K-lite and mpc huge frame drop - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Sammy2
post #1 of 5 Old 08-13-2014, 05:10 AM - Thread Starter
Liked: 0
Exclamation K-lite and mpc huge frame drop
my system : intel i3 2310m 2.10 ghz,
6gb ram , 1tb hard , hd6470m amd
i installed k-lite codec pack with lav and madvr renderer .
in madvr i geting 3000+ frame drop in 1080p playback.
in evr custom preset i get only 2 or 3 framedrop.
i using dxva-copyback in lav.
no other changes or codecs.
i dont know why this much of drop in frame please some one help .
no other extra configuration i have done . (new laptop).
thanks in advance
robo king is offline
post #2 of 5 Old 08-13-2014, 11:53 AM
Sammy2's Avatar
Quoted: 561 Post(s)
Liked: 264
Uninstall k-lite and use the built in LAV filters in MPC-HC. If you want to use a codec pack, use Shark007 but be sure to uncheck the boxes for the add-in software you don't need. Get MadVR directly from the doom 9 forum.
StinDaWg likes this.
Sammy2 is online now
post #3 of 5 Old 08-14-2014, 12:12 AM - Thread Starter
Liked: 0
Thank you . i un-installed k-lite and installed 32 bit mpc and madvr its works fine.
but in k-lite i had 3000 frame drop in 1080p playback , in the method u said give me only 20 -30 fps drop that too when i try to skip (slider) . is it common ? .
post #4 of 5 Old 08-14-2014, 05:21 AM
Sammy2's Avatar
Quoted: 561 Post(s)
Liked: 264
That number of drops is normal when first starting a video or when skipping. If you don't see it then dont worry about it!
post #5 of 5 Old 08-14-2014, 05:55 AM - Thread Starter
Liked: 0
Talking
Originally Posted by sammy2 View Post
that number of drops is normal when first starting a video or when skipping. If you don't see it then dont worry about it!
thanks !
Reply Home Theater Computers
