Simple fix for overscan and Intel graphics cards - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Works?
Yes 0 0%
No 1 100.00%
Voters: 1. You may not vote on this poll
 2Likes
  • 1 Post By enginetester
  • 1 Post By crbaldwin
post #1 of 4 Old 07-27-2014, 01:15 PM - Thread Starter
Liked: 1
Post Simple fix for overscan and Intel graphics cards
With the newer Intel graphics getting so much better, I know there are people having the same issue as me with their HTPC. The Intel software doesn't seem to have overscan correction! And Powerstrip doesn't work either.
I figured this out on an Intel 4600, Windows 7 64-bit, 15.33.18.64.3496 driver. Probably works for others though.
Right-click on desktop, then Graphics options submenu, Custom Resolutions. Select your display (your TV) on the left. Now enter the resolution you want to use (for me it was 1920x1080, 32bit, 30Hz, and the last 2 at default). Click add at the bottom.
Now right-click Graphics properties to go into the normal Intel utility. Click Display. Select your display on the left. Click Customize aspect ratio at the bottom. On the right side, you now have overscan adjustment bars! Correct your overscan and hit Apply. Done.
Please post if this works on your chip. And share across other forums, I'm not bored enough to go post this on all of them.
freetvEE likes this.
enginetester is offline
post #2 of 4 Old 07-27-2014, 03:53 PM
Slosh's Avatar
Quoted: 51 Post(s)
Liked: 33
This doesn't work with a 1080i HDTV. I can set the custom resolution by right clicking the desktop but in the Intel dashboard utility maintain display scaling can't be unchecked and there's no overscan sliders available (there are for my monitor, however).
i5-4440
10.18.10.3621 driver
Windows 8.1 64-bit
Slosh is online now
post #3 of 4 Old 07-28-2014, 07:23 PM - Thread Starter
Liked: 1
That is what mine was doing at first. Might be worth trying adding the custom resolution again, restarting and then trying it.
I've also found that the Intel driver is buggy - when I change settings and hit apply, it only sometimes applies the settings. Will have to do some searching first, but I might try an older version and see if it's more stable. Maybe someone on here knows of a better driver?
post #4 of 4 Old 08-02-2014, 12:10 PM
crbaldwin's Avatar
Quoted: 75 Post(s)
Liked: 24
The "Scaling" setting in the Intel drivers works as overscan correction for me.
JP32 likes this.
crbaldwin is online now
Reply Home Theater Computers
