New Case - AVS Forum | Home Theater Discussions And Reviews
 1Likes
Old 07-30-2014, 09:31 AM - Thread Starter
Sammy2's Avatar
Quoted: 487 Post(s)
Liked: 243
New Case
I was going to put my new system in my existing case and utilize my graphics card but got to thinking, "This HTPC works pretty well, so why not get a new case for my new system?"
So I figured who else but you guys to ask for assistance in that regard. I like SFF so I'm going with an ATX a Micro ATX case and I'll need a 3.5" (or 2.5" 1Gig I already have) DVR Drive and a 2.5" SSD in it as well as fitting my graphics card.
Sammy2 is offline
Old 07-30-2014, 10:01 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Originally Posted by Sammy2 View Post
I like SFF so I'm going with an ATX case
An ATX case is usually considered as a large form factor...?
renethx is offline
Old 07-30-2014, 10:05 AM - Thread Starter
Sammy2's Avatar
Quoted: 487 Post(s)
Liked: 243
Oops.. Micro ATX so it's "medium" form factor I suppose..
Sammy2 is offline
Old 07-30-2014, 10:47 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Fractal Design Node 605 is a nice microATX / ATX case. (ATX when slim ODD is not installed.) Or Lian Li PC-C50. If you want to go cheaper, then Silverstone GD04/GD05/GD06.
renethx is offline
Old 07-30-2014, 11:03 AM - Thread Starter
Sammy2's Avatar
Quoted: 487 Post(s)
Liked: 243
The Lian Li PC-C50 seems to be OOS at all the normal places..
Sammy2 is offline
Old 07-30-2014, 11:29 AM
Dark_Slayer's Avatar
Quoted: 634 Post(s)
Liked: 416
So you've decided to use or not to use the graphics card?
I like the mlo3b and mlo4b (though I usually find the 3 cheaper and don't have a need for usb3 on the case)
Dark_Slayer is offline
Old 07-30-2014, 11:34 AM - Thread Starter
Sammy2's Avatar
Quoted: 487 Post(s)
Liked: 243
I am going to use that graphics card in the main PC unless there's no need for it. I do do 3D and 23.976fps with MadVR is desirable.
Sammy2 is offline
Old 07-30-2014, 11:40 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
renethx is offline
Old 07-30-2014, 11:57 AM - Thread Starter
Sammy2's Avatar
Quoted: 487 Post(s)
Liked: 243
Originally Posted by renethx View Post
Silverstone Milo ML03/ML04 are low-profile cases, so HD 7850 won't fit.
Do I need it with an i5 4690 with Gigabyte GA-Z97X -Gaming 5 MoBo?
Sammy2 is offline
Old 07-30-2014, 12:10 PM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
What's your "main PC"? Is it different from the HTPC you are talking about in this thread?
Intel HD Graphics 4600 works fine with madVR if you select DXVA2 up/downscaling (basically a Lanczos flavor). Beyond that you will need a better GPU.
Dark_Slayer likes this.
renethx is offline
Old 07-30-2014, 12:11 PM
StardogChampion's Avatar
Quoted: 92 Post(s)
Liked: 160
nMediaPC makes some nice inexpensive microATX cases that'll fit a GPU.
StardogChampion is offline
Old 07-30-2014, 12:13 PM - Thread Starter
Sammy2's Avatar
Quoted: 487 Post(s)
Liked: 243
My "Main" PC will remain as an i5-650 but I'm moving all MB3 server functions to this new HTPC and may use it for other processor intensive tasks too. The thing is that I want to drive 4 or 5 extenders simultaneously or maybe a couple of Rokus too. Additionally, I want it to serve media outside the home for when I'm on the go. Transcoding is a GPU CPU intensive task that my old i5 is not so good at.
Sammy2 is offline
Old 07-30-2014, 12:37 PM
FantaXP7's Avatar
Quoted: 42 Post(s)
Liked: 35
My "Main" PC will remain as an i5-650 but I'm moving all MB3 server functions to this new HTPC and may use it for other processor intensive tasks too. The thing is that I want to drive 4 or 5 extenders simultaneously or maybe a couple of Rokus too. Additionally, I want it to serve media outside the home for when I'm on the go. Tanscoding is a GPU intensive task that my old i5 is not so good at.
Transcoding is CPU. Unless "Tanscoding" is what you meant then maybe that is something GPU intensive
FantaXP7 is offline
Old 07-30-2014, 12:38 PM
Quoted: 634 Post(s)
Liked: 416
Transcoding is a GPU intensive task that my old i5 is not so good at.
Negative, in fact, afaik neither Plex nor MB3 server use hardware acceleration. CPU bound
Old 07-30-2014, 01:04 PM - Thread Starter
Sammy2's Avatar
Quoted: 487 Post(s)
Liked: 243
Yes. I knew this. I just was thinking/typing fast.
That's why I'm upgrading the CPU and moving my MB3 server to the new HTPC. This and using multiple extenders were not of as much consideration in 2011 as they are now.
