Problems with new HTPC setup - AVS Forum | Home Theater Discussions And Reviews
Old 08-10-2014, 07:08 AM - Thread Starter
Richardw322's Avatar
So I rebuilt my HTPC using Windows 8.1 update and got Media center. I have 3 problems
1. I installed LAV filters, but WMC still doesn't see my MKV files. I can play them just fine in Windows Media Player, so I know that LAV is being used, but nothing in WMC.
2. I installed Media Browser Server, and set up a couple folders. Then I installed Media Browser Classic and it showed up in WMC. It played the MKV files just fine. Thought I was set, but then I noticed it was only showing the last season of some TV shows I have. The folders are set up the same as when I used MB2 (the old one) and in 2 it all worked just fine.
3 Playing around I went out of WMC and played with the server a little, then back to test. Loaded WMC clicked on Media Browser and it said can't find server.
At that point I gave up for the day, but want to try again today.
Richardw322 is offline
Old 08-10-2014, 07:24 AM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
I haven't tried to do MKV's in WMC (not MB) in ages, but iirc, there is a registry entry that needs to be changed in order for MKVs to work. I also have a suspicion that some of the codec packs like Shark007 automatically makes the proper associations.
If you just got it up and running my first guess is that it just hasn't finished updating the cache, especially if you have a sizable library. Just out of curiosity, what folder structure are you using for your shows? (And does MB3 Server recognize that library as TV?) I use: Show Title\Season 00\Show Title - sXXeYY - Episode Title.ext
That could be any number of things. I'd start with the most obvious and work to the more complex stuff. Can you connect to the server with any other means? (ping it, remote desktop, file shares) If you can communicate with it, then is MB3 server still running? Is your firewall doing anything odd?
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is online now
Old 08-10-2014, 07:32 AM - Thread Starter
OOps, sorry for the confusion. Both the server and the client are on the same computer. It appears that is the only way to work the silly thing. I liked the old one better.
Old 08-10-2014, 07:39 AM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
Well, that should make troubleshooting easier.
Again, going with the old reliable stuff, I'd restart the computer, open up MB Server and make sure it's running then see if it'll reconnect in WMC again.
Old 08-10-2014, 08:42 AM - Thread Starter
And for the record we use the same file path and title
Old 08-10-2014, 09:08 AM
LastButNotLeast's Avatar
Quoted: 1480 Post(s)
Liked: 1070
Most of us did. Many of us have gone back to "the old one."
I'm sure you'll (eventually) be able to do what you want, it just wasn't worth it for me.
Good luck.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
Old 08-10-2014, 01:46 PM - Thread Starter
Well, I got Media browser working. problem was the server wasn't auto starting on reboot, religion. Still kind of like to get MKV in WMC, but Media browser works. Fine for that. One other thing, Xbox Video doesn't work. When I go to stream a movie, I hear sound but no picture. Nothing works but to reboot the computer. Tried alt f4, control alt delete, alt tab, no screen at all. Anyone have an idea on that?
Old 08-16-2014, 06:44 AM - Thread Starter
Just realized another problem. When I let the computer go to sleep, on resume it's like 720P resolution instead of 1080P. If I reboot it comes back at 1080P. Do I need to set a profile in the AMD Catalyst control?
Old 08-16-2014, 08:01 AM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
In my case this is highly dependent on the order I power things up. My PC is connected to my AVR which then goes to my TV. So turn on my TV, wake my PC then turn on my AVR after PC is awake. All this is done with one macro on my remote. A different order gives my unpredictable resolution changes.
mdavej is offline
Old 08-16-2014, 08:45 AM
SteelWill's Avatar
Quoted: 79 Post(s)
Liked: 38
The registry file for getting MKV's to show in WMC is here:
http://www.hack7mc.com/2009/02/mkvs-...windows-7.html
SteelWill is offline
Old 08-16-2014, 08:59 AM
JustaSheep's Avatar
Quoted: 25 Post(s)
Liked: 32
Odd, for me the AVR is the first thing to turn on in order to get the correct resolution. If the HDMI controller on the avr isn't booted all the way, I get downgraded graphics and audio from the source.
JustaSheep is offline
Old 08-16-2014, 09:27 AM
dfkimbro's Avatar
Quoted: 127 Post(s)
Liked: 84
Thanks for posting this! Bookmarked.
dfkimbro is offline
Old 08-21-2014, 04:34 PM - Thread Starter
Thanks for this SteelWill!!
Also, figured out the REZ change, for some reason the rez changed in Media Center, thought I went through in setup but either I missed it or it changed somehow. Set it to 1080P 59.994 (I think? I'm not at it) and that's now fine. Now just Xbox Video and the MKV thing to play with. So much to do, and no way to get the little woman away so I can play!!
Old 08-23-2014, 01:27 PM
Dark_Slayer's Avatar
Quoted: 655 Post(s)
Liked: 434
Nice link
This is correct on both counts. Shark's recommended settings will do this
Dark_Slayer is offline
