I have had my HTPC setup for years working perfectly, but unfortunately my son became curious with the remote controls for my receiver and TV. In the process he changed several settings, and I couldn't seem to get the system working properly so that MPC (set up in the same way the sticky notes) would switch to 24 Hz when playing content.
I have tried removing MPC, reclock, Mad VR and video drivers (registry keys included) to no avail. I'm close to just blowing the install away and starting fresh.
Here is my current config including receiver and TV settings:
-My Denon 2313 is not doing any processing under video settings (this was difficult to disable for some reason and was never enabled previously)
-My Samsung is set to PC mode (which in itself is annoying because i can't tweak the colour and tint but i will save that for another sub forum)
-My video card is a radeon 7850 with the 14.4 drivers installed freshly
I understand that this description may be a bit lacking, but i will update with any information if needed. As always thank you for looking.
