4K questions... - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ElJimador
post #1 of 9 Old 08-10-2014, 08:41 AM - Thread Starter
hlkc's Avatar
4K questions...
I've a Samsung 4K 55" display. In order to take an advantage of real 4K experience in my HTPC, I assume I need a 4K graphic card and 4K material, BD today only, right?
If I just update the graphic card, w/o 4K content, it won't make much different, right?
Any reasonable 4K display card in the market today?
Thanks for the advice in advance!
hlkc is offline
post #2 of 9 Old 08-10-2014, 02:25 PM
Thrillho's Avatar
Quoted: 14 Post(s)
Liked: 33
Right now the only real thing that will take advantage of 4K is PC games with a really high-end video card. That's assuming you can feed your TV 60hz. There is no current method of getting 4k video content outside of a few streaming services and the extra compression kind of negates the extra resolution. There are a few demo clips you can download to show off your set, the Elysium trailer looks amazing but no readily available full length movies.
Thrillho is offline
post #3 of 9 Old 08-10-2014, 03:26 PM
mdavej's Avatar
Quoted: 2126 Post(s)
Liked: 940
4k questions ... man, that's a lot of questions. You're gonna need more than one thread.
mdavej is online now
post #4 of 9 Old 08-11-2014, 12:18 PM
blueiedgod's Avatar
Quoted: 254 Post(s)
Liked: 94
I remember back in 1994 or 1995, my girlfriend and I sat in the "home theater" at Circuit City and marveled at the 32" Flat Panel TV (that must have been "only" 3" thick) for $10,000, playing something that looked really good compared to the rest of the tube TVs on display.
Thanks for the efforts of the early adopters, willing to plunk $10,000 for a TV that had the capability (720p capability had been surpassed long before TV's became mainstream), but no source of content, I was able to afford to buy my own first 42" Flat Panel (LCD) TV in 2004 for $600, and then a 55" LED for $400 in 2012.
6 TV's in the house on FiOS and we only pay $4.99/month to connect them all!!! Power to the CableCard and WMC7!!!
blueiedgod is offline
post #5 of 9 Old 08-11-2014, 12:46 PM
ElJimador's Avatar
Quoted: 116 Post(s)
Liked: 109
Just doing a quick power search on NewEgg, here's the cheapest video card I can find that will output 4K -- http://www.newegg.com/Product/Produc...82E16814121836
With a card like this the Samsung would be doing all the upscaling since I'm sure you wouldn't run MadVR with this. If the Samsung is good at that though (and for what they cost they should be a heck of a lot better than a Seiki) than a passive card like this for $50 after rebate sounds like a pretty sweet deal to me.
ElJimador is offline
post #6 of 9 Old 08-11-2014, 06:45 PM - Thread Starter
hlkc's Avatar
Thanks ElJimador! Can you please share with me what I need to look for when I pick up a GC that can support 4K? I'm using a native HDMI from this MB http://www.newegg.com/Product/Produc...82E16813131850
Thanks again!
hlkc is offline
post #7 of 9 Old 08-11-2014, 07:52 PM
ElJimador's Avatar
Quoted: 116 Post(s)
Liked: 109
Thanks again!
Just use the power search on NewEgg like I did and select everything w/a max resoltion of 4k (2160p). Just make sure they output that through HDMI and not DisplayPort only since I assume your Samsung doesn't have DP in.
If you want to make a more serious investment and get a card to do higher level MadVR w/4k then I would still do a cheaper card now to bridge the gap until HDMI 2.0 cards start coming out.
post #8 of 9 Old 08-11-2014, 08:40 PM
ajhieb's Avatar
Quoted: 928 Post(s)
Liked: 663
If the card is outputting 4K then the Samsung wouldn't be doing any upscaling.
RAID protection is only for failed drives. That's it. It's no replacement for a proper backup.
ajhieb is offline
post #9 of 9 Old 08-11-2014, 10:50 PM
ElJimador's Avatar
Quoted: 116 Post(s)
Liked: 109
You're right, sorry. I just meant that w/a card like this you couldn't be using chroma upscaling, etc w/MadVR (let alone image doubling) like yiu might be able to do w/a higher end card. At least not outputting to 4k.
ajhieb likes this.
Reply Home Theater Computers
