BSOD on HTPC, need assistance please!! - AVS Forum | Home Theater Discussions And Reviews
Old 08-02-2014, 09:32 PM - Thread Starter
colleycol's Avatar
Exclamation BSOD on HTPC, need assistance please!!
Guys, I have been stuck trying to figure this out. Was using Media browser Theater and now I have the dreaded blue screen of death....
Any ideas on where i should go? Please see attached...
_________________________________________________
JVC RS4810, Screen Excellence 4K 115 inch wide
Lumagen Radiance 2021
Onkyo 818, Emotiva Amp
B&W CT700 Series Speakers, (2) PowerSound Audio XS30s
HTPC running Emby, 12TB Server for storage
colleycol is offline
Old 08-02-2014, 11:10 PM
Aleron Ives's Avatar
Quoted: 1581 Post(s)
Liked: 1289
An initial search indicates that STOP error 0xF4 is related to hardware problems and often specifically those related to HDDs. How many hard drives do you have connected? Do you have any SSDs connected? Did you install any special SATA drivers, SSD "optimizer" software, or re-use any old hardware in this PC?
Aleron Ives is offline
Old 08-03-2014, 12:04 AM
BassThatHz's Avatar
Quoted: 2034 Post(s)
Liked: 1559
If you reboot and run WhoCrashed, it may tell you more information about the cause.
http://download.cnet.com/WhoCrashed/...-75205821.html
BassThatHz is online now
Old 08-03-2014, 05:25 AM
Dark_Slayer's Avatar
Quoted: 658 Post(s)
Liked: 434
I always use nirsoft's blue screen viewer
If you get two bsods then zip the dump files and upload them to sky drive. Then create a post on technet and someone should try to help out
Dark_Slayer is offline
Old 08-03-2014, 12:34 PM - Thread Starter
colleycol's Avatar
I do have an SSD drive, but the OS started in safe mode. Would it start in safe mode with a bad SSD?
Old 08-03-2014, 12:35 PM - Thread Starter
colleycol's Avatar
Looking for this now to use and see if they can help.... Thanks!
Old 08-03-2014, 04:10 PM
Liked: 1289
Windows will usually ask if you want to start in Safe Mode after you get a BSOD. There should be a prompt when you restart asking you which mode to use.
Old 08-04-2014, 01:48 PM
Quoted: 658 Post(s)
Liked: 434
Typically no, ssd is not a common failure mode for blue screens. If it failed you would usually be stuck at your bios saying "which drive should I boot from" and your ssd wouldn't show up
