issue is resolved would it have sleep at 2:30am?
and why did my three tests put the PC to sleep
immediately after recording?
Thanks STB
Reply Home Theater Computers
