How to resume play with media player classic HC’s - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-03-2014, 07:07 PM - Thread Starter
stevethebrain's Avatar
Quoted: 96 Post(s)
Liked: 25
I recently ripped a couple of DVD to HDD and trying to playback w/ the HTPC.
I started w/ VLC then found out there’s no resume play (like if I’m watching a DVD then stop it I expect to resume play where I left off).
I searched a little and found the media player classic home cinemahas the resume play
I just can’t figure out how it works.
this did'nt work
I think the feature you are describing already exists. Go in Options > Player and check "Remember File/DVD position". Is that what you want?
Also how do you Guy’s categorize the DVDs?
I'm using my D:\ drive for the ripped DVDs
copy the TS file and paste it to a folder w/ the DVDs name I see one file.
when I look in video libray for same dvd I see nine files looks like four chapters of the DVD then two orange cones, two text files windows can't open and dvd name, space used, type of disc. ect.
is it possiable to have just one DVD icon or am I reduced to one folder(these are homemade dvds)?
edit when I try to right click the DVD I want to choose which media player to playback on I only see VLC, windows media player I don't have the option of using media player classic home cieana, I have to open MPC-HC from desktop then open file. is VLC the defualt player and needs to be downgraded or completely removed?
Thanks for any tips
STB
Samsung PN58C500/Amp: Yamaha RX-V465/Polk DSW1KProSub/DefTECH SM450/C1CC/Pro80/Sony BPX37 BD/Magnavox515/ HTPC-CPU: I3 550, 3.2 GHz/Mobo: Intel H57/RAM: 6GB DDR3 1333/HDD: 1TB/2TBX2 Internal, 1TB external/Tuner: 1800-950 Haupague/W7 64 OS Remote: Harmony 700
stevethebrain is offline
post #2 of 6 Old 08-04-2014, 06:26 PM - Thread Starter
Quoted: 96 Post(s)
Liked: 25
no one here using media player classic HC
post #3 of 6 Old 08-05-2014, 08:12 PM
Krispy Kritter's Avatar
Quoted: 38 Post(s)
You simply need to change MPCHC to the default player. Sounds like you currently have VLC set as default.
Right click, "open with", select mpchc and ensure "always use the selected program..." is ticked
You can also set mpchc as the default from within the mpchc config.
...or the default Windows config (which applies to all programs/file types)> http://windows.microsoft.com/en-us/w...#1TC=windows-7
Krispy Kritter is offline
post #4 of 6 Old 08-09-2014, 06:10 AM - Thread Starter
Quoted: 96 Post(s)
Liked: 25
OK I'll set MPC-HC to the defualt
thanks for the link.
However even when I use MPC-HC from the DT Icon I still can't figure out,
I have all the (that I’ve read about) options checked.
Remember file position
Remember the DVD position
Remember the last window position
Also is there a way to not to constantly resize the view tofull screen?
Thanks STB
post #5 of 6 Old 08-09-2014, 07:14 AM
StinDaWg's Avatar
Quoted: 450 Post(s)
Liked: 214
MPC-HC will only save so many restore points (up to 40 I think?). After playing a bunch of videos you will lose the older ones. I believe there is a way to edit this in the system files somehow, but it can cause slowness/instability in the software.
StinDaWg is offline
post #6 of 6 Old 08-16-2014, 07:40 AM - Thread Starter
Quoted: 96 Post(s)
Liked: 25
I would like to press stop play and expect MPC to resumehowever it always restarts the program.
When I press exit from a playing program it actually doe’sresume this is inconvenient because I then then have to
Open file
View
Full screen.
Couple more ?s on MPC-HC
1.is it possible to avoid constantly resizing screen back upto full size?
2.the DVDs I’ve ripped usually have multiply chapters andMPC doesn’t automatically start the next chapter so I have to think well whatchapter did I just watch (I didn’t observe any highlighted chapter so I wouldknow what was just watched).
Thanks STB
Reply Home Theater Computers
