NUC for the price of the Asus Chromebox? - AVS Forum | Home Theater Discussions And Reviews
Old 08-09-2014, 02:22 PM - Thread Starter
Raident's Avatar
Quoted: 21 Post(s)
Is there anything similar to the $180 Asus Chromebox, except with the ability to run Windows?
Raident is offline
Old 08-09-2014, 02:56 PM
SteelWill's Avatar
Quoted: 79 Post(s)
Liked: 38
SteelWill is offline
Old 08-09-2014, 03:24 PM
Aryn Ravenlocke's Avatar
Quoted: 351 Post(s)
Liked: 134
I'm not quite sure what you are asking. Are you asking if it is possible to build or buy a PC with Windows on it for under $200? If that's simply the question, then the answer is yes. The real issue should be what you intend to do with the PC though. Working down in that price range, you will be rather limited in what you can do with the PC. I've seen a couple of systems that were built for about $250 that worked as very minimalist HTPCs. Both of them underwent upgrades less than a year later to keep up with new demands.
It's nice to save money. And, it's a great idea to look for ways to do so. But instead of looking for what is inexpensive and then trying to tweak it to do what you would like, you might be better off deciding what it is you want the machine to be able to do and work backwards from there. The folks on these forums know their stuff. They'll let you know what sort of guts your PC needs to have inside to achieve what you want out of it. Then, you can take those specs and shop according to the specs and look for the best deal that checks off each of your boxes.
Aryn Ravenlocke is offline
Old 08-09-2014, 03:37 PM - Thread Starter
Raident's Avatar
Quoted: 21 Post(s)
The primary purpose would be to play 1080p h.264/h.265 videos streamed from a Samba share. The secondary purpose would be to browse the web occasionally and watch Youtube videos. Supporting this all would be the ability to load an ICC profile.
Raident is offline
Old 08-09-2014, 04:37 PM
josrq's Avatar
There is this:
http://www.newegg.com/Product/Produc...&leaderboard=1
Not $180 but net $230 now. Includes Win8.1, 500GB hard drive, keyboard & mouse etc.
josrq is offline
Old 08-09-2014, 06:02 PM
Charles R's Avatar
Liked: 536
There are two NUCs roughly $150... plus memory and storage.
http://www.intel.com/content/www/us/...n2820fykh.html
http://www.intel.com/content/www/us/...ccp847dye.html
| 120" Screen | 1080p Projector | 7.2.4 Boston Acoustics & Power Sound Audio | Yamaha RX-A3060 & AudioSource AMP110 | Philips BDP7501 | LibreELEC/ODROID-C2 Media Client | Ubuntu/ODROID-XU4 Server via Kodi/Plex Media Server : LG 65EG9600 OLED TV | TiVo | Premiere+ | Blu-ray Movies for Sale | Digital HD Codes for Sale |
Charles R is offline
Old 08-09-2014, 10:02 PM
Defcon's Avatar
Quoted: 1104 Post(s)
Liked: 572
For the stated needs I cannot think of a better price/performance value than the Chromebox. It's been much cheaper, it was (may still be) $139 on Newegg, and the HP version is $150 on Amazon.
Note that you can install a full Linux distro or OpenElec. You can also easily dual boot with ChromiumOS and that will give you a full Chrome browsing experience. It also has a Haswell GPU which should be better than the Baytrail in Celeron. But I don't know anything about ICC profiles. The XBMC forums have more info.
Defcon is offline
Old 08-10-2014, 12:16 AM - Thread Starter
Raident's Avatar
Quoted: 21 Post(s)
I did consider actual Chromeboxes (and hacking Ubuntu/XBMC onto it), but I've heard that at least for the Asus Chromebox, audio over HDMI doesn't work in anything other Chrome OS.
Hardly anybody seems to have the HP Chromebox (I'm guessing that's because it's more expensive?), so it's hard to say what the situation is like over there.
Raident is offline
Old 08-10-2014, 06:11 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
I think perhaps you misconstrued this post http://forum.xbmc.org/showthread.php...660#pid1741660
No reason to use windows if you are just looking to run xbmc, though if windows is a necessity to you then the chromebox is not as good of a choice as a regular nuc
http://wiki.xbmc.org/index.php?title=ASUS_Chromebox
http://forum.xbmc.org/showthread.php?tid=194362
Audio over hdmi works in openelec, just use the script above to install it standalone (gives you the option to backup chrome's install to a flash drive as well)
Dark_Slayer is offline
