SAS controller help - AVS Forum | Home Theater Discussions And Reviews
Old 07-28-2014, 10:45 AM - Thread Starter
imadork8317's Avatar
Question [SOLVED] SAS controller help
I have 2 AOC-SASLP-MV8 card's running 15 of my drive's everything was going great running on WHS2011. I recently did a major rebuild and combined my PC and Server into a single case. It seems that Windows 8 and the AOC-SASLP-MV8 do not play nice together, i can get the drivers installed but the moment i connect any hard drives to it, Windows 8 throws a BSOD dpc_watchdog_violation error, which i have yet to determine a solution for.
I am fairly confident I could order the newer aoc-sas2lp-mv8 which seems to have Win8 drivers. However I am interested in possibly upgrading my controller, would it be worthwhile to upgrade to an LSI controller even though all I need is JBOD? It would be nice to have something faster than the Marvell 6480 I am currently running. Would the upgrade to the aoc-sas2lp-mv8 with the Marvell 9480 give me a performance boost?
Any help is appreciated.
Solution - Actually install the 4.0.0.1200 driver not the 3.1.0.22 driver
imadork8317 is offline
Old 07-29-2014, 09:32 AM
fibertech's Avatar
I had the same cards in a WHS v1 build that kept dropping drives all of the time. When I upgraded to 2011 I also bough two IBM M1015 and flashed them to LSI 9211-8i, Both have been working flawlessly ever since and the cards are pretty cheap. Do a search on the subject, there are a few threads about it on here.
fibertech is offline
Old 07-29-2014, 12:37 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I don't see any problem with AOC-SASLP-MV8 + Windows 8.1, like many other users. Which driver are you using? 4.0.0.1200 should work.
You would see very little performance difference by upgrading SASLP (PCIe 1.x x4) to SAS2LP or IBM ServRAID M1015 (PCIe 2.0 x8).
PCIe 1.x x4: 1000MB/s, that's fast enough even for simultaneous access to 8 HDDs, let alone for access to each individual HDD at a time.
renethx is offline
Old 07-29-2014, 12:42 PM - Thread Starter
PCIe 1.x x4: 1000MB/s, that's fast enough even for simultaneous access to 8 HDDs, let alone access to each individual HDD at a time.
renethx,
I am running 4.0.0.1200, the driver and firmware work fine until i try to boot with any number of disks attached to it, then my system locks up and gives me BSOD.
Old 07-29-2014, 01:05 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
If you are using "Windows 8" not "8.1" (as you wrote), then it may be worth upgrading to 8.1, as well as the chipset drivers (the latest one is 10.0.17, ME driver is 10.0.0.1204; they support Intel 6, 7, 8, 9 Series chipsets)
renethx is offline
Old 07-29-2014, 01:07 PM - Thread Starter
It is win8.1, i'll check the chipset to ensure it is up to date, though i believe it is.
Old 07-30-2014, 09:47 PM - Thread Starter
Update - I am dense. I wasn't using the 4.X driver, I grabbed the 3.X by mistake my bad renethx !
When i started seeing my 2TB drivers work and not the rest i eventually figured it out.
aoc-sas2lp-mv8 , aoc-saslp-mv8 , lsi , marvell 6480 , marvell 9480