Sammy2 is offline
Old 07-30-2014, 01:46 PM
Quoted: 634 Post(s)
Liked: 416
Well, this is tangential, but I do need to ask at some point . . . does the echo playback full rips now that shark put the "alternate extender support" checkbox in his codec pack?
I had set one up a while back for a coworker, but I told him in advance it would only be good for music, pictures, and tv. He has copy-once cable and a bunch of blu-rays. No dvds. I'm wondering now if that checkbox would change things. Some of the wmc-extender crowd here have said the echo plays back all of their videos, but I wasn't sure what to make of that
Old 07-30-2014, 02:00 PM - Thread Starter
Sammy2's Avatar
Quoted: 487 Post(s)
Liked: 243
I have not bothered with that much as time has not permitted. The TV's where the echos will be are generally 720p with no surround sound so and echo and the Rokus will do fine there. The TV in the Master Bedroom will have my current HTPC and an echo. The echo's are basically for whole home PVR and copy once content.
That said, I haven't installed the latest Shark007 because I've had no need to do so but I will in this install and check it out.
Sammy2 is offline
Old 08-05-2014, 01:51 PM - Thread Starter
Sammy2's Avatar
Quoted: 487 Post(s)
Liked: 243
Any thoughts on this case?
Sammy2 is offline
Old 08-05-2014, 02:55 PM
techmattr's Avatar
Quoted: 71 Post(s)
Liked: 184
One of my HTPCs is in a Phenom M which is similar in shape and size to that. I love the Phenom. Can't speak to the apevia itself though.
techmattr is offline
Old 08-05-2014, 04:47 PM
hogues's Avatar
Quoted: 72 Post(s)
Liked: 51
I have this case and really like it.
hogues is offline
Old 08-06-2014, 06:22 AM - Thread Starter
Sammy2's Avatar
Quoted: 487 Post(s)
Liked: 243
Can't find the Fractal Design case at a drcent price from a reputable seller..
What do you guys think of the Siverstone GD05B? Will it fit my Video Card?
Sammy2 is offline
Old 08-06-2014, 07:40 AM
JackDiesel14's Avatar
Quoted: 12 Post(s)
Liked: 31
I have the 04B and it wouldn't fit my Asus 270x that turned out to be DOA or the Sapphire 270x I bought to replace it. The 04/05 lack the height to accommodate bigger cards.
I'm about to pull the trigger on the GD10 which was just released. It has the height of the 07/08 without being as deep.
JackDiesel14 is offline
Old 08-06-2014, 08:09 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
I bought Node 605 from NCIX US for $137 (shipped). The current lowest price is $151 at Nextwarehouse.com?
Yes, your card (no tall heatpipes unlike the ASUS card) fits GD04/GD05/GD06 just fine. (I don't like the fan filter positions in these cases, however.)
renethx is offline
Old 08-06-2014, 09:40 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
The internal structure of GD10 is the same as GD09, just in case...
renethx is offline
Old 08-06-2014, 10:13 AM - Thread Starter
Sammy2's Avatar
Quoted: 487 Post(s)
Liked: 243
I just checked and it's $175. Trying to not get too spendy here but what is it about the filters that you don't like with the GD05B?
Sammy2 is offline
Old 08-06-2014, 10:22 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2668
Haswell with HD4600 in the i5 has good enough graphics, so using the card in your old i5 is a better balance between the two systems. You'll have good performance on both. If you want more than HD4600 you'd want to upgrade later for that machine, probably something even higher like an R9 card which will be sub $200 by the time you go looking for one anyways.
Mfusick is offline
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2668
http://www.amazon.com/dp/B008J0ZOV8/...SIN=B008J0ZOV8
This might be an option ?
Or the normal GD08. (you need how many hard drives?)
Mfusick is offline
Old 08-06-2014, 10:29 AM
Quoted: 12 Post(s)
Liked: 31
I remember. I thought about it and after not using my bluray drive for 2 years in my current HTPC I decided I don't need one in my new one.
Silverstone does make a specially designed full sized CPU fan to fit in it though if you want to go that route.
Old 08-06-2014, 10:32 AM
renethx's Avatar
Quoted: 245 Post(s)
Liked: 402
Google product search. If you select "Super Saving" (free shipping) at Nextwarehouse.com, the total price is $151.37.
The filters are attached to the fans with screws from inside the case. The only way to remove and clean the filters is remove the motherboard / the ODD cage / the HDD cage (i.e. completely disassemble the system) and unscrew the filters. Or vacuum the fans from outside the case (easier, but hard to remove dust from the filters). This is a kind of design flaw of the case.
renethx is offline
Old 08-09-2014, 06:41 AM
riffer's Avatar
Quoted: 12 Post(s)
I have a GD04. I put some large DEMCI filters on the outside. The inside filters still get dusty, but only have to be done once a year or so.
riffer is offline
