Low Voltage / Ethernet Contractors in SoCal - AVS Forum | Home Theater Discussions And Reviews
Old 07-29-2014, 11:41 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
So that's the question. I'm moving into a new to us house next week and want to get the ethernet installed stat so I'm looking for suggestions on people to do this for me. I can physically do it but I don't have the time to do it.
Should I go with MoCA or Powerline??
Any suggestions?
Sammy2 is offline
Old 07-29-2014, 04:58 PM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
Any suggestions?
I use Powerline and love it. Just plug in the adapters and off you go. The next gen of Powerline - Gigabit speed w/MIMO - hits around the holiday season so you might want to just wait to invest in it when that is available and stick with a high-end wireless router for now.
LexInVA is online now
Old 07-29-2014, 06:19 PM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
Any suggestions?
I went with MoCa a little over a year ago, and I'm stuck with 10Mbps transfers. I've been thinking about running an Ethernet cable into my converted garage room, but not looking forward to crawling under the house.
leebo is offline
Old 07-29-2014, 09:23 PM
NNate's Avatar
Quoted: 54 Post(s)
Cutting holes in your walls is fun. Covering them back up again is another story, however...
NNate is offline
Old 07-29-2014, 09:56 PM
Aryn Ravenlocke's Avatar
Quoted: 351 Post(s)
Liked: 134
This is why I invariably wind up paying someone else to do it.
Aryn Ravenlocke is offline
Old 07-29-2014, 11:55 PM
leebo's Avatar
Quoted: 525 Post(s)
Liked: 293
YouTube can be your friend.
leebo is offline
Old 07-30-2014, 09:09 AM
NNate's Avatar
Quoted: 54 Post(s)
I've done it many times. It's just much more time consuming to cover the hole and repaint than the minute it takes to cut it open.
NNate is offline
Old 07-30-2014, 09:38 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Well, I know how to do it, I did it on the house I'm moving out of.
This time however, it is a matter of having the time to do it, not the expertise.
Sammy2 is offline
Old 07-30-2014, 10:33 AM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
Having wired 2 houses, so far, you only to cut a hole for the low voltage box and wall plate, and just fish the wires through the wall from basement or attic.
I think I only had to cut additional holes when I was installing recessed lights where there were none, and rafters ran perpendicular to the room.
If you are planning on having the interior painted, which is what most people do when they move into new to them house, you will already have the paint that will match, should you decide to wire it after you paint.
I really hate how cable TV installers either run the coax along the moldings or drill a hole to the outside to run the wire to another floor/room. They almost never seal it with caulking. So, if you were to do it, then run coax and at least 2 Ethernet wires (one can be used for phone) to each location. For bigger rooms place 2 locations on the opposite sides of each other, future proofing any future re-arrangements.
For a 3,000 ft² colonial figure a good part of a 2 day weekend to wire it completely. Less time for a smaller house or a ranch.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
Old 07-30-2014, 10:55 AM - Thread Starter
Sammy2's Avatar
Quoted: 514 Post(s)
Liked: 250
Good advice. The paint in this home is in really good shape so we aren't planning on re-painting right away but this may accelerate that project.
It is a two-story California Tuscan/Mission style home. The bedrooms upstairs should be a piece of cake for the most part but the Family Room, Kitchen and outside covered patio/BBQ by the pool will be a little bit more of a consideration as to routing of cables.
Sammy2 is offline
