Networking issue please help! - AVS Forum | Home Theater Discussions And Reviews
 11Likes
  • 1 Post By kjfalls
  • 1 Post By Foxbat121
  • 1 Post By bryansj
  • 1 Post By Andy_Steb
  • 1 Post By ajkrishock
  • 1 Post By ajhieb
  • 1 Post By ajhieb
  • 1 Post By DanPackMan
  • 1 Post By jimbo75
  • 1 Post By jimbo75
post #1 of 20 Old 07-28-2014, 09:56 PM - Thread Starter
whiteboy714's Avatar
So I have a server that runs 24/7. I use RDP to remote into it. Holds my media and handles all downloads etc.
The internet connection has been really flaky on it lately. It is connected via the onboard GB NIC. The server and my main PC are behind a GB switch that goes to my modem/router.
I ruled out the switch/cable as I swapped cables and connection spots on the switch with my main rig and the main rig is flawless. I have never experienced any internet drop outs on it. On the server I can load web pages repeatedly and every minute or so it the pages will stop loading, after a few seconds of hitting refresh things will load again.
So I figured it must be the onboard NIC since another PC using the same switch and cable works fine. Went and bought a PCIE GB NIC card and am experiencing the same issue. Now I am lost, server is running a fairly new fairly light install of Win 7 x64.
Any software I can use to check the connection, when I look in windows "network and sharing center" I do not see the connection drop but it is definitely having issues.
whiteboy714 is offline
post #2 of 20 Old 07-28-2014, 10:50 PM
kjfalls's Avatar
Location: Dennison IL, just across the state line from Terre
Quoted: 198 Post(s)
Liked: 63
Perform a ping from the command line to the router IP address.
C> ping 192.168.2.1 (or whatever the default gateway address is)
This will send 32 byte packets to the default gateway and should receive a response with the time it took to respond. If you receive 100% of the packets is a few milliseconds try the same command, but with larger packets.
C> ping 192.1682.1 -l 1000
If this looks OK try the same two commands but use an external address such as www.google.com. This should tell you if you have an internal or external issue.
whiteboy714 likes this.
kjfalls is offline
post #3 of 20 Old 07-29-2014, 08:38 AM - Thread Starter
Thanks, so the problem is definitely external. Pings the router fine. Couldn't even reach google. Right now I can't even load a web page, but windows shows I am online and everything is fine. Never seen that before.
post #4 of 20 Old 07-29-2014, 08:52 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 386
Sounds like somekind of DNS trouble..
Foxbat121 is offline
post #5 of 20 Old 07-29-2014, 08:56 AM
bryansj's Avatar
Quoted: 1066 Post(s)
Liked: 524
That's what I was thinking. Time for a "ipconfig /flushdns".
bryansj is offline
post #6 of 20 Old 07-29-2014, 08:57 AM
Andy_Steb's Avatar
Quoted: 31 Post(s)
Liked: 158
Agreed.
Googles IP is 74.125.131.103
Try that in your web browser and ping
Andy_Steb is offline
post #7 of 20 Old 07-29-2014, 09:04 AM - Thread Starter
I did the flush DNS. I am able to ping the google IP but it won't load in the browser.
post #8 of 20 Old 07-29-2014, 09:12 AM
Foxbat121's Avatar
Quoted: 698 Post(s)
Liked: 386
Try a different browser. Your current browser may have been hijacked by malware or something.
post #9 of 20 Old 07-29-2014, 09:20 AM - Thread Starter
Tried that yesterday, didn't help, tried again just now. The connection works about 80% of the time.
post #10 of 20 Old 07-29-2014, 09:23 AM
ajkrishock's Avatar
Quoted: 76 Post(s)
Liked: 33
I had somebody mess with my hosts file once. They put a bunch of websites I frequently read into my hosts file with the loopback address next to them. Might be worth a look.
ajkrishock is offline
post #11 of 20 Old 07-29-2014, 09:25 AM
ajhieb's Avatar
Quoted: 914 Post(s)
Liked: 656
Could be malware, or it could be the stuff designed to prevent you from getting malware. I've seen AV/Firewall/anti-malware software cause all sorts of network related problems. Some of those AV suites (I'm looking at you McAfee and Norton) have a mind of their own sometimes.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is online now
post #12 of 20 Old 07-29-2014, 09:44 AM - Thread Starter
But that would cause it to do it everytime right? I am just getting a dropped connection like half the time as it sits right now.
Ran malwarebytes and it found nothing. It or any AV was not installed before just now. This is craziness. Super frustrating.
post #13 of 20 Old 07-29-2014, 09:55 AM
ajhieb's Avatar
Quoted: 914 Post(s)
Liked: 656
If it is affecting multiple browsers (that is to say, the entire computer) but you can ping external IP Addresses fine, and there isn't any software blocking traffic on that computer evidently, then I'm back to DNS issues.
Are you using your ISP's DNS servers?
You might try using Google's, just to see if it makes a difference. (8.8.8.8 and 8.8.4.4)
You can either reconfigure your router to use them or just change them on your computer. (exact process will vary depending on your OS but basically you'll change you IP configuration from dynamic to static, use the same IP address that your router had assigned, and use the same default gateway, just change the primary and secondary DNS servers to the ones above)
post #14 of 20 Old 07-29-2014, 10:01 AM
DanPackMan's Avatar
Quoted: 187 Post(s)
Liked: 306
Long shot, but wth: I've heard of cases where time and date set on the PC did not match network and caused problems, but that us usually website specific. Might as well at least check that.
Run ipconfg on both PC and Server and make sure gateway is the same.
Have you tried a manually specified DNS? Might give that a shot (8.8.8.8, 8.8.4.4 = google dns)
DanPackMan is offline
post #15 of 20 Old 07-29-2014, 10:12 AM - Thread Starter
Thanks guys I actually am using googles dns. I have the IP address on the server setup manually. The default gateway is correct.
Time is the same as my desktop, although trying to manually sync it would not work. Connection isn't working again. I hope a clean install would fix it? It sounds like a software issue right? Two different NIC's same issue.
Not sure if it could still be an issue with the mobo but seems like the new NIC would have solved that. I really don't want to reinstall windows as there a few programs that take a bit of setup that I use. But thats where it seems I am at right now.
post #16 of 20 Old 07-29-2014, 10:24 AM
jimbo75's Avatar
Could you have an IP address conflict with something else in the network?
jimbo75 is offline
post #17 of 20 Old 07-29-2014, 10:29 AM - Thread Starter
It shouldn't because I have used that IP specifically for my server for years. But I changed it just to test and still have problems. Its weird because this just happened out of the blue, or maybe I just wasn't noticing it but I don't know that I changed anything that could have caused an issue.
post #18 of 20 Old 07-29-2014, 10:39 AM
jimbo75's Avatar
Have you rebooted everything in your network?
Can you ping 8.8.8.8 from your server?
jimbo75 is offline
post #19 of 20 Old 07-29-2014, 10:50 AM - Thread Starter
Yes and yes, I can ping anything when the internet wants to work. But that is pretty hit and miss as far as when it feels like working. I'm backing everything up right now going to start over.
post #20 of 20 Old 07-29-2014, 01:06 PM - Thread Starter
Seems to be good so far, thanks for the help everyone.
Reply Home Theater Computers
